rhofset Skrevet 13. januar 2007 Del Skrevet 13. januar 2007 (endret) Parse error: syntax error, unexpected T_ELSE in /home/melhusga/public_html/subdreamer/forum/admin/admin_groups.php on line 379 Noen som kan kikke litt? <?php /*************************************************************************** * admin_groups.php * ------------------- * begin : Saturday, Feb 13, 2001 * copyright : (C) 2001 The phpBB Group * email : [email protected] * * $Id: admin_groups.php,v 1.25.2.13 2006/03/09 19:42:41 grahamje Exp $ * * ***************************************************************************/ /*************************************************************************** * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * ***************************************************************************/ define('IN_PHPBB', 1); if ( !empty($setmodules) ) { $filename = basename(__FILE__); $module['Groups']['Manage'] = $filename; return; } // // Load default header // $phpbb_root_path = './../'; require($phpbb_root_path . 'extension.inc'); require('./pagestart.' . $phpEx); if ( isset($HTTP_POST_VARS[POST_GROUPS_URL]) || isset($HTTP_GET_VARS[POST_GROUPS_URL]) ) { $group_id = ( isset($HTTP_POST_VARS[POST_GROUPS_URL]) ) ? intval($HTTP_POST_VARS[POST_GROUPS_URL]) : intval($HTTP_GET_VARS[POST_GROUPS_URL]); } else { $group_id = 0; } if ( isset($HTTP_POST_VARS['mode']) || isset($HTTP_GET_VARS['mode']) ) { $mode = ( isset($HTTP_POST_VARS['mode']) ) ? $HTTP_POST_VARS['mode'] : $HTTP_GET_VARS['mode']; $mode = htmlspecialchars($mode); } else { $mode = ''; } if ( isset($HTTP_POST_VARS['edit']) || isset($HTTP_POST_VARS['new']) ) { // // Ok they are editing a group or creating a new group // $template->set_filenames(array( 'body' => 'admin/group_edit_body.tpl') ); if ( isset($HTTP_POST_VARS['edit']) ) { // // They're editing. Grab the vars. // $sql = "SELECT * FROM " . GROUPS_TABLE . " WHERE group_single_user <> " . TRUE . " AND group_id = $group_id"; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Error getting group information', '', __LINE__, __FILE__, $sql); } if ( !($group_info = $db->sql_fetchrow($result)) ) { message_die(GENERAL_MESSAGE, $lang['Group_not_exist']); } $mode = 'editgroup'; $template->assign_block_vars('group_edit', array()); } else if ( isset($HTTP_POST_VARS['new']) ) { $group_info = array ( 'group_name' => '', 'group_description' => '', 'group_moderator' => '', 'group_type' => GROUP_OPEN); $group_open = ' checked="checked"'; $mode = 'newgroup'; } // // Ok, now we know everything about them, let's show the page. // if ($group_info['group_moderator'] != '') { $sql = "SELECT user_id, username FROM " . USERS_TABLE . " WHERE user_id = " . $group_info['group_moderator']; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Could not obtain user info for moderator list', '', __LINE__, __FILE__, $sql); } if ( !($row = $db->sql_fetchrow($result)) ) { message_die(GENERAL_ERROR, 'Could not obtain user info for moderator list', '', __LINE__, __FILE__, $sql); } $group_moderator = $row['username']; } else { $group_moderator = ''; } $group_open = ( $group_info['group_type'] == GROUP_OPEN ) ? ' checked="checked"' : ''; $group_closed = ( $group_info['group_type'] == GROUP_CLOSED ) ? ' checked="checked"' : ''; $group_hidden = ( $group_info['group_type'] == GROUP_HIDDEN ) ? ' checked="checked"' : ''; $s_hidden_fields = '<input type="hidden" name="mode" value="' . $mode . '" /><input type="hidden" name="' . POST_GROUPS_URL . '" value="' . $group_id . '" />'; $template->assign_vars(array( 'GROUP_NAME' => $group_info['group_name'], 'GROUP_DESCRIPTION' => $group_info['group_description'], 'GROUP_MODERATOR' => $group_moderator, 'L_GROUP_TITLE' => $lang['Group_administration'], 'L_GROUP_EDIT_DELETE' => ( isset($HTTP_POST_VARS['new']) ) ? $lang['New_group'] : $lang['Edit_group'], 'L_GROUP_NAME' => $lang['group_name'], 'L_GROUP_DESCRIPTION' => $lang['group_description'], 'L_GROUP_MODERATOR' => $lang['group_moderator'], 'L_FIND_USERNAME' => $lang['Find_username'], 'L_GROUP_STATUS' => $lang['group_status'], 'L_GROUP_OPEN' => $lang['group_open'], 'L_GROUP_CLOSED' => $lang['group_closed'], 'L_GROUP_HIDDEN' => $lang['group_hidden'], 'L_GROUP_DELETE' => $lang['group_delete'], 'L_GROUP_DELETE_CHECK' => $lang['group_delete_check'], 'L_SUBMIT' => $lang['Submit'], 'L_RESET' => $lang['Reset'], 'L_DELETE_MODERATOR' => $lang['delete_group_moderator'], 'L_DELETE_MODERATOR_EXPLAIN' => $lang['delete_moderator_explain'], 'L_YES' => $lang['Yes'], 'U_SEARCH_USER' => append_sid("../search.$phpEx?mode=searchuser"), 'S_GROUP_OPEN_TYPE' => GROUP_OPEN, 'S_GROUP_CLOSED_TYPE' => GROUP_CLOSED, 'S_GROUP_HIDDEN_TYPE' => GROUP_HIDDEN, 'S_GROUP_OPEN_CHECKED' => $group_open, 'S_GROUP_CLOSED_CHECKED' => $group_closed, 'S_GROUP_HIDDEN_CHECKED' => $group_hidden, 'S_GROUP_ACTION' => append_sid("admin_groups.$phpEx"), 'S_HIDDEN_FIELDS' => $s_hidden_fields) ); $template->pparse('body'); } else if ( isset($HTTP_POST_VARS['group_update']) ) { // // Ok, they are submitting a group, let's save the data based on if it's new or editing // if ( isset($HTTP_POST_VARS['group_delete']) ) { // // Reset User Moderator Level // // Is Group moderating a forum ? $sql = "SELECT auth_mod FROM " . AUTH_ACCESS_TABLE . " WHERE group_id = " . $group_id; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Could not select auth_access', '', __LINE__, __FILE__, $sql); } $row = $db->sql_fetchrow($result); if (intval($row['auth_mod']) == 1) { // Yes, get the assigned users and update their Permission if they are no longer moderator of one of the forums $sql = "SELECT user_id FROM " . USER_GROUP_TABLE . " WHERE group_id = " . $group_id; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Could not select user_group', '', __LINE__, __FILE__, $sql); } $rows = $db->sql_fetchrowset($result); for ($i = 0; $i < count($rows); $i++) { $sql = "SELECT g.group_id FROM " . AUTH_ACCESS_TABLE . " a, " . GROUPS_TABLE . " g, " . USER_GROUP_TABLE . " ug WHERE (a.auth_mod = 1) AND (g.group_id = a.group_id) AND (a.group_id = ug.group_id) AND (g.group_id = ug.group_id) AND (ug.user_id = " . intval($rows[$i]['user_id']) . ") AND (ug.group_id <> " . $group_id . ")"; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Could not obtain moderator permissions', '', __LINE__, __FILE__, $sql); } if ($db->sql_numrows($result) == 0) { $sql = "UPDATE " . USERS_TABLE . " SET user_level = " . USER . " WHERE user_level = " . MOD . " AND user_id = " . intval($rows[$i]['user_id']); if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not update moderator permissions', '', __LINE__, __FILE__, $sql); } } } } // // Delete Group // // Delete group in gallery require($phpbb_root_path . 'g2helper.inc'); $g2h = new g2helper($db); $g2h->deleteGroup($group_id); $sql = "DELETE FROM " . GROUPS_TABLE . " WHERE group_id = " . $group_id; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not update group', '', __LINE__, __FILE__, $sql); } $sql = "DELETE FROM " . USER_GROUP_TABLE . " WHERE group_id = " . $group_id; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not update user_group', '', __LINE__, __FILE__, $sql); } $sql = "DELETE FROM " . AUTH_ACCESS_TABLE . " WHERE group_id = " . $group_id; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not update auth_access', '', __LINE__, __FILE__, $sql); } $message = $lang['Deleted_group'] . '<br /><br />' . sprintf($lang['Click_return_groupsadmin'], '<a href="' . append_sid("admin_groups.$phpEx") . '">', '</a>') . '<br /><br />' . sprintf($lang['Click_return_admin_index'], '<a href="' . append_sid("index.$phpEx?pane=right") . '">', '</a>'); message_die(GENERAL_MESSAGE, $message); } else { $group_type = isset($HTTP_POST_VARS['group_type']) ? intval($HTTP_POST_VARS['group_type']) : GROUP_OPEN; $group_name = isset($HTTP_POST_VARS['group_name']) ? htmlspecialchars(trim($HTTP_POST_VARS['group_name'])) : ''; $group_description = isset($HTTP_POST_VARS['group_description']) ? trim($HTTP_POST_VARS['group_description']) : ''; $group_moderator = isset($HTTP_POST_VARS['username']) ? $HTTP_POST_VARS['username'] : ''; $delete_old_moderator = isset($HTTP_POST_VARS['delete_old_moderator']) ? true : false; if ( $group_name == '' ) { message_die(GENERAL_MESSAGE, $lang['No_group_name']); } else if ( $group_moderator == '' ) { message_die(GENERAL_MESSAGE, $lang['No_group_moderator']); } $this_userdata = get_userdata($group_moderator, true); $group_moderator = $this_userdata['user_id']; if ( !$group_moderator ) { message_die(GENERAL_MESSAGE, $lang['No_group_moderator']); } if( $mode == "editgroup" ) { $sql = "SELECT * FROM " . GROUPS_TABLE . " WHERE group_single_user <> " . TRUE . " AND group_id = " . $group_id; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Error getting group information', '', __LINE__, __FILE__, $sql); } if( !($group_info = $db->sql_fetchrow($result)) ) { message_die(GENERAL_MESSAGE, $lang['Group_not_exist']); } if ( $group_info['group_moderator'] != $group_moderator ) { if ( $delete_old_moderator ) { $sql = "DELETE FROM " . USER_GROUP_TABLE . " WHERE user_id = " . $group_info['group_moderator'] . " AND group_id = " . $group_id; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not update group moderator', '', __LINE__, __FILE__, $sql); } } $sql = "SELECT user_id FROM " . USER_GROUP_TABLE . " WHERE user_id = $group_moderator AND group_id = $group_id"; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Failed to obtain current group moderator info', '', __LINE__, __FILE__, $sql); } if ( !($row = $db->sql_fetchrow($result)) ) { $sql = "INSERT INTO " . USER_GROUP_TABLE . " (group_id, user_id, user_pending) VALUES (" . $group_id . ", " . $group_moderator . ", 0)"; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not update group moderator', '', __LINE__, __FILE__, $sql); } } } // Update group in gallery require($phpbb_root_path . 'g2helper.inc'); $g2h = new g2helper($db); $g2h->updateGroup($group_id, str_replace("\'", "''", $group_name)); $sql = "UPDATE " . GROUPS_TABLE . " SET group_type = $group_type, group_name = '" . str_replace("\'", "''", $group_name) . "', group_description = '" . str_replace("\'", "''", $group_description) . "', group_moderator = $group_moderator WHERE group_id = $group_id"; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not update group', '', __LINE__, __FILE__, $sql); } $message = $lang['Updated_group'] . '<br /><br />' . sprintf($lang['Click_return_groupsadmin'], '<a href="' . append_sid("admin_groups.$phpEx") . '">', '</a>') . '<br /><br />' . sprintf($lang['Click_return_admin_index'], '<a href="' . append_sid("index.$phpEx?pane=right") . '">', '</a>');; message_die(GENERAL_MESSAGE, $message); } else if( $mode == 'newgroup' ) // Create new group in gallery require($phpbb_root_path . 'g2helper.inc'); $g2h = new g2helper($db); $g2h->createGroup(str_replace("\'", "''", $group_name)); { $sql = "INSERT INTO " . GROUPS_TABLE . " (group_type, group_name, group_description, group_moderator, group_single_user) VALUES ($group_type, '" . str_replace("\'", "''", $group_name) . "', '" . str_replace("\'", "''", $group_description) . "', $group_moderator, '0')"; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not insert new group', '', __LINE__, __FILE__, $sql); } $new_group_id = $db->sql_nextid(); $sql = "INSERT INTO " . USER_GROUP_TABLE . " (group_id, user_id, user_pending) VALUES ($new_group_id, $group_moderator, 0)"; if ( !$db->sql_query($sql) ) { message_die(GENERAL_ERROR, 'Could not insert new user-group info', '', __LINE__, __FILE__, $sql); } $message = $lang['Added_new_group'] . '<br /><br />' . sprintf($lang['Click_return_groupsadmin'], '<a href="' . append_sid("admin_groups.$phpEx") . '">', '</a>') . '<br /><br />' . sprintf($lang['Click_return_admin_index'], '<a href="' . append_sid("index.$phpEx?pane=right") . '">', '</a>');; message_die(GENERAL_MESSAGE, $message); } else { message_die(GENERAL_MESSAGE, $lang['No_group_action']); } else { $sql = "SELECT group_id, group_name FROM " . GROUPS_TABLE . " WHERE group_single_user <> " . TRUE . " ORDER BY group_name"; if ( !($result = $db->sql_query($sql)) ) { message_die(GENERAL_ERROR, 'Could not obtain group list', '', __LINE__, __FILE__, $sql); } $select_list = ''; if ( $row = $db->sql_fetchrow($result) ) { $select_list .= '<select name="' . POST_GROUPS_URL . '">'; do { $select_list .= '<option value="' . $row['group_id'] . '">' . $row['group_name'] . '</option>'; } while ( $row = $db->sql_fetchrow($result) ); $select_list .= '</select>'; } $template->set_filenames(array( 'body' => 'admin/group_select_body.tpl') ); $template->assign_vars(array( 'L_GROUP_TITLE' => $lang['Group_administration'], 'L_GROUP_EXPLAIN' => $lang['Group_admin_explain'], 'L_GROUP_SELECT' => $lang['Select_group'], 'L_LOOK_UP' => $lang['Look_up_group'], 'L_CREATE_NEW_GROUP' => $lang['New_group'], 'S_GROUP_ACTION' => append_sid("admin_groups.$phpEx"), 'S_GROUP_SELECT' => $select_list) ); if ( $select_list != '' ) { $template->assign_block_vars('select_box', array()); } $template->pparse('body'); } include('./page_footer_admin.'.$phpEx); ?> Spoiler-tag lagt inn av moderator JohndoeMAKT Endret 13. januar 2007 av JohndoeMAKT Lenke til kommentar
The_Lozer Skrevet 14. januar 2007 Del Skrevet 14. januar 2007 (endret) Kva er line 379? 7713987[/snapback] linje 7716742[/snapback] Det vet vi, men hva står det på linje 379? EDIT: POST 100 Endret 14. januar 2007 av The_Lozer Lenke til kommentar
loathsome Skrevet 14. januar 2007 Del Skrevet 14. januar 2007 (endret) Hva som står på linje 379 er jo egentlig urelevant, da det ikke er der problemet forekommer. Uansett, her har dere linje 379: else Endret 14. januar 2007 av loathsome Lenke til kommentar
magicgunnar Skrevet 14. januar 2007 Del Skrevet 14. januar 2007 Hva som står på linje 379 er jo egentlig urelevant, da det ikke er der problemet forekommer. Uansett, her har dere linje 379: else 7717681[/snapback] Det hadde nok vært enklere om linje 379 hadde vært uthevet i kode-eksempelet, for meg ser det ut som det er to "else" etterhverandre og det går vel ikke: if(noe){ noe } else{ noe annet } else{ noe helt annet } Dermed blir det feil. Men har ikke sett nok på scriptet til å si noe om hvordan det egentlig skal være. Lenke til kommentar
loathsome Skrevet 14. januar 2007 Del Skrevet 14. januar 2007 Dersom det magicgunnar påstår er tilfellet, så kan du helle gjøre slik; PHP <?php if(noe){ noe } elseif(noe annet){ noe annet } else{ noe helt annet } ?> Lenke til kommentar
