noe nytt om R600 og 8900GTS/GTX?
fant dette:
The G80 from now:
GeForce 8800 GTX
Production Proces: 90nm
Stream (Shader) Processors 128
Core Clock (MHz) 575
Shader Clock (MHz) 1350
Memory Type GDDR3
Memory Clock (MHz) x2 900
Memory amount 768 MB
Memory Interface 384-bit
Memory Bandwidth (GB/sec) 86.4
Texture Fill Rate (billion/sec) 36.8
This is the new G80(or G81 due to smaller production proces) as I think it will be, based upon the evolution from the G70 to G71, and that was smaller die size with higher clocks without any major changes in the architecture.
GeForce 8900 GTX
Production Proces: 65nm
Core Clock (MHz) 625~675
Shader Clock (MHz) 1400~1500
Memory Type GDDR3( maybe 4)
Memory Clock (MHz) x2 900~1000 (1000~1100 if it's GDDR4)
Memory Bandwidth (GB/sec) 86.4~96(96~105.6 GDDR4)
Texture Fill Rate (billion/sec) 40~43.2
fra denne siden
noen som vet om det stemmer?
og dette om R600:
700-800MHz Core clock.
16 ROPs.
64 Shader Units /4-way SIMDs (theoretycal performance of 256 simple scalar shader units)/.
512bit Memory interface / 1024bit Internal RingBus.
1024MB (Consumer) / 2048MB (FireGL) videomemory.
1800MHz (GDDR3) / 2200MHz (GDDR4) memoryclocks.
115GB/s (GDDR3) / 140.1GB/s (GDDR4) memory bandwidth.
12 layer very complex (and very expensive) PCB.
Large (and longer than the PCB) quad-heatpipe AC Silencer like cooler.
ATi RageTheather 200 chip handles the VIVO functions.
fra her
Endret av skylinepower
spennende... kjenner det kribler over allt :p
men..
leste at kortet var 30 cm håper det er total lengde, ikke bare pcb. så kommer kjøler utpå
har mest tro på 8900gtx, de har hatt tid og finpussa ting. 65nm høres mye kaldere ut enn 90nm....
men lite datoer og se
