Registeret har brukt opp tildelt plass?
Bumbumb. Nå fikk jeg den igjen uten å starte windows på nytt.
Den nesten nøyaktige melding er: registeret har nådd maksimum system plass eller noe sånt. Ytterligere informasjon vill ikke bli lagret.
Ingen som har peil på hvordan dette kan fikses?
Det er relativt skjeldent dette dukker opp .
ERROR_REGISTRY_QUOTA_LIMIT
613 {Low On Registry Space} The system has reached the maximum size allowed for the system part of the registry. Additional storage requests will be ignored.
Registry'en din trenger å kompakt(eres) enten pga faktisk mis rapprotert
størrelse eller at det er for mye "white space" .
NTREGOPT vil fikse dette for deg.
http://www.softpedia.com/get/Tweak/Registr.../NTRegOpt.shtml
You should use the NTREGOPT utility regularly, but especially after installing or uninstalling a program, to minimize the size of the registry files and optimize registry access.
The program works by recreating each registry hive "from scratch",
thus removing any slack space that may be left from previously
modified or deleted keys.
Note that the program does NOT change the contents of the registry in
any way, nor does it physically defrag the registry files on the drive
(as the PageDefrag program from SysInternals does).
The optimization done by NTREGOPT is simply compacting the registry hives to the minimum size possible.
