// Creates and initializes a new ArrayList.
     ArrayList myAL = new ArrayList();
     myAL.Add("Hello");
     myAL.Add("World");
     myAL.Add("!");
     // Displays the properties and values of the ArrayList.
     Console.WriteLine( "myAL" );
     Console.WriteLine( "    Count:    {0}", myAL.Count );
     Console.WriteLine( "    Capacity: {0}", myAL.Capacity );
     Console.Write( "    Values:" );
     PrintValues( myAL );
  public static void PrintValues( IEnumerable myList )  {
     foreach ( Object obj in myList )
        Console.Write( "   {0}", obj );
     Console.WriteLine();
Kan noen forklare meg hva {0} i denne koden betyr?
Litt vanskelig å google ;-)
Endret av cub71
Console.WriteLine Method (String, Object, Object)
This method uses the composite formatting feature of the .NET Framework to convert the value of an object to its text representation and embed that representation in a string. The resulting string is written to the output stream.
The format parameter consists of zero or more runs of text intermixed with zero or more indexed placeholders, called format items, that correspond to an object in the parameter list of this method. The formatting process replaces each format item with the text representation of the value of the corresponding object.
The syntax of a format item is {index[,alignment][:formatString]}, which specifies a mandatory index, the optional length and alignment of the formatted text, and an optional string of format specifier characters that govern how the value of the corresponding object is formatted.
http://msdn2.microsoft.com/en-us/library/aakt1eab.aspx
