problem med wine + evolvEd (ubuntu)
heiho mine trofaste forumtroll! :w00t:
driver og skal installere evolvEd igjen nå, for jeg savna den så mye fra windows :p installeringa gikk fint, men støter på noen problmer nå :/
første problem jeg fikk: fikk error om at jeg mangla MSVBVM60.dll.. greit nok, den har jeg skaffa, og får ikke den meldingen lengre.
men når jeg prøver å starte opp nå får jeg: runtime error '380' - invalid property value (fra evolvEd)
og jeg får(warning MYE text!)
Klikk for å se/fjerne innholdet nedenfor
Xlib: extension "XFree86-DRI" missing on display ":1.0".
fixme:ole:CoRegisterMessageFilter message filter has been registered, but will not be used
fixme:ole:OleLoadPictureEx (0xa11af4,12870,0,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x33f714), partially implemented.
fixme:richedit:RichEditANSIWndProc EM_SETTARGETDEVICE: stub
fixme:richedit:RichEditANSIWndProc WM_STYLECHANGING: stub
fixme:richedit:RichEditANSIWndProc WM_STYLECHANGED: stub
fixme:richedit:IRichEditOle_fnInPlaceDeactivate stub 0xc231c0
fixme:ole:OleLoadPictureEx (0xa1bad4,2246,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x33f330), partially implemented.
fixme:ole:OleLoadPictureEx (0xa1bad4,2246,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x33f300), partially implemented.
fixme:ole:OleLoadPictureEx (0xa1bad4,2246,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x33f2d0), partially implemented.
fixme:ole:OleLoadPictureEx (0xa1bad4,3136,1,{7bf80980-bf32-101a-8bbb-00aa00300cab},x=0,y=0,f=0,0x33f2d0), partially implemented.
fixme:ole:OLEPictureImpl_SaveAsFile (0x16b068)->(0x212858, 0, (nil)), hacked stub.
fixme:richedit:ME_StreamOutFlush Invalid returned written size *pcb: 0xdeadbeef (-559038737) instead of 0
fixme:ole:OLEPictureImpl_FindConnectionPoint no connection point for {33ad4ed2-6699-11cf-b70c-00aa0060d393}
fixme:ole:OLEPictureImpl_FindConnectionPoint no connection point for {33ad4f92-6699-11cf-b70c-00aa0060d393}
fixme:richedit:IRichEditOle_fnInPlaceDeactivate stub 0xc23a18
i terminal(vet ikke helt om jeg trengte å poste det der, men gjorde det for sikkerthets skyld ;) )
noen som kan hjelpe meg og fikse problemet? :) savner gode gammle evolvEd editoren min :(
Endret av ZeS
Kansje finne tilsvarende program for Linux?
7621034[/snapback]
jeg vil ha EVOLVED! ingenting anna.. den editoren er i en klasse for seg selv..
plus: jeg har allerede en backup løsning om ingen gidder hjelpe meg fikse det
Endret av ZeS
Vel, WINE gir ingen garantier for at noe som helst fra Windows vil fungere. Sørg iallefall for at du bruker siste versjon av WINE. Hvis programmet ikke fungerer gjennom WINE er det egentlig ikke så mye å gjøre.
Om du får programmet til å fungere så er det heller ingen garantier for at programmet vil fungere ved en oppdatering eller lignende.
7621034[/snapback]
7621268[/snapback]
Hvis du skal ha den innstillingen kan du bare glemme linux.
Endret av roberth1990
Du kommer til å måtte lære deg en skikkelig teksteditor for GNU/Linux om du har planer om å lære deg litt av systemet... Vel, bør. Jeg foretrekker jeg vim(evt. i form av gvim), men det er flere gode alternativer å se på. Vim kan virke sært at first(samme gjelder Emacs), men så snart du er inne i tastekombinasjoner og slikt kommer du til å se at det hjelper deg til å jobber raskere. Nå kjenner ikke jeg evolved, men det finnes fabelaktige verktøy for GNU/Linux as well, og det er virkelig verdt å ta en titt på dem. Du kan kjøre "vimtutor" i terminal for å få en introduksjon til hvordan vim fungerer.
7621034[/snapback]
7621268[/snapback]
7622386[/snapback]
helt enig
7621034[/snapback]
7621268[/snapback]
7622386[/snapback]
helt enig
7624138[/snapback]
sorry om folk fortsto meg helt feil der, men jeg posta ikke her og spurte om hjelp fordi jeg ville ha forslag til et annet program.. jeg har et alternativ i bakhånd, men jeg prøver å få det programmet jeg har brukt lenge(og som jeg kjenner bedre enn alle andre programmer) til å funke.. hvorfor lære seg et nytt program om jeg kan få det programmet jeg kan til å funke? så om ingen er interesert i å hjelpe med å få det til å funke, kan moderator gjerne stenge/slette denne tråden.
-ZeS-
edit: om jeg ville ha forslag til et annet program hadde jeg laget en post som heta noe som "trenger forslag til annen webeditor".......
Endret av ZeS
