konvertering fra fat32 til ntfs
Ja, det kan skje. Når du formaterer får du 4kB cluster, men ved konvertering er det mulig at du får 512 Byte. Da blir det mange flere operasjoner per fil, og dermed tregere.
Vil alltid anbefale formatering framfor konvertering.
When you are using the Convert.exe utility to convert to NTFS, Windows always uses a 512-byte cluster size.
http://support.microsoft.com/kb/140365
The NTFS disc was achieved by a conversion of FAT16/FAT32 partition. (the command convert). This procedure will lead to high fragmentation of the NTFS system area. You should avoid conversion of other system in NTFS.
http://www.digit-life.com/articles/ntfs/index3.html
