big typhoon og lian li kabinett
sham_rock
Ser ut som det skal gå...
I have a Lian-li PC-V1000 for my main computer case, I personally think it’s the best case I’ve ever seen. Before I got the Big Typhoon, I also thought it was extremely roomy and easy to work with. The Big Typhoon scoffed at this idea; it was physically impossible to install the heat sink with the motherboard already inside the case. The 120mm fan was literally touching the separator wall in-between the power supply and motherboard sections (which is upside down on the Lian-li compared to most cases).
Du kan lese litt her: http://www.virtual-hideout.net/reviews/tt_...on/index2.shtml
