Unresolved external symbol, trenger litt hjelp
Heisann, det er en stund siden sist jeg kodet c++, og har litt problemer med linkingen.
Kan noen hjelpe meg litt her?
Feilmelding:
Linking...
Peer2PeerDlg.obj : error LNK2019: unresolved external symbol "public: void __thiscall Packet::setData(class CBuffer)" (?setData@Packet@@QAEXVCBuffer@@@Z) referenced in function "public: void __thiscall CPeer2PeerDlg::OnBnClickedButton1(void)" (?OnBnClickedButton1@CPeer2PeerDlg@@QAEXXZ)
Peer2PeerDlg.obj : error LNK2019: unresolved external symbol "public: void __thiscall Packet::setHeader(class Header)" (?setHeader@Packet@@QAEXVHeader@@@Z) referenced in function "public: void __thiscall CPeer2PeerDlg::OnBnClickedButton1(void)" (?OnBnClickedButton1@CPeer2PeerDlg@@QAEXXZ)
Utdrag av kode som gir feil:
head.setType(1);
head.setfileName(myFile.GetFileName());
head.setLength(nFileLength);
pakken.setHeader(head);
while ( nReadBytes < nFileLength)
 nReadBytes += myFile.Read(&szBuffer, 1);
pakken.setData(szBuffer);
Packet.hpp:
#pragma once
//Packet.hpp
#include "Header.h"
#include "Buffer.h"
class Packet
public:
Packet(void);
Header getHeader();
CBuffer getData();
void setHeader(Header);
void setData(CBuffer);
public:
virtual ~Packet(void);
private:
Header head;
CBuffer data;
Packet.cpp:
#include "stdafx.h"
#include "Packet.h"
#include "Header.h"
#include "Buffer.h"
Header head;
CBuffer data;
Packet::Packet(void)
head.setType(0);
head.setLength(0);
head.setfileName("");
data.ClearBuffer();
Packet::~Packet(void)
Header getHeader(){
return head;
CBuffer getData(){
return data;
void setHeader (Header h ){
head = h;
void setData(CBuffer buf){
data = buf;
Og header.hpp:
#pragma once
class Header
public:
Header(void);
char getType();
int getLength();
CString getfileName();
void setType(char);
void setLength(int);
void setfileName(CString);
public:
virtual ~Header(void);
private:
char type;
int length;
CString fileName;
header.cpp:
#include "stdafx.h"
#include "Header.h"
#include "Buffer.h"
Header::Header(void)
type = 0;
length = 0;
fileName.SetString("");
Header::~Header(void)
char Header::getType(){
return type;
int Header::getLength(){
return length;
CString Header::getfileName(){
return fileName;
void Header::setType(char t){
type = t;
void Header::setLength(int len){
length = len;
void Header::setfileName(CString fn){
fileName.SetString(fn);
Endret av Mr Burns
Linking...
Dette betyr at linkeren (som kjøres etter kompilatoren, og enkelt sagt har ansvaret for at nødvendig kode ender opp i den ferdigproduserte filen) ikke er i stand til å finne funksjonene Packet::setData og Packet::setHeader. Hvis du kikker på Packet.cpp, så finner du forklaringen:
Packet.cpp:
#include "stdafx.h"
#include "Packet.h"
#include "Header.h"
#include "Buffer.h"
Header head;
CBuffer data;
head.setType(0);
head.setLength(0);
data.ClearBuffer();
Header getHeader(){
return head;
CBuffer getData(){
return data;
head = h;
data = buf;
[/code]
7678908[/snapback]
Her mangler du klassenavnet i funksjonsdefinisjonene.
void setHeader skal være void Packet::setHeader, og setData, getDate, getHeader må navngis på samme måte. Poenget er rett og slett at du her skal definerer funksjoner som er deklarert i klasser, mens du definerer globale funksjoner i stedet. Når linkeren kikker etter definisjonen for f.eks. setHeader, som er referert et annet sted i koden din, finner den ingenting. Det eneste den derfor kan gjøre, er å spytte ut en feilmelding :)
7678998[/snapback]
Doh!
Takk skal du ha! Burde sett den selv... :blush:
