Gjest Slettet+6132 Skrevet 29. desember 2006 Del Skrevet 29. desember 2006 Måtte slå av serveren her om dagen for å flytte på den, men når jeg nå boota den ble bare 2 av 3 disker mountet. root@web:~# mount /dev/hda2 on / type ext3 (rw) proc on /proc type proc (rw) /dev/hda1 on /boot type ext3 (rw) /dev/hda4 on /files1 type ext3 (rw) /dev/hdc1 on /files2 type ext3 (rw) devpts on /dev/pts type devpts (rw,gid=5,mode=620) Her burde /dev/hdd1 bli mountet. /etc/fstab: /dev/hda3 swap swap defaults 0 0 /dev/hda2 / ext3 defaults 1 1 /dev/hda1 /boot ext3 defaults 1 2 /dev/hda4 /files1 ext3 defaults 1 2 /dev/hdc1 /files2 ext3 defaults 1 2 /dev/hdd1 /files3 ext3 defaults 1 2 /dev/cdrom /mnt/cdrom iso9660 noauto,owner,ro 0 0 /dev/fd0 /mnt/floppy auto noauto,owner 0 0 devpts /dev/pts devpts gid=5,mode=620 0 0 proc /proc proc defaults 0 0 root@web:~# fdisk -l Disk /dev/hdc: 81.9 GB, 81964302336 bytes 255 heads, 63 sectors/track, 9964 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hdc1 1 9964 80035798+ 83 Linux Disk /dev/hdd: 40.0 GB, 40060403712 bytes 255 heads, 63 sectors/track, 4870 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hdd1 1 4870 39118243+ 83 Linux Disk /dev/hda: 80.0 GB, 80026361856 bytes 255 heads, 63 sectors/track, 9729 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hda1 * 1 6 48163+ 83 Linux /dev/hda2 7 1222 9767520 83 Linux /dev/hda3 1223 1284 498015 82 Linux swap /dev/hda4 1285 9729 67834462+ 83 Linux Prøver jeg manuelt skjer dette: root@web:~# mount -t ext3 /dev/hdd1 /files3 mount: wrong fs type, bad option, bad superblock on /dev/hdd1, missing codepage or other error (could this be the IDE device where you in fact use ide-scsi so that sr0 or sda or so is needed?) In some cases useful info is found in syslog - try dmesg | tail or so dmesg | tail: root@web:~# dmesg | tail eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 hdd1: bad access: block=2, count=2 end_request: I/O error, dev 16:41 (hdd), sector 2 EXT3-fs: unable to read superblock hdd1: bad access: block=2, count=2 end_request: I/O error, dev 16:41 (hdd), sector 2 EXT3-fs: unable to read superblock hdd1: bad access: block=2, count=2 end_request: I/O error, dev 16:41 (hdd), sector 2 EXT3-fs: unable to read superblock Ut fra det jeg forstår er det en lesefeil på disken, men jeg har jo ikke gjort noe mens serveren var "død". Lenke til kommentar
A!1 Skrevet 29. desember 2006 Del Skrevet 29. desember 2006 Sikker på at disken ikke er død? Bad sectors... Lenke til kommentar
Gjest Slettet+6132 Skrevet 29. desember 2006 Del Skrevet 29. desember 2006 Den virket 100% for noen dager siden, disker pleier ikke å dø av en reboot ... forhåpentligvis. Lenke til kommentar
A!1 Skrevet 29. desember 2006 Del Skrevet 29. desember 2006 Nei, men kan ha strøket med før du rebootet (på grunn av varme eller andre ting) og så oppdager du det først når du rebooter og forsøker å montere partisjonen igjen... Lenke til kommentar
Gjest Slettet+6132 Skrevet 29. desember 2006 Del Skrevet 29. desember 2006 Jo, men /files3 er hovedlagringsplass for rtorrent (som alltid kjører), så om det hadde vært noe galt ville jeg ha merka det, alle 3 diskene er delt med samba og brukes jevnlig, er bare så rart at den plutselig ikke virker. Men mens vi er inne på det kom jeg på noe annet rart. Da jeg boota serveren kjørte BIOS-testene osv, og så stoppet det opp en stund før "LIL" kom opp på skjermen, altå LILO prøvde tydeligvis å starte, men noe hang seg opp. Etter å ha stirret på "LIL" en stund trykket jeg enter og plutselig gikk den videre, og så hang den seg på "Checking BIOS data" (eller noe lignende) før PCen boota, og etter det gikk alt som normalt. Lenke til kommentar
A!1 Skrevet 29. desember 2006 Del Skrevet 29. desember 2006 (endret) Har du prøvd å kjørt e2fsck eller badblocks da? Kjør evt e2fsck med en -c switch, så får du den til å kjøre badblocks for deg... Edit: BIOS hangups er veldig symptomatisk på harddisker med badblocks eller hvor kabelen ikke står i skikkelig... Endret 29. desember 2006 av HavarN Lenke til kommentar
Gjest Slettet+6132 Skrevet 30. desember 2006 Del Skrevet 30. desember 2006 root@web:~# e2fsck -c /dev/hdd e2fsck 1.35 (28-Feb-2004) Couldn't find ext2 superblock, trying backup blocks... e2fsck: Bad magic number in super-block while trying to open /dev/hdd The superblock could not be read or does not describe a correct ext2 filesystem. If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> Starta badblocks /dev/hdd etter du posta innlegget ditt og serveren går på 100% cpu om jeg ikke tar feil, ingenting svarer. Lenke til kommentar
A!1 Skrevet 30. desember 2006 Del Skrevet 30. desember 2006 Jeg tror du egentlig skal kjøre e2fsck og badblocks mot partisjonen og ikke disken... /dev/hdd1 http://man.he.net/man8/e2fsck Lenke til kommentar
Gjest Slettet+6132 Skrevet 30. desember 2006 Del Skrevet 30. desember 2006 (endret) root@web:~# e2fsck /dev/hdd1 e2fsck 1.35 (28-Feb-2004) e2fsck: Invalid argument while trying to open /dev/hdd1 The superblock could not be read or does not describe a correct ext2 filesystem. If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> root@web:~# badblocks /dev/hdd1 badblocks: bad blocks range: 0-0 Funka ikke noe særlig bedre. Flaks at jeg ikke har noe viktig på den disken da Endret 30. desember 2006 av Slettet+6132 Lenke til kommentar
Gjest Slettet+6132 Skrevet 1. januar 2007 Del Skrevet 1. januar 2007 Harddisken lar seg fortsatt ikke mounte, noen som har flere forslag? Lenke til kommentar
BarteBaluba Skrevet 1. januar 2007 Del Skrevet 1. januar 2007 Et lite tips: ikke legg swap først til i fstab, linux mounter alle partisjonene/harddiskene i ftsba i den rekkefølgen de ligger i, har hatt erfaring med dette selv som har endt med knekkt installasjon. Lenke til kommentar
olear Skrevet 1. januar 2007 Del Skrevet 1. januar 2007 Har alltid SWAP først, ingen problemer her. Lenke til kommentar
