Den Store Aksjetråden
Tror jeg ville startet i noe tryggere enn seismikk-bransjen. Der dør de jo som fluer om dagen, så du har rett i at mange har gått konkurs.
EDIT: Du må forøvrig ut med litt over 10'000 for en børspost. Men hvis du har råd til å tape dette er det jo bare å kjøre på, selv om du kanskje bør gjøre litt mer research først.
Endret av haarod
Hei, et lite spm.
Noen som vet om et godt TA - verktøy/program til å analysere aksjer. Tenkte helst på et gratis et som man kan legge inn trendlinjer med.
På forhånd takker jeg for svar!
EsAa
Oil vs. Natural Gas: Something Has to Give
The price of oil has always been front and center for market watchers, but it is now watched as closely as ever. There are a variety of reasons for this. One is oil’s wild ride last year. It rocketed all the way up to $147.50 a barrel last June before plummeting down to $33 in January/February of this year. (At that time, Russian government sources told me the government there was making budget plans assuming that oil would hit $20 a barrel.)
Another reason is the fact that demand for oil simply has to pick up if and when the global economy resumes growth. Supply and demand are the most important factors in determining the price of anything, but Dan Niles, Co-Chief Investment Officer at Alpha One Capital Partners, is closely watching another way to view oil prices, and that is their relationship to natural gas. As Dan recently emailed me, oil has historically traded at 8x to 10x the price of natural gas. One of the reasons it usually stays within that range is the law of physics: On a thermal basis, it takes roughly six times the amount of oil to generate the same amount of heat as natural gas.
Looking at today’s prices, however, oil is going for a hefty 17x the price of natural gas, far outside the historical norm. What does this mean? Either oil is overvalued right now, or natural gas is incredibly cheap. Dan told me he believes that oil will get crushed or natural gas will go up a lot over the next year “because the laws of physics do not change.”
It will be interesting to see what happens. I’m hearing a lot of talk that oil has more room to fall, at least in the short term. If a global recovery gets under way in earnest later this year or early in 2010, however, I wouldn’t be surprised to see prices increase.
Dan is primarily a technology investor, but recently he has been investing in the “inflation trade,” buying commodities producers on the bet that international economies will see increased demand in all sorts of raw materials and resources such as aluminum, copper, iron ore, steel, and oil among others.
Jeg har hørt at folk prater om dette fra stadig flere hold nå. Noen som har noen tanker om det er olje som er uforholdsmessig dyr eller om det er gass som er uforholdsmessig billig? Og er det selskaper på Oslo Børs hvor lønnsomhet er kraftig korrelert med gassprisene? NEC er jo ett alternativ, noen andre?
Gjest member-101642
Eltek går greit for tiden. Det kommer den sannsynligvis til å gjøre frem til tallene for andre kvartal kommer. Da frykter jeg at den vil falle.
Endret av member-101642
Eltek har vell bare blitt den nye daytrader-hypen på OSE så derfor den går så mye. Tror ikke det fundamentale har så mye å si inntill populariteten på denne avtar. Forsåvidt interessant å se hvordan børs og psykologi fungerer.
Angående inflasjon:
The main question is when will inflationary expectations begin to rise causing a new stage of a gold bull market? The best answer we can give is as follows:
The lag between monetary expansion and price inflation in the United States is about 3.5 years. The Fed started bloating its balance sheet about a year ago. Therefore, price inflation could really begin showing its teeth toward 2012. However, inflation expectations are a different animal. In the context of a major concern for fiscal sustainability and a prolonged period of elevated money supply by the Fed, inflation expectations can explode much earlier. It is quite possible that this could happen as early as next year.
Tatt fra: What will it take for gold to overcome $1000
For å forklare det slik jeg tenker. Spesielt etter 1982 fikk den amerikanske økonomien fart på seg. Det var lett å sette igang økonomien etter 1987, da konsumentene bare tok opp mer gjeld. Det samme etter 1991, men etter 2003 var det tungt å få økonomien igang igjen. Mengden gjeld på alle felter var alt for stor, men med en irak krig, og krig mot terror kom det igang igjen. Denne gangen tror jeg det er enda tyngre. Det betyr at en større kraft enn ved noen av de tidligere tilbakeslagene etter 1982 må til for å få det til å vokse igjen. Det må til så mye pengetrykking og stimulering at jeg tror det blir nærmest umulig å ikke ta i for hardt.
Synes det vangles mye mellom inflasjon og deflasjon. Annenhver uke inflaslon/deflasjon. Hva blir det til oghvor skal en putte pengene? Hvis det blir deflasjon så er det jo bare å putte de i banken.
Dette lurer jeg også egentlig på. Det er mye snakk om inflasjon/deflasjon om dagen, men akkurat hvor man skal gjøre av pengene i slike stuasjoner, skjønner jeg ingenting av.
Jada jeg vet at en med mine økonomikunnskaper aldri burde ha satt en eneste krone på børs. :!:
Hvis man putter for mye penger inn i økonomien i form av krisepakker vil inflasjon være et sannsynlig scenario, mens hvis det viser seg at de krisepakkene som har blitt gitt ikke er virkningsfulle nok til å stable på beina en levedyktig oppgang, vil dette kunne føre til at oppgangen forsvinner igjen og vi går tilbake igjen til dårligere tider. Man har vel ikke helt oversikten over hvor virkningsfulle krisepakkene er helt ennå, og man vet heller ikke om det vil bli gitt flere krisepakker fremover, derfor er det per idag vanskelig å forutsi hvilken av scenarioene som vil slå til.
