Guitar Hero-kontroller og PS3
alkymist
Vet at det ligger litt frem i tid siden PS3 ikke er lansert her til lands enda men kanskje noen som har importert fra USA kan svare....
Noen som har prøvd om det går an å koble gitaren fra Guitar Hero til PS3 hvis man bruker en overgang tilsvarende den man kan bruke for å koble en PS2 kontroller til PC? Wikipedia nevner at man kunne koble en vanlig PS2 kontrolller til PS3 på denne måten, men er det noen som har pøvd med Guitar Hero gitaren?
Eventuelt om en trådløs Guitar Hero Gitar vil være kompatibel med både PS2 og PS3?
mvh Øystein
Endret av alkymist
November 10, 2006 - If you plan on picking up a PlayStation 3 anytime soon and are worried about the dent that the system and its peripherals will put in your wallet, you may want to consider picking up some USB adapters for the PS2's Dual Shock 2 controller. These relatively cheap adapters are made for using a Dual Shock 2 on a PC, but they seem to work quite well with every PlayStation 3 game that we've tried. You need to switch on the analog button when you plug them in and they're missing the PlayStation button that brings up the Cross Media Bar, but other than that they seem perfectly functional.
With that, we assumed that Guitar Hero and its sequel would work perfectly well on the PlayStation 3. Unfortunately, that doesn't seem to be the case. When you pop in a PS2 or PSone game, you're prompted to tap the PlayStation button on the controller. For what reason, we're not sure, but as Guitar Hero's SG controller doesn't have this button, you can't actually activate it. You also can't quick-swap from one controller to another as the second part of the problem lies in that you need to turn on analog control, but again, the SG guitar doesn't have an on/off button for analog play.
Yes, this sucks. Yes, we really hope someone releases an adapter sometime soon.
