Snagaaa Skrevet 2. januar 2007 Del Skrevet 2. januar 2007 Hei, siden jeg ikke fant noe annet sted å poste dette så poster jeg det her. Jeg vet ikke om det er noen som har svar på det, men hvem vet. Hvis ikke hadde det vært fint om noen kunne gi en link til et forum eller noe der jeg kunne ha postet det. Jeg skrev det først på engelsk, men jeg regner med at de fleste kan det så: Hello. At the moment I am making a movie using World of Warcraft clips. I'm using 'Fraps' to gather material. Some days ago when I wanted to render my movie to see how it was looking like, an error appared. It was this windows error: "This program has performed an illegal task etc.." Well, this is pretty usual I thought and tried again. I rebooted, I reinstalled vegas, I deleted all files having anything to do with vegas. And still it wouldn't work. Now I figured out that the problem is the files that are to be rendered. It's pretty strange 'cause I've rendered the SAME files just before, and now it's not working. I tried to delete a specific file in the project, and put it in again, but still it's not working. I've put a lot of work into this, so to replace all files and edit them again would be a waste and take huge amount of time. Later on, after several tries I get this Sony Vegas error instead. It sounds like: "Sony Vegas 6.0 Version 6.0c (Build 153) Exception 0xC0000005 (access violation) READ:0x18 IP:0x5D5367 In Module 'vegas60.exe' at Address 0x400000 + 0x1D5367 Thread: GUI ID=0xAF4 Stack=0x12D000-0x130000 Registers: EAX=00000000 CS=001b EIP=005d5367 EFLGS=00250206 EBX=59d99008 SS=0023 ESP=0012de34 EBP=00000000 ECX=5d7cd578 DS=0023 ESI=5d7cd578 FS=003b EDX=0000008b ES=0023 EDI=59d99008 GS=0000 Bytes at CS:EIP: 005D5367: FF 50 18 8B 16 8B CE 8B .P...... 005D536F: F8 FF 52 14 57 8B D8 E8 ..R.W... Stack Dump: 0012DE34: 59D99008 59770000 + 629008 0012DE38: 00000000 0012DE3C: 59D99008 59770000 + 629008 0012DE40: 0066A8E2 00400000 + 26A8E2 (vegas60.exe) 0012DE44: 59D99008 59770000 + 629008 0012DE48: 00000000 0012DE4C: 59D99008 59770000 + 629008 0012DE50: 00000040 0012DE54: 00000000 0012DE58: 00000000 0012DE5C: 00000000 0012DE60: 00000000 0012DE64: 00000000 0012DE68: 00000000 0012DE6C: 00000000 0012DE70: 00000000 > 0012DE74: 004742F7 00400000 + 742F7 (vegas60.exe) 0012DE78: 00000001 0012DE7C: 00000000 0012DE80: 59D99008 59770000 + 629008 0012DE84: 2F5F5540 2F590000 + 65540 > 0012DE98: 004B1DBB 00400000 + B1DBB (vegas60.exe) 0012DE9C: 59D99008 59770000 + 629008 0012DEA0: 00000040 0012DEA4: 00000000 0012DEA8: 0012DEF0 00030000 + FDEF0 > 0012DEF4: 77D3F0F6 77D30000 + F0F6 (USER32.dll) > 0012DF00: 498AF16A 49500000 + 3AF16A (h264vout.003) > 0012DF18: 00474549 00400000 + 74549 (vegas60.exe) 0012DF1C: 00000040 0012DF20: E90110C4 0012DF24: 2F5F5540 2F590000 + 65540 0012DF28: 0012E170 00030000 + FE170 > 0012DF2C: 77D3F076 77D30000 + F076 (USER32.dll) > 0012DF60: 77D3DDDC 77D30000 + DDDC (USER32.dll) > 0012DF88: 77D3DDF7 77D30000 + DDF7 (USER32.dll) > 0012DFC4: 77F53020 77F10000 + 43020 (GDI32.dll) > 0012DFE4: 77D38CC3 77D30000 + 8CC3 (USER32.dll) > 0012DFE8: 0053004D 00400000 + 13004D (vegas60.exe) > 0012DFEC: 00530020 00400000 + 130020 (vegas60.exe) - - - 0012FFF0: 00000000 0012FFF4: 00000000 0012FFF8: 0088CD0C 00400000 + 48CD0C (vegas60.exe) 0012FFFC: 00000000 " Regards, Simen Lenke til kommentar
Torbjørn T. Skrevet 2. januar 2007 Del Skrevet 2. januar 2007 (endret) Du vil finne Videoredigering og video under Digital foto og video (eg rapporterte tråden, so den vert nok flytta snart). Av utanlandske fora kan du prøve Vegas-forumet på Sonymediasoftware.com, DVInfo.net og Creativecow.net. Søkte litt, og fann mellom anna denne tråden på DVinfo. Eit av forslaga der er å kopiere alt på tidslinja og lime det inn i eit anna prosjekt, for so å rendre frå det. Står at du må ha to Vegas-vindauge køyrande samtidig. Andre trådar frå andre fora er denne om DVD Architect, der det vert anbefala å kontakte kundeservice, og denne som seier at om du bruker Debugmode Wax og får problem, so kan det hjelpe å skru av maskinvareakselerasjon (hardware acceleration). I tillegg denne sida, som omhandlar ein liknande feil generelt for Windows XP. Redigert: Har du vurdert oppgradering til Vegas 7.0c? Endret 2. januar 2007 av incanus Lenke til kommentar
Snagaaa Skrevet 2. januar 2007 Forfatter Del Skrevet 2. januar 2007 Takk for svar! Eit av forslaga der er å kopiere alt på tidslinja og lime det inn i eit anna prosjekt, for so å rendre frå det. Står at du må ha to Vegas-vindauge køyrande samtidig. 7622673[/snapback] Har allerede prøvd dette, men skal sjekke ut det andre du postet. Redigert: Har du vurdert oppgradering til Vegas 7.0c? Har faktisk ikke tenkt så mye på det. Kanskje jeg skal teste det ut. Takk igjen :> Lenke til kommentar
Torbjørn T. Skrevet 2. januar 2007 Del Skrevet 2. januar 2007 Den tråden frå DVinfo var forresten på fem sider, og eg skumlas berre den fyrste, so det kan vere det står meir der. Og om du på Sony-forumet søker etter Exception 0xC0000005 (access violation) rendering får du opp ein god del trådar, so der kan det vere noko. Lenke til kommentar
