Formattering av disk fra DVD/HDD-recorder
Kjære hardwareguruer.
Jeg har ved flere anledninger "kapret" disker på 160Gb fra defekte recordere, som nevnt i emnetittelen.
Helt konkret, dreier dette seg om WD-disker med betegnelsen WD1600BB.
Ved tilkobling via USB-adapter blir disken gjenkjent i XP, men ved forsøk på formattering får jeg utelukkende beskjed om å sette inn en disk(?) i stasjonen.
Er det slik at disse diskene er såpass "hardt" linket opp mot spillerne, at de ikke lar seg behandle på vanlig måte?
Kan huske ifra min DOS-tid at det var ett eller annet triks rundt lavformattering, men har glemt hva dette innebærer. :blush: Vil dette være en løsning, og i så fall hvordan gjennomføre dette?
Takker for alle svar! :)
Ville i første omgang lastet ned et diagnoseprogram fra WD og prøvd ut formateringsfunksjonen der.
Kanskje dette også kan være til hjelp. Har ikke prøvd dette selv.
Ang low level-formattering:
User instigated low-level formatting of hard disks was common in the 1980s. Typically this involved setting up the MFM pattern on the disk, so that sectors of bytes could be successfully written to it. With the advent of RLL encoding, low-level formatting grew increasingly uncommon, and most modern hard disks are embedded systems, which are low-level formatted at the factory and thus not subject to user intervention.
Early hard disks were quite similar to floppies, but low-level formatting was generally done by the BIOS rather than by the operating system. This was a fairly bizarre process that involved using the MS-DOS debug program to transfer control to a routine hidden at different addresses in different BIOSs.
Starting in the early 1990s, low-level formatting of hard drives became more complex as technology improved to:
    * use RLL encoding,
    * store a higher number of sectors on the longer outer tracks (traditionally, all tracks had the same number of sectors, as is still the case with floppy disks),
    * encode track numbers into the disk surface to simplify hardware, and
    * increase the mechanical speeds of the drive.
Rather than face ever-escalating difficulties with BIOS versioning, disk vendors started doing low-level formatting at the factory. Today, an end-user, in most cases, should never perform a low-level formatting of an IDE or ATA hard drive; disk reinitialization of an IDE or ATA hard drive is much more common.
Mer info om akkurat dette finner du her.
Det er antagelig bare nødvendig å fjerne partisjonstabellen, lage ny partisjon, og så formatere.
Det finnes et utall programmer som kan håndtere partisjoner. Det mest nærliggende å bruke er Diskbehandling i Windows.
Det man kaller low-level formatering er i dag bare å skrive nuller til alle sektorer på disken. Da fjernes alt, også partisjonstabellen.
