Command and Conquer 3 vil støtte Vision kamera
kewell79
One of the greatest features for Command and Conquer 3 on the Xbox 360 is the ability to use the Xbox live camera.
See the Enemy Before You Crush Them:
Using Xbox 360's revolutionary VisionCam technology you can now literally see the face of your opponent while you decimate him in Xbox Live battles. Plus, for the winner, the Spotlight cam gives you an unchallenged ten seconds of fame to let your enemy know exactly how you feel about your victory.
Link
