Kan ikke skrive på cd-rw med cdrecord.
glabba
Jeg har problemer med å skrive på cdrw-plater med cdrecord v1.11a19 under Gentoo linux. Skriveren er en Sony CD-RW CRX145E. Har søkt litt rundt på groups.google.com, uten videre hell.
Jeg kjører følgende kommando som root: cdrecord -v speed=4 dev=0,0,0 -data iRiver.iso. Dette går helt fint på vanlige cdr, men når jeg prøver å skrive på cdrw-er får jeg følgende utskrift (mye lesing):
Cdrecord 1.11a19 (i686-pc-linux-gnu) Copyright © 1995-2002 Jörg Schilling
TOC Type: 1 = CD-ROM
scsidev: '0,0,0'
scsibus: 0 target: 0 lun: 0
Linux sg driver version: 3.1.23
Using libscg version 'schily-0.6'
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 1
Vendor_info : 'SONY '
Identifikation : 'CD-RW CRX145E '
Revision : '1.0b'
Device seems to be: Generic mmc CD-RW.
Using generic SCSI-3/mmc CD-R driver (mmc_cdr).
Driver flags : SWABAUDIO
Supported modes: TAO PACKET SAO SAO/R96R RAW/R96R
Drive buf size : 4183808 = 4085 KB
FIFO size : 4194304 = 4096 KB
Track 01: data 529 MB
Total size: 608 MB (60:14.32) = 271074 sectors
Lout start: 608 MB (60:16/24) = 271074 sectors
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 3
Reference speed: 6
Is not unrestricted
Is erasable
Disk sub type: High speed Rewritable (CAV) media (1)
ATIP start of lead in: -11240 (97:32/10)
ATIP start of lead out: 359849 (79:59/74)
speed low: 4 speed high: 8
power mult factor: 1 5
recommended erase/write power: 5
A2 values: 26 B2 4A
Disk type: Phase change
Manuf. index: 27
Manufacturer: Prodisc Technology Inc.
Blocks total: 359849 Blocks current: 359849 Blocks remaining: 88775
Starting to write CD/DVD at speed 4 in write mode for single session.
Last chance to quit, starting real write in 0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Performing OPC...
Starting new track at sector: 0
Track 01: 0 of 529 MB written.cdrecord: Input/output error. write_g1: scsi sendcmd: no error
CDB: 2A 00 00 00 00 00 00 00 1F 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 12 00 00 00 00 27 00 00 00
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x27 Qual 0x00 (write protected) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.007s timeout 40s
write track data: error after 0 bytes
Sense Bytes: 70 00 00 00 00 00 00 12 00 00 00 00 00 00 00 00 00 00
Writing time: 5.057s
Fixating...
cdrecord: Input/output error. close track/session: scsi sendcmd: no error
CDB: 5B 00 02 00 00 00 00 00 00 00
cmd finished after 0.008s timeout 480s
Fixating time: 0.011s
cdrecord: fifo had 64 puts and 1 gets.
cdrecord: fifo was 0 times empty and 0 times full, min fill was 100%.
Noen som kan være til hjelp? Selv har jeg ikke peiling.
Edit: Code-tag ble ikke bra.
[ Denne Melding var redigert av: glabba på 2002-11-23 23:35 ]
