Når kommer det DVD-brenner med 8-9 GB kapasitet
regn
Dagens DVD brennere kan fint brenne dobbeltsidig på DVD plater slik som disse Verbatim double-sided du får hos komplett.
Om du derimot tenkte på dual-layer slik at du får 9GB på samme side av en DVD plate så er det nok bare å skuffe deg, det kommer aldri, desverre. Så skal du kopiere en DVD film blir du enten nødt til å bruke 2 DVD plater eller du må bruke en dobbeltsidig som da blir en flipper.
Vel du kan blandt annet lese FAQen til dvdplusrw.org. Der står det blandt annet:
Quote:
Will there be discs with a higher capacity than 4.7 GB?
All normal-sized 12 centimeter DVD+R and DVD+RW discs will have a 4.7 GB capacity. DVD+RW has been designed to be compatible with existing DVD players, so creating a disc with a higher capacity than the 4.7 GB defined for DVD-Video and DVD-ROM would render these discs to be incompatible with existing players and drives. However, the DVD+R/+RW format includes support for a smaller 8 centimeter disc, which will contain about 1 GB of data. This disc will also be fully compatible with normal DVD players.
Will there double sided discs?
Yes, the DVD+R/+RW standard allows for double sided DVD+R/+RW discs, lifting the storage capacity per disc to 9 GB or up to 12 hours of video. It is doubtfull that these discs will become very popular however, since they are likely to cost more than 2 single-sided discs, and they are much harder to handle or to identify (as there is no room on the disc surface to write down its contents).
Will there be dual-layered discs?
No. DVD+RW uses mixed characteristics of single and dual layer pressed DVD-Video discs in order to be compatible with existing players, hence it will not be possible to create a DVD+RW disc with two layers. This also applies to other recordable DVD systems, such as DVD-R, DVD-RAM and DVD-RW. No current recordable DVD format will offer dual layer discs.
Du kan også se på sida til DVD Forum som står bak DVD-R
Det står da ikke der at det ikke kommer dual layer?
"No current recordable DVD format will offer dual layer discs." Det står at DVD-R DVD+R DVDRW osv ikke vil støtte duallayer, og det sier seg jo selv da det ikke ligger i standarden, men det sier ikke at det ikke kommer en DVDDLR f.eks.
