PS3 Blu Ray vs Xbox 360 HD-DVD vs DVD
Men å regne ps3 med i salgstall for blu-ray blir vel noe feil, da man ikke kan vite om de som kjøper i det hele tatt bryr seg om det. Om noen kjøper 360 addonen så VET man at det er for å kjøpe og se hddvd film.
Har uansett en følelse av at vi ikke vil se noen klar "taper" i "krigen". Vedder min venstre stein på at begge kommer til å eksistere i all overskuelig fremtid.
7704351[/snapback]
Hvorfor selger blu-ray filmer bedre enn hd dvd filmer da?
Ok. Her er teksten fra kilden til itavisen, og den samme kilden som du oppgir.
CES 2007: HD DVD versus Blu-ray - The porn industry says HD DVD
Aaron McKenna January 11, 2007 12:39
Las Vegas (NV) - Knowing their audience quite well, the adult entertainment industry holds their annual get together in Las Vegas to coincide with the CES. There is also a very pertinent crossover between the adult and tech industries - porn has a tendency to drive, and be driven, by technology. Which means HD DVD when it comes to high-def.
Quite famously in the war between Betamax and VHS the latter won especially because the adult industry preferred it. If you've been around long enough, you probably remember that the very early home video rental stores were primarily responsible for driving Betamax out of the market. And those stores carried almost exclusively pornographic content.
Although the market environments from then do not really compare to today's home video market, parallels are drawn between the Betamax-VHS battle to the ongoing and escalating fight between Blu-ray and HD DVD. One of the key questions at this year's CES actually is "Which high-def format will win the current format war - Blu-ray or HD DVD?" Surprisingly, it seems that there is no such question in the minds of the adult industry luminaries.
Putting myself through the arduous trek through the floor of the adult expo I did a quick straw poll on, the virtues of HD DVD versus Blu-ray, and the answer from a dozen companies, big and small, including Pink Visual and Bangbros editor-in-chief, is going into a single direction: HD DVD is the preferred format. Period.
One of the big problems they have with Blu-ray is its expense, followed by its market share. "Blu-ray has superior quality, yes," said a spokesperson for porn studio Bangbros, "but HD DVD is easier to produce, cheaper to produce and there are more HD DVD players in homes than there are Blu-ray players, for example in the Xbox 360."
Pink Visual heavily complained about the fact that Blu-ray discs cannot be replicated and a range of other studios, who did not want to be mentioned by name indicated that the cost of going with Blu-ray cancels the technology as a possible HD solution for this industry. "Only bigger studios can afford Blu-ray, and even then it's not economical," we were told.
It would seem that either Blu-ray has to do some catching up very quickly. But we got the strange feeling that HD DVD has won the format war already, at least in the porn industry.
Står ingenting om at Sony ikke vil at noen skal gi ut porno på blu-ray. Det står at de fleste utgivere av porno går for HD dvd fordi de er enklere å produsere, billigere å produsere og at det er flere HD dvd spillere enn det er blu-ray spillere, og da tok de med HD dvd add-on'en til xbox 360. Men alle vet da at med ps3 så er det mange flere blu-ray spillere en hd-dvd spillere. Og de siste salgstall viser at blu-ray selger best for tiden.
7704328[/snapback]
En ganske stor forskjell er jo at de som kjøper hd-dvd add on til 360 er interessert i HD filmer. De som kjøper PS3 er ikke nødvendigvis det.
Men alt tyder på at bluray vil vinne format krigen, da bluray har all støtte fra filmselskapene. Så lenge Bluray har såpass mange ekslusive filmselskaper skal det vel mye til at hd-dvd vinner.
Du forsvarer Sony/BD/PS3* så krampeaktig at det hele blir jo morsomt. Foreslår at du kikker på Moonhowl sitt innlegg, men det er vel ikke troverdig nok kilde for deg  :roll:
Edit: *
7704343[/snapback]
Krampeaktig? Er ikke jeg som tar fram kilder som sier at Sony nekter å ha porno på blu-ray. Vil heller høre dette i en pressemelding offisielt fra blu-ray selskapene før at jeg tror det.
Paidgeek;
Sony replication will not handle pornographic product and I think many of other major replicators have similar policies. Nothing more than that.
__________________
Sony Pictures BD Insider
Om denne personen har peiling eller ikke vet vi ikke, og han tror at mange andre major replicators som han kaller det har samme politikk. Synes de blir mye synsing og troing. Tro gjør du i kirken.
Mulig det ene formatet selger litt bedre enn det andre nå, men salget for begge formater er vel så minimalt at det ikke har noe stort å si foreløpig. Tror nok vi må vente til slutten av året før vi kan si noe mer sikkert om hvordan det utvikler seg.
7704381[/snapback]
Der er jeg enig. DVD er kongen, å vil være den en god stund framover. Men mye tyder på at Blu-Ray trekker det lengste strået.
Ja bare fox som kilde hadde vært for lite, men når salgstallene fra f.eks amazon viser at det som fox sier er sant så kan jeg tro dem. Slike selskaper liker selvfølgelig å skryte seg selv og sitt format opp i skyene, akkurat som Sony, Nintendo og Microsoft, men når man ser hvor dårlig HD dvd var representert på CES så må man begynne å lure. Salgstallene til blu-ray øker mye og blu-ray har mange flere titler som kommer ut det neste halve året.
Om du ser på hdgame siden så ser du at blu-ray selger bedre og bedre, mens at salget til hd dvd ikke når nye høyder.
Endret av Mgs
Det var jaggu ikke rare forskjellene på salgstallene fra amazon, så skjønner ikke hva du skal fra til. Grafen viser jo at BD tar turen nedover!
Siden dette opprinnelig er en PS3 vs. 360 debatt, så vil jeg bare understreke konsekvensene når en vinner er kåret: Sony har lagt sin sjel (les: tid, penger) i BD-formatet. MS har bare kjøpt rettighetene og kan raskt tilpasse seg enhver situasjon. Dette er den største forskjellen. Og en av mine grunner til å ikke kjøpe PS3 når den kommer. Ihvertfall ikke på lang tid.
Edit: Nå er det på tide å ta av fanboy-brillene, Mgs. Begge formatene svinger voldsomt, og ender omtrent samme plass, enten du ser på dagen i dag, 7 dager eller 14 dager.
Endret av WonderStivi
ja, vi får bare smøre oss med tålmodighet, for det vil nok ta noe tid før vi ser hvem som vinner. Men som med spille konsoller så er det spillene som teller mest, og med blu-ray og hd dvd er det filmene som teller mest. Og her har blu-ray ett overtak.
gå inn på http://www.hdgamedb.com/amazon/history.aspx?TYPE=10, velg Comparison Type: Top 25 hddvd vs Top 25 blu-ray og velg time span: 14 days. Ser ut som en generell økning for blu-ray og en lite nedgang for hd dvd.
Endret av Mgs
ja og hva i all verden var poenget med den artikkelen? De har laget hd dvd med masse lag som ingen hd dvd linser i dag kan lese. Blu-ray holder også på med dette og har vistnok kommet til 200 GB. Poenget er vel at vi bli nok ikke å få se stort mer en dobbelt lags blu-ray og hd dvd.
Tom Adams of Adams Media Research told Dan Ackman of Forbes (article published May 25, 2001) that porn, at most, accounted for 10% of total DVD/video sales and rentals. Tom Adams said his $1.8 billion estimate of aggregate porn sales and rentals for 2000 was "generous."
De er viktig, men ikke viktigere en 10 %.
Kilde
Og om hele film industrien går for blu-ray så kommer nok pornoen etter ;)
Kilde
7704583[/snapback]
Eller når alle forbrukere går for HD-DVD så dilter nok BD leiren etter ...
Det formatet som vinner vil selvsagt tiltrekke seg resten, men trolig får vi en DVDR situasjon hvor ingen bryr seg.. uansett er codeks lik og ingen formater vil ha bedre spesifikasjoner..
7704351[/snapback]
7704355[/snapback]
Fordi Sony markedsfører Blu-ray som "Beyond High Definition" - og folk tror det. Det står jo i reklamen deres. Til og med selgeren på Elkjøp gjorde jo det. "Det er langt flere megapiksler i Blu-ray enn i HD DVD. Blu-ray er steget etter HD igjen liksom". Ble jeg fortalt. Hvilket viste hvilken innsikt han hadde om hjemmekino genrelt. hehehe.
Selvfølgelig må det komme porno på Blu-ray - jeg mener - bare navnet på mediaet skriker jo etter pupper, lår, nakenhet osv... ;)
Fordi pornoindustrien var noe med å styre VHS vs Betamax i sin tid så tror alle at det vil gjenta seg. Men det tror ikke jeg denne gangen.
Nei, porno egner seg best nedlasta i 320x240 mpeg1 kvalitet og vist i et lite vindu på monitoren med nesa nesten klemt inn i den mens kona er en tur i butikken ;)
Endret av Dr.Peedee
