tibbs Skrevet 17. januar 2007 Forfatter Del Skrevet 17. januar 2007 Her er min menu.lst. Problemet er altså at jeg ikke får fram Windows som et valg ved oppstart, bare Arch. # Config file for GRUB - The GNU GRand Unified Bootloader # /boot/grub/menu.lst # DEVICE NAME CONVERSIONS # # Linux Grub # ------------------------- # /dev/fd0 (fd0) # /dev/hda (hd0) # /dev/hdb2 (hd1,1) # /dev/hda3 (hd0,2) # # FRAMEBUFFER RESOLUTION SETTINGS # +-------------------------------------------------+ # | 640x480 800x600 1024x768 1280x1024 # ----+-------------------------------------------- # 256 | 0x301=769 0x303=771 0x305=773 0x307=775 # 32K | 0x310=784 0x313=787 0x316=790 0x319=793 # 64K | 0x311=785 0x314=788 0x317=791 0x31A=794 # 16M | 0x312=786 0x315=789 0x318=792 0x31B=795 # +-------------------------------------------------+ # general configuration: timeout 5 default 0 color light-blue/black light-cyan/blue # boot sections follow # each is implicitly numbered from 0 in the order of appearance below # # TIP: If you want a 1024x768 framebuffer, add "vga=773" to your kernel line. # #-* # (0) Arch Linux title Arch Linux root (hd0,1) kernel /boot/vmlinuz26 root=/dev/sda2 ro initrd /boot/kernel26.img # (1) Arch Linux title Arch Linux Fallback root (hd0,1) kernel /boot/vmlinuz26 root=/dev/sda2 ro initrd /boot/kernel26-fallback.img title Windows XP root (hd0,0) savedefault makeactive chainloader +1 Lenke til kommentar
Mr.Elendig Skrevet 17. januar 2007 Del Skrevet 17. januar 2007 . . . # (0) Arch Linux title Arch Linux root (hd0,1) kernel /boot/vmlinuz26 root=/dev/sda2 ro initrd /boot/kernel26.img # (1) Arch Linux title Arch Linux Fallback root (hd0,1) kernel /boot/vmlinuz26 root=/dev/sda2 ro initrd /boot/kernel26-fallback.img # (2) Wintendo title Windows XP rootnoverify (hd0,0) chainloader +1 Lenke til kommentar
tibbs Skrevet 17. januar 2007 Forfatter Del Skrevet 17. januar 2007 Mr.Elendig: Jeg prøvde ditt forslag, men det ville ikke det heller. Nye forslag mottas med takk Lenke til kommentar
Mr.Elendig Skrevet 17. januar 2007 Del Skrevet 17. januar 2007 prøv å innstaler grub på nytt: grub-install /dev/hda Lenke til kommentar
tibbs Skrevet 17. januar 2007 Forfatter Del Skrevet 17. januar 2007 Når jeg prøver å installere Grub på nytt får jeg denne meldingen: /dev/hda: Not found or not a block device Lenke til kommentar
wil Skrevet 17. januar 2007 Del Skrevet 17. januar 2007 Grub bruker da vel ikke hda, bruker den ikke hd0? Lenke til kommentar
tibbs Skrevet 17. januar 2007 Forfatter Del Skrevet 17. januar 2007 (endret) Når jeg prøver å reinstallere Grub med /dev/hd0 får jeg samme feilmelding: /dev/hd0: Not found or not a block device Men er det ikke sda jeg skal bruke mon tro? Endret 17. januar 2007 av tibbs Lenke til kommentar
olefiver Skrevet 17. januar 2007 Del Skrevet 17. januar 2007 jo, det er sda du skal bruke. Lenke til kommentar
tibbs Skrevet 17. januar 2007 Forfatter Del Skrevet 17. januar 2007 Men hva skriver jeg i menu.lst? Blir det (sda0,0) eller blir det (sda1,0)? Og om jeg reinstallerer grub, blir det da /dev/sda, eller sda0, eller hva? Blir helt snurrig i hodet av alle disse benevnelsene. Lenke til kommentar
olefiver Skrevet 17. januar 2007 Del Skrevet 17. januar 2007 (endret) GRUB betegner første harddisk som HD0, uavhengig om det er sata eller pata(ide). Så hvis du har pata disker i maskina di kan jeg ikke garantere om GRUB regner sata eller pata disken som første disk. Jeg har en pata disk i desktop maskina mi og har erfart det sjøl. Så om du har problemer med det kan jeg muligens hjelpe. Men nok om det. Som sagt GRUB bruker betegnelsen HD0 om første disk, så /dev/sda er i GRUB HD0. Partisjoner, samme system: /dev/sda1 er i GRUB HD0,0 Når det gjelder menu.lst, behold versjonen til Mr.Elendig. Hvis det fortsatt ikke funker etter reinstall av GRUB har jeg noen forslag liggende i en arkivert menu.lst fil. Endret 17. januar 2007 av olefiver Lenke til kommentar
tibbs Skrevet 19. januar 2007 Forfatter Del Skrevet 19. januar 2007 Uansett hva jeg enn prøver, så nytter det ikke å få fram Windows som valg ved boot. Nye tips mottas med stor takk Lenke til kommentar
tibbs Skrevet 19. januar 2007 Forfatter Del Skrevet 19. januar 2007 Nå klarte jeg å få fram Windows som valg ved boot, men problemet nå er at når jeg trykker på Windows hopper den tilbake på Arch og booter den. Lenke til kommentar
