{Løst} Trojaner, rpcc.dll - med HJT logg *utvidet*
Brute Force Uninstaller logg:
Klikk for å se/fjerne innholdet nedenfor
BFU v1.00.9
Windows XP SP2 (WinNT 5.01.2600 SP2)
Script started at 22:58:29, on 06-12-30
Failed: DllUnregister C:\WINDOWS\DH.dll|1 (file not found)
Failed: DllUnregister C:\Programfiler\Deskbar\deskbar.dll|1 (file not found)
Failed: DllUnregister \asappsrv.dll|1 (file not found)
Failed: DllUnregister \MyToolBar.dll|1 (file not found)
Failed: DllUnregister \888Bar.dll|1 (file not found)
Failed: ServiceStop Network Monitor (service not found)
Failed: ServiceStop cmdService (service not found)
Failed: ServiceDisable Network Monitor (service not found)
Failed: ServiceDisable cmdService (service not found)
Failed: ServiceDelete Network Monitor (service not found)
Failed: ServiceDelete cmdService (service not found)
Failed: RegDelValue HKCU\System\CurrentControlSet\Control\Lsa|p2pnetwork (key not found)
Failed: RegDelValue HKCU\Microsoft\Windows\CurrentVersion\policies\Explorer\Run|WinUpdate.exe (key not found)
Option pause between commands: 300 ms
Option pause between commands: 50 ms
Failed: FolderDelete C:\Programfiler\MsConfigs (folder not found)
Failed: FolderDelete C:\Programfiler\winupdates (folder not found)
Failed: FolderDelete C:\Programfiler\winupdate (folder not found)
Failed: FolderDelete C:\Programfiler\winsupdater (folder not found)
Failed: FolderDelete C:\Programfiler\MsMovies (folder not found)
Failed: FolderDelete C:\Programfiler\wmplayer (folder not found)
Failed: FolderDelete C:\Programfiler\outlook (folder not found)
Failed: FileDelete C:\Programfiler\Common Files\mc-*-*.exe (operation failed)
Failed: FileDelete C:\Programfiler\Common Files\Windows\mc-*-*.exe (operation failed)
Failed: FileDelete C:\Programfiler\Common Files\Download\mc-*-*.exe (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-1033-*-*}\update.exe (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-1033-*-*}\services.dll (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-1033-*-*}\activate.exe (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-1033-*-*}\MyToolBar.dll (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-2057-*-*}\update.exe (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-2057-*-*}\services.dll (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-2057-*-*}\activate.exe (operation failed)
Failed: FileDelete C:\Programfiler\common files\{*-*-2057-*-*}\MyToolBar.dll (operation failed)
Failed: FolderDelete C:\Programfiler\toolbar888 (folder not found)
Failed: FolderDelete C:\Programfiler\e-mailpaysu toolbar (folder not found)
Failed: FolderDelete C:\Programfiler\EMUSIC TOOLBAR (folder not found)
Failed: FolderDelete C:\Programfiler\find dvd toolbar (folder not found)
Failed: FolderDelete C:\Programfiler\GULESIDER VERKTøYLINJE (folder not found)
Failed: FolderDelete C:\Programfiler\sesam-p4 toolbar (folder not found)
Failed: FolderDelete C:\Programfiler\slownik ling (folder not found)
Failed: FolderDelete C:\Programfiler\MediaPipe (folder not found)
Failed: FolderDelete C:\Programfiler\p2pnetworks (folder not found)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\Perflib_Perfdata_d4.dat (operation failed)
Failed: FolderDelete C:\DOCUME~1\Server\LOKALE~1\Temp\Ultra$ISO (operation failed)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DF5289.tmp (operation failed)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DFB4B6.tmp (operation failed)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DFEDD3.tmp (operation failed)
Failed: FolderDelete C:\Documents and Settings\Server\Lokale innstillinger\Temporary Internet Files\Content.IE5\4PKX2JOD (operation failed)
Failed: FolderDelete C:\Documents and Settings\Server\Lokale innstillinger\Temporary Internet Files\Content.IE5\4T2RWT2V (operation failed)
Failed: FolderDelete C:\Programfiler\Maxifiles (folder not found)
Failed: FolderDelete C:\Programfiler\EQAdvice (folder not found)
Failed: FolderDelete C:\Programfiler\FCAdvice (folder not found)
Failed: FolderDelete C:\Programfiler\PSCastor (folder not found)
Failed: FolderDelete C:\Programfiler\CMIntex (folder not found)
Failed: FolderDelete C:\Programfiler\PadsysAssistant (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\FreeProd1 (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\FreeProd2 (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\InetGet (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\InetGet2 (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\svchostsys (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\simtest (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\misc001 (folder not found)
Failed: FolderDelete C:\Programfiler\InetGet2 (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\VCClient (folder not found)
Failed: FolderDelete C:\Programfiler\Network Monitor (folder not found)
Failed: FolderDelete C:\WINDOWS\inet20001 (folder not found)
Failed: FolderDelete C:\Programfiler\Update06 (folder not found)
Failed: FolderDelete C:\Programfiler\Update03 (folder not found)
Failed: FolderDelete C:\Programfiler\Update04 (folder not found)
Failed: FolderDelete C:\Programfiler\Update08 (folder not found)
Failed: FolderDelete C:\Programfiler\W-Update (folder not found)
Failed: FolderDelete C:\Programfiler\Yazzle Sudoku (folder not found)
Failed: FolderDelete C:\Programfiler\Cas (folder not found)
Failed: FolderDelete C:\Programfiler\CasStub (folder not found)
Failed: FolderDelete C:\Programfiler\Cas2Stub (folder not found)
Failed: FolderDelete C:\Programfiler\ipwins (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\Snowball Wars (folder not found)
Failed: FolderDelete C:\Programfiler\folder.js (folder not found)
Failed: FolderDelete C:\Programfiler\ini.ini (folder not found)
Failed: FolderDelete C:\temp (folder not found)
Failed: FolderDelete C:\WINDOWS\mdrive (folder not found)
Failed: FolderDelete C:\WINDOWS\system32\crunner (folder not found)
Failed: FolderDelete C:\Programfiler\PECarlin (folder not found)
Failed: FolderDelete C:\Programfiler\AXVenore (folder not found)
Failed: FolderDelete C:\Programfiler\SDVita (folder not found)
Failed: FolderDelete C:\Programfiler\EQBranch (folder not found)
Failed: FolderDelete C:\Programfiler\EQArticle (folder not found)
Failed: FolderDelete C:\Programfiler\PSHope (folder not found)
Failed: FolderDelete C:\Programfiler\Batty (folder not found)
Failed: FolderDelete C:\Programfiler\Batty2 (folder not found)
Failed: FolderDelete C:\Programfiler\AXFibula (folder not found)
Failed: FolderDelete C:\Programfiler\CMFibula (folder not found)
Failed: FolderDelete C:\Programfiler\PSLister (folder not found)
Failed: FolderDelete C:\Programfiler\PSCloner (folder not found)
Failed: FolderDelete C:\Programfiler\PSDream (folder not found)
Failed: FolderDelete C:\Programfiler\cmapp (folder not found)
Failed: FolderDelete C:\Programfiler\cmman (folder not found)
Failed: FolderDelete C:\Programfiler\cmsystem (folder not found)
Failed: FolderDelete C:\Programfiler\fcengine (folder not found)
Failed: FolderDelete C:\Programfiler\wincmapp (folder not found)
Failed: FolderDelete C:\Programfiler\Deskbar\Cache (folder not found)
Failed: FolderDelete C:\Programfiler\popupwithcast (folder not found)
Failed: FolderDelete C:\Programfiler\Common Files\cloader (folder not found)
Failed: FileMove C:\WINDOWS\win*-*.exe|C:\bintheredunthat (source file not found)
Script completed.
Får ikke til Combofix enda men skal prøve noen ganger til.....
Jeg tror vi tar skriptet på en annen måte:
Kopier adressen under og lim den inn i adressefeltet i nettleseren. Kopier innholdet i notisblokk.
http://metallica.geekstogo.com/alcanshorty.bfu
Fordi skriptet er laget for engelsk versjon av WinXP, heter Fellesfiler for Common files. Kunne du ha byttet ut alle 'Common files' med 'Fellesfiler' i scriptet. Det er ikke så mange :)
Lagre skriptet på skrivebordet, kall det for f.eks. test.bfu
Start BFU igjen
Velg 'Open script files...' (mappeikonet i øvre høyre hjørne)
Du skal velge 'test.bfu'
Kjør scripet.
Endret av norbat
Ny BFU Logg:
BFU v1.00.9
Script started at 23:50:33, on 06-12-30
Option Unload Explorer: Yes
Failed: FolderDelete C:\Programfiler\MsUpdate (folder not found)
Failed: FileDelete C:\Programfiler\Fellesfiler\Windows\mc-*-*.exe (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-1033-*-*}\update.exe (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-1033-*-*}\services.dll (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-1033-*-*}\activate.exe (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-1033-*-*}\MyToolBar.dll (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-2057-*-*}\update.exe (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-2057-*-*}\services.dll (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-2057-*-*}\activate.exe (operation failed)
Failed: FileDelete C:\Programfiler\Fellesfiler\{*-*-2057-*-*}\MyToolBar.dll (operation failed)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DFB61E.tmp (operation failed)
Failed: FolderDelete C:\Programfiler\DNS (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\FreeProd1 (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\FreeProd2 (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\svchostsys (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\simtest (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\misc001 (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\VCClient (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\Snowball Wars (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\cloader (folder not found)
Failed: FolderCreate C:\bintheredunthat (folder already exists)
Script completed.
Det gikk fint det å putte inn Fellesfiler :)
Hva kommer nå da?
Kan du sjekke om du har linja (i bold) i skripet som du har laget:
FolderDelete %PROGRAMFILES%\Common Files\FreeProd1
FolderDelete %PROGRAMFILES%\Common Files\FreeProd2
FolderDelete %PROGRAMFILES%\Fellesfiler\inetget
FolderDelete %PROGRAMFILES%\Common Files\indetget2
FolderDelete %PROGRAMFILES%\Common Files\svchostsys
FolderDelete %PROGRAMFILES%\Common Files\simtest
Kan ikke se den i den siste loggen din.
Gjorde enda en ny BFU "scann":
BFU v1.00.9
Script started at 00:15:22, on 06-12-31
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DF2CEA.tmp (operation failed)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DF2CF5.tmp (operation failed)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DF9CEC.tmp (operation failed)
Failed: FileDelete C:\DOCUME~1\Server\LOKALE~1\Temp\~DF9D1C.tmp (operation failed)
Failed: FolderDelete C:\Documents and Settings\Server\Lokale innstillinger\Temporary Internet Files\Content.IE5\YL41KLWR (operation failed)
Failed: FolderDelete C:\Programfiler\Fellesfiler\InetGet (folder not found)
Failed: FolderDelete C:\Programfiler\Fellesfiler\InetGet2 (folder not found)
Script completed.
Fant den i den nye loggen men i den forrige var den ikke der :hmm: .
Kunne du forandret navnet InetGet til inetget, bare for sikkerhets skyld. Kjør skriptet. Trenger ikke å se loggen (du kan gi beskjed om det gir noen resultat ang. inetget)
Når dette er ferdig, poster du en ny HJT-logg for litt opprydding.
Hvis du har en hastighet på 1600 (isteden for 2500) er ikke det uvanlig hos telenor. :)
Endret av norbat
Den er enda i loggen så ingen forandring = Ikke funnet.....
Failed: FolderDelete C:\Programfiler\Fellesfiler\inetget (folder not found)
HJT logg nå:
Logfile of HijackThis v1.99.1
Scan saved at 00:50, on 06-12-31
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.5730.0011)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Programfiler\Java\jre1.5.0_02\bin\jusched.exe
C:\WINDOWS\system32\CTHELPER.EXE
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
C:\WINDOWS\system32\LVCOMSX.EXE
C:\Programfiler\Logitech\Video\LogiTray.exe
C:\Programfiler\SoftDisc\softdisc.exe
C:\PROGRA~1\Maxtor\OneTouch\Utils\OneTouch.exe
C:\WINDOWS\MXOALDR.EXE
C:\Programfiler\CyberLink\PowerDVD\PDVDServ.exe
C:\PROGRA~1\Grisoft\AVG7\avgcc.exe
C:\Programfiler\Winamp\winampa.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Programfiler\BMT MouseTracker\MouseTrack.exe
C:\Programfiler\Pulse\Pulse.exe
C:\Programfiler\YourWare Solutions\FreeRAM XP Pro\FreeRAM XP Pro.exe
C:\Programfiler\Microsoft Encarta\Encarta Premium DVD 2006\EDICT.EXE
C:\Programfiler\Logitech\MouseWare\system\em_exec.exe
C:\Programfiler\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\Program Files\FinePixViewer\QuickDCF2.exe
C:\Programfiler\InterVideo\Common\Bin\WinCinemaMgr.exe
C:\Programfiler\Fellesfiler\Microsoft Shared\Works Shared\wkcalrem.exe
C:\Programfiler\Logitech\Video\FxSvr2.exe
C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
C:\PROGRA~1\Grisoft\AVG7\avgrssvc.exe
C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
C:\WINDOWS\system32\bgsvcgen.exe
C:\WINDOWS\system32\CTsvcCDA.EXE
C:\WINDOWS\system32\drivers\KodakCCS.exe
C:\Programfiler\Fellesfiler\Microsoft Shared\VS7Debug\mdm.exe
C:\Programfiler\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
C:\WINDOWS\system32\MsPMSPSv.exe
C:\WINDOWS\system32\taskmgr.exe
C:\Programfiler\MSN Messenger\msnmsgr.exe
C:\WINDOWS\explorer.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\Programfiler\Internet Explorer\IEXPLORE.EXE
C:\Documents and Settings\Server\Skrivebord\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.startsiden.no/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koblinger
O2 - BHO: HelperObject Class - {00C6482D-C502-44C8-8409-FCE54AD9C208} - C:\Programfiler\TechSmith\SnagIt 8\SnagItBHO.dll
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Programfiler\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: BitComet ClickCapture - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - C:\Programfiler\BitComet\tools\BitCometBHO.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: IeHelper Class - {A491D208-B353-490F-B81A-A8A3DC97042D} - C:\WINDOWS\system32\smiehlp.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - blank (file missing)
O3 - Toolbar: (no name) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - (no file)
O3 - Toolbar: (no name) - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - (no file)
O3 - Toolbar: SnagIt - {8FF5E183-ABDE-46EB-B09E-D2AAB95CABE3} - C:\Programfiler\TechSmith\SnagIt 8\SnagItIEAddin.dll
O4 - HKLM\..\Run: [updReg] C:\WINDOWS\Updreg.exe
O4 - HKLM\..\Run: [CTStartup] C:\Programfiler\Creative\SBAudigy\Program\CTEaxSpl.EXE /run
O4 - HKLM\..\Run: [sunJavaUpdateSched] C:\Programfiler\Java\jre1.5.0_02\bin\jusched.exe
O4 - HKLM\..\Run: [PRONoMgr.exe] C:\Programfiler\Intel\NCS\PROSet\PRONoMgr.exe
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
O4 - HKLM\..\Run: [WorksFUD] C:\Programfiler\Microsoft Works\wkfud.exe
O4 - HKLM\..\Run: [Microsoft Works Portfolio] C:\Programfiler\Microsoft Works\WksSb.exe /AllUsers
O4 - HKLM\..\Run: [Microsoft Works Update Detection] C:\Programfiler\Microsoft Works\WkDetect.exe
O4 - HKLM\..\Run: [LVCOMSX] C:\WINDOWS\system32\LVCOMSX.EXE
O4 - HKLM\..\Run: [LogitechVideoRepair] C:\Programfiler\Logitech\Video\ISStart.exe
O4 - HKLM\..\Run: [LogitechVideoTray] C:\Programfiler\Logitech\Video\LogiTray.exe
O4 - HKLM\..\Run: [softDisc] "C:\Programfiler\SoftDisc\softdisc.exe" -hide
O4 - HKLM\..\Run: [Logitech Utility] Logi_MwX.Exe
O4 - HKLM\..\Run: [MaxtorOneTouch] C:\PROGRA~1\Maxtor\OneTouch\Utils\OneTouch.exe
O4 - HKLM\..\Run: [MXO Auto Loader] C:\WINDOWS\MXOALDR.EXE
O4 - HKLM\..\Run: [RemoteControl] C:\Programfiler\CyberLink\PowerDVD\PDVDServ.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [Jet Detection] C:\Programfiler\Creative\SBAudigy\PROGRAM\ADGJDet.exe
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVG7\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [WinampAgent] C:\Programfiler\Winamp\winampa.exe
O4 - HKLM\..\Run: [ATICCC] "C:\Programfiler\ATI Technologies\ATI.ACE\CLIStart.exe"
O4 - HKLM\..\Run: [REGSHAVE] C:\Programfiler\REGSHAVE\REGSHAVE.EXE /AUTORUN
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [LogitechSoftwareUpdate] C:\Programfiler\Logitech\Video\ManifestEngine.exe boot
O4 - HKCU\..\Run: [bMT] C:\Programfiler\BMT MouseTracker\MouseTrack.exe
O4 - HKCU\..\Run: [Pulse] C:\Programfiler\Pulse\Pulse.exe -splash
O4 - HKCU\..\Run: [FreeRAM XP] "C:\Programfiler\YourWare Solutions\FreeRAM XP Pro\FreeRAM XP Pro.exe" -win
O4 - HKCU\..\Run: [E06AXLRD_16125156] "C:\Programfiler\Microsoft Encarta\Encarta Premium DVD 2006\EDICT.EXE" -m
O4 - HKCU\..\Run: [sUPERAntiSpyware] C:\Programfiler\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - Startup: Mamut Online Backup.lnk = ?
O4 - Startup: World Community Grid Agent.lnk = C:\Programfiler\WorldCommunityGrid\UD.EXE
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Programfiler\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: Exif Launcher 2.lnk = ?
O4 - Global Startup: InterVideo WinCinema Manager.lnk = C:\Programfiler\InterVideo\Common\Bin\WinCinemaMgr.exe
O4 - Global Startup: Påminnelser for Microsoft Works Kalender.lnk = ?
O8 - Extra context menu item: &D&ownload &with BitComet - res://C:\Programfiler\BitComet\BitComet.exe/AddLink.htm
O8 - Extra context menu item: &D&ownload all video with BitComet - res://C:\Programfiler\BitComet\BitComet.exe/AddVideo.htm
O8 - Extra context menu item: &D&ownload all with BitComet - res://C:\Programfiler\BitComet\BitComet.exe/AddAllLink.htm
O8 - Extra context menu item: &Google Search - res://c:\programfiler\google\GoogleToolbar2.dll/cmsearch.html
O8 - Extra context menu item: Backward Links - res://c:\programfiler\google\GoogleToolbar2.dll/cmbacklinks.html
O8 - Extra context menu item: Cached Snapshot of Page - res://c:\programfiler\google\GoogleToolbar2.dll/cmcache.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Similar Pages - res://c:\programfiler\google\GoogleToolbar2.dll/cmsimilar.html
O8 - Extra context menu item: Translate into English - res://c:\programfiler\google\GoogleToolbar2.dll/cmtrans.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {B205A35E-1FC4-4CE3-818B-899DBBB3388C} - C:\Programfiler\Fellesfiler\Microsoft Shared\Encarta Search Bar\ENCSBAR.DLL
O9 - Extra button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Programfiler\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra 'Tools' menuitem: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Programfiler\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programfiler\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programfiler\Messenger\msmsgs.exe
O11 - Options group: [iNTERNATIONAL] International*
O16 - DPF: {04E214E5-63AF-4236-83C6-A7ADCBF9BD02} (HouseCall Control) - http://housecall60.trendmicro.com/housecall/xscan60.cab
O16 - DPF: {0A5FD7C5-A45C-49FC-ADB5-9952547D5715} - http://www.creative.com/su/ocx/15009/CTSUEng.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} - http://security.symantec.com/sscv6/SharedC...bin/AvSniff.cab
O16 - DPF: {39D420B3-E0EB-424C-89AA-C24F8DE7EF79} (KooPlayer Control) - http://www.tvkoo.com/update/KooPlayer.ocx
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://spaces.msn.com//PhotoUpload/MsnPUpld.cab
O16 - DPF: {54B52E52-8000-4413-BD67-FC7FE24B59F2} - http://files.ea.com/downloads/rtpatch/v2/EARTPX.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/microsoftupdat...b?1118175952031
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedC...n/bin/cabsa.cab
O16 - DPF: {6A060448-60F9-11D5-A6CD-0002B31F7455} - http://www.icanal.no/spill/commerce/catalo...es/ExentCtl.ocx
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdat...b?1118175849265
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} - http://messenger.msn.com/download/msnmesse...pdownloader.cab
O16 - DPF: {D8089245-3211-40F6-819B-9E5E92CD61A2} (FlashXControl Object) - https://flashcasino.ladbrokes.com/instant-p...-en/FlashAX.cab
O16 - DPF: {F04A8AE2-A59D-11D2-8792-00C04F8EF29D} (Hotmail Attachments Control) - http://by18fd.bay18.hotmail.msn.com/activex/HMAtchmt.ocx
O16 - DPF: {F58E1CEF-A068-4C15-BA5E-587CAF3EE8C6} - http://chat.msn.com/bin/msnchat45.cab
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} - http://www.creative.com/su/ocx/15010/CTPID.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{6978F5E5-3FD8-4CB7-80FF-52CDF6E3D714}: NameServer = 193.213.112.4 130.67.15.198
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O20 - Winlogon Notify: !SASWinLogon - C:\Programfiler\SUPERAntiSpyware\SASWINLO.dll
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
O23 - Service: AVG7 Resident Shield Service (AvgCoreSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgrssvc.exe
O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
O23 - Service: AVG Firewall (AVGFwSrv) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgfwsrv.exe
O23 - Service: B's Recorder GOLD Library General Service (bgsvcgen) - B.H.A Corporation - C:\WINDOWS\system32\bgsvcgen.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.EXE
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Programfiler\Fellesfiler\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Kodak Camera Connection Software (KodakCCS) - Eastman Kodak Company - C:\WINDOWS\system32\drivers\KodakCCS.exe
O23 - Service: Intel NCS NetService (NetSvc) - Intel® Corporation - C:\Programfiler\Intel\NCS\Sync\NetSvc.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Unknown owner - C:\Programfiler\Fellesfiler\Symantec Shared\SNDSrvc.exe (file missing)
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Programfiler\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
O23 - Service: SymWMI Service (SymWSC) - Unknown owner - C:\Programfiler\Fellesfiler\Symantec Shared\Security Center\SymWSC.exe (file missing)
Itavisens speedometer viser:
Nedlastingshastighet: 22 kbit/s
Opplastingshastighet: 430 kbit/s
Jeg laster ikke ned noe, eller har noen programmer som er kjent av meg som gjør det.
Kjør HJT og fix:
Hvis du kjenner til dette programmet
er HJT-loggen ok.
Står litt stille ang. lav hastighet. Kanskje reinstallere nettverkskortet?
Brukes det noen programmer som kan fordele båndbredde og så forårsaker dette?
Prøv å kjør en sfc /scannow (mellomrom mellom sfc og / ) fra Start->Kjør . Du trenger WinXP cd'n. Du får ikke noe beskjed om det er fixet noe. Restart når det er ferdig å sjekk hastigheten.
Endret av norbat
Ja pulse kjenner jeg til (programm som ser hvor mange trykk jeg har på keybordet).
Måtte først finne Windows cd'en hehe :!:
Kjørte Scanningen med windows cd'en og restartet etterpå men hastigheten er den samme.
Da gjenstår det disse to tingene da....
Endret av tha_man
Last ned SDfix og pakk det (normalt til C:\SDfix )
Åpne SDfix-mappa og kjør RunTHis.bat. Trykk 'y' for å bekrefte at du kjører skiptet på egen risiko
Du vil bli bedt om å restarte pc'n. Når pc'n er startet igjen vil skriptet kjøres ferdig og du vil få melding når det er ferdig. Klikk en tast for å få skrivebordsikonene fram.
Det lages en logg i SDfix-mappa - Report.txt. Post den her.
Vi skal også prøve et annet glimrende antispywareprog - AVG. Kjør en full scan. Velg å 'Save report' og post loggen her.
Endret av norbat
SDfix rapport:
SDFix: Version 1.53
06-12-31 - 14:07:19.07
Microsoft Windows XP [Versjon 5.1.2600]
Running From: C:\SDFix
Stage One - Safe Mode
Checking Services...
Service Name:
File Path:
Starting Registry Repairs...
Restoring Default Hosts File...
Stage One Complete
Rebooting...
Stage Two - Normal Mode
Checking For Malware:
C:\WINDOWS\system32\SysPr.prx
Backing Up and Removing any Files Found...
Alternate Stream Check:
C:\WINDOWS\system32
No streams found.
Final Check:
Remaining Services:
Remaining Files:
Backups Folder: - C:\SDFix\backups\backups.zip
Checking for files with Hidden Attributes:
C:\olddrivers\cdplayer.exe.manifest
C:\olddrivers\logonui.exe.manifest
C:\WINDOWS\system32\cdplayer.exe.manifest
C:\WINDOWS\system32\logonui.exe.manifest
C:\hiberfil.sys
C:\IO.SYS
C:\MSDOS.SYS
C:\MSSYS.SYS
C:\pagefile.sys
C:\Documents and Settings\All Users\DRM\Cache\Indiv01.tmp
C:\Documents and Settings\All Users\Programdata\Microsoft\Media Player\FQUPhdtC5\p4vdBLq7zb.tmp
C:\Documents and Settings\All Users\Programdata\PACE Anti-Piracy\2BFQUPhdtC5Axy\p4vdBLq7zb.tmp
C:\WINDOWS\system32\config\default.tmp.LOG
C:\WINDOWS\system32\config\software.tmp.LOG
C:\WINDOWS\system32\config\system.tmp.LOG
FINISHED!
AVG er mitt primære anti-virus programm (Har profesional), kjører full test nå....
AVG Anti-Spyware - Scan Report
+ Created at: 02:55 07-01-01
+ Scan result:
C:\Documents and Settings\Server\Cookies\server@advertising[2].txt -> TrackingCookie.Advertising : No action taken.
C:\Documents and Settings\Server\Cookies\server@mediaplex[1].txt -> TrackingCookie.Mediaplex : No action taken.
::Report end
Nedlastings hastigheten min er borti 70 kbit/s men det er enda bare 1/25 av linja!?
Endret av tha_man
Loggene dine ser ok ut så jeg klarer ikke helt å se hva som evt. kan forårsake strupingen av hastigheten.
At du ikke får kjørt Combofix er også litt merkelig. Kanskje det lar seg gjøre fra sikker modus?
Har du prøvd å avinstallere nettverkskortet og reinstallert det?
Om ikke det over hjelper, er en repair en mulig løsning. Om du ikke har gjort dette før er det enkelt forklart:
1. Boot med WinXP cd'n
2. Velg å foreta en installasjon av Windows.
3. Installasjonen vil lete etter installerte operativsystemer
4. Du vil få valget om å bla. reparere det installerte operativsys., noe du velger
5. Det vil bli foretatt en reparering - fortoner seg som en vanlig installering.
6. Du vil i utg.pkt ikke miste noe som helst av data, men regner med at du må hente oppdateringene for windows som har kommet i etterkant av cd'n. Det er også lurt å ta backup av data du ikke vil miste. Just in case.
Hvis dette ikke hjelper tror jeg du har to valg:
1. Prøv et nytt nettverkskort
2. Foreta en formatering og legg inn windows helt på nytt.
I sikkermodus gikk det med Combofix....
Combofix logg:
Server - 07-01-01 14:44:53.85 Service Pack 2
ComboFix 06.11.27 - Running from: "C:\Documents and Settings\Server\Skrivebord\combofix"
(((((((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\Documents and Settings\Server\Programdata\Install.dat
C:\Programfiler\Fellesfiler\download
((((((((((((((((((((((((((((((( Files Created from 2006-11-29 to 2006-12-29 ))))))))))))))))))))))))))))))))))
2006-12-31 14:53 3,968 --a------ C:\WINDOWS\system32\drivers\AvgAsCln.sys
2006-12-31 13:50 <DIR> dr-h----- C:\Documents and Settings\Server\Siste
2006-12-31 13:49 <DIR> d-------- C:\SDFix
2006-12-30 23:00 <DIR> d-------- C:\bintheredunthat
2006-12-30 22:26 <DIR> d-------- C:\BFU
2006-12-30 13:32 <DIR> d-------- C:\WINDOWS\WBEM
2006-12-30 13:32 <DIR> d-------- C:\WINDOWS\system32\nb-no
2006-12-30 13:31 <DIR> d--h-c--- C:\WINDOWS\ie7
2006-12-30 13:29 121,856 --------- C:\WINDOWS\system32\xmllite.dll
2006-12-30 13:21 <DIR> d-------- C:\Programfiler\Windows Media Connect 2
2006-12-30 13:19 <DIR> d-------- C:\WINDOWS\system32\LogFiles
2006-12-30 13:19 <DIR> d-------- C:\WINDOWS\system32\drivers\UMDF
2006-12-29 20:40 <DIR> d-------- C:\afe32085786b18b0af89948f0063446e
2006-12-29 20:19 <DIR> d-------- C:\fa6067dbda5aa9979c501f
2006-12-29 14:23 <DIR> d-------- C:\Documents and Settings\Server\DoctorWeb
2006-12-29 13:22 <DIR> d-------- C:\Programfiler\SUPERAntiSpyware
2006-12-29 13:22 <DIR> d-------- C:\Documents and Settings\Server\Programdata\SUPERAntiSpyware.com
2006-12-29 12:35 <DIR> d-------- C:\Programfiler\CCleaner
2006-12-22 16:07 5,632 --a------ C:\WINDOWS\system32\ptpusb.dll
2006-12-22 16:07 159,232 --a------ C:\WINDOWS\system32\ptpusd.dll
2006-12-22 15:58 <DIR> d-------- C:\Programfiler\PIXELA
2006-12-22 15:56 106,496 --a------ C:\WINDOWS\system32\FPXS2Pro.dll
2006-12-22 15:54 81,924 --------- C:\WINDOWS\system32\drivers\VC4CB104.SYS
2006-12-22 15:54 69,632 --------- C:\WINDOWS\system32\FREGSHEX.DLL
2006-12-22 15:54 65,536 --------- C:\WINDOWS\system32\FINFCHECK.dll
2006-12-22 15:54 45,056 --------- C:\WINDOWS\system32\FINFCOPY.dll
2006-12-22 15:54 45,056 --------- C:\WINDOWS\system32\FCLKBTN.DLL
2006-12-22 15:54 <DIR> d-------- C:\Programfiler\REGSHAVE
2006-12-22 15:30 <DIR> d-------- C:\Documents and Settings\Server\Programdata\FUJIFILM
2006-12-22 15:29 <DIR> d-------- C:\Programfiler\FinePixViewer
2006-12-22 15:12 86,016 --------- C:\WINDOWS\system32\bgsvcgen.exe
2006-12-22 15:12 57,344 --------- C:\WINDOWS\system32\GenSvcInst.exe
2006-12-22 15:12 49,152 --------- C:\WINDOWS\system32\setupsvc.dll
2006-12-22 15:12 32,256 --------- C:\WINDOWS\system32\drivers\cdrbsdrv.sys
2006-12-22 15:10 274,432 --a------ C:\WINDOWS\system32\FFTIFF16.dll
2006-12-22 15:10 155,648 --a------ C:\WINDOWS\system32\FFRAFLIB.DLL
2006-12-21 00:57 <DIR> dr-h----- C:\$VAULT$.AVG
2006-12-21 00:47 816,672 --a------ C:\WINDOWS\system32\drivers\avg7core.sys
2006-12-21 00:47 4,960 --a------ C:\WINDOWS\system32\drivers\avgtdi.sys
2006-12-21 00:47 4,224 --a------ C:\WINDOWS\system32\drivers\avg7rsw.sys
2006-12-21 00:47 3,968 --a------ C:\WINDOWS\system32\drivers\avgclean.sys
2006-12-21 00:47 28,416 --a------ C:\WINDOWS\system32\drivers\avg7rsxp.sys
2006-12-21 00:47 18,240 --a------ C:\WINDOWS\system32\drivers\avgmfx86.sys
2006-12-21 00:47 110,592 --a------ C:\WINDOWS\system32\avgfwafu.dll
2006-12-21 00:47 <DIR> d-------- C:\Programfiler\Grisoft
2006-12-21 00:47 <DIR> d-------- C:\Documents and Settings\Server\Programdata\AVG7
2006-12-21 00:47 <DIR> d-------- C:\Documents and Settings\All Users\Programdata\Grisoft
2006-12-20 23:55 <DIR> d-------- C:\Documents and Settings\All Users\Programdata\Avg7
2006-12-11 17:57 <DIR> d-------- C:\Programfiler\SEGA
2006-12-11 17:55 <DIR> d-------- C:\Documents and Settings\Server\Programdata\InstallShield
(((((((((((((((((((((((((((((((((((((((((((((((( Find3M Report )))))))))))))))))))))))))))))))))))))))))))))))))))))
2006-12-31 15:24 -------- d-------- C:\Programfiler\WorldCommunityGrid
2006-12-30 13:35 -------- d-------- C:\Programfiler\Internet Explorer
2006-12-30 13:21 -------- d-------- C:\Programfiler\Windows Media Player
2006-12-30 03:26 2560 --a------ C:\WINDOWS\system32\BitCometRes.dll
2006-12-30 03:26 -------- d-------- C:\Programfiler\BitComet
2006-12-29 19:51 -------- d--h----- C:\Programfiler\InstallShield Installation Information
2006-12-29 19:51 -------- d-------- C:\Programfiler\Logitech
2006-12-29 16:58 -------- d-------- C:\Programfiler\LimeWire
2006-12-29 13:21 -------- d-------- C:\Programfiler\Fellesfiler\Wise Installation Wizard
2006-12-22 15:14 -------- d-------- C:\Documents and Settings\Server\Programdata\Skype
2006-12-21 15:25 -------- d-------- C:\Documents and Settings\Server\Programdata\teamspeak2
2006-12-21 13:33 -------- d-------- C:\Programfiler\QuickTime
2006-12-21 12:59 -------- d-------- C:\Documents and Settings\Server\Programdata\Winamp
2006-12-21 12:58 -------- d-------- C:\Programfiler\Winamp
2006-12-21 12:37 -------- d-------- C:\Programfiler\InetGet
2006-12-20 23:11 -------- d---s---- C:\Programfiler\Xfire
2006-12-20 22:30 -------- d-------- C:\Documents and Settings\Server\Programdata\Xfire
2006-12-16 03:03 -------- d-a------ C:\Programfiler\Outlook Express
2006-12-16 03:03 -------- d-------- C:\Programfiler\Fellesfiler\System
2006-12-03 19:26 -------- d-------- C:\Programfiler\Electronic Arts
2006-12-03 19:24 -------- d-------- C:\Programfiler\Skype
2006-12-03 19:19 -------- d-------- C:\Programfiler\America's Army Server Manager
2006-11-29 13:35 -------- d-------- C:\Programfiler\WinRAR
2006-11-22 10:52 520192 --------- C:\WINDOWS\system32\ati2sgag.exe
2006-11-22 04:25 2829824 --a------ C:\WINDOWS\system32\drivers\ati2mtag.sys
2006-11-22 04:25 261120 --a------ C:\WINDOWS\system32\ati2dvag.dll
2006-11-22 04:20 118784 --a------ C:\WINDOWS\system32\atipdlxx.dll
2006-11-22 04:20 106496 --a------ C:\WINDOWS\system32\Oemdspif.dll
2006-11-22 04:19 90112 --a------ C:\WINDOWS\system32\ati2evxx.dll
2006-11-22 04:19 42496 --a------ C:\WINDOWS\system32\ati2edxx.dll
2006-11-22 04:19 26112 --a------ C:\WINDOWS\system32\Ati2mdxx.exe
2006-11-22 04:18 430080 --a------ C:\WINDOWS\system32\ati2evxx.exe
2006-11-22 04:17 53248 --a------ C:\WINDOWS\system32\ATIDDC.DLL
2006-11-22 04:12 2526688 --a------ C:\WINDOWS\system32\ati3duag.dll
2006-11-22 04:11 5279744 --a------ C:\WINDOWS\system32\atioglxx.dll
2006-11-22 04:08 1090016 --a------ C:\WINDOWS\system32\ativvaxx.dll
2006-11-22 03:57 217088 --a------ C:\WINDOWS\system32\atikvmag.dll
2006-11-22 03:56 17408 --a------ C:\WINDOWS\system32\atitvo32.dll
2006-11-22 03:51 294912 --a------ C:\WINDOWS\system32\ati2cqag.dll
2006-11-22 03:50 6684672 --a------ C:\WINDOWS\system32\atioglx1.dll
2006-11-22 03:49 307200 --a------ C:\WINDOWS\system32\atiiiexx.dll
2006-11-22 03:21 303104 --a------ C:\WINDOWS\system32\ATIDEMGR.dll
2006-11-15 11:07 8247296 --a------ C:\WINDOWS\system32\wmploc.dll
2006-11-15 10:46 99840 --a------ C:\WINDOWS\system32\wmpshell.dll
2006-11-15 10:45 225280 --a------ C:\WINDOWS\system32\wmerror.dll
2006-11-15 10:43 7168 --a------ C:\WINDOWS\system32\asferror.dll
2006-11-08 06:08 679424 --a------ C:\WINDOWS\system32\inetcomm.dll
2006-11-07 21:03 6049280 --------- C:\WINDOWS\system32\ieframe.dll
2006-11-07 21:03 50688 --------- C:\WINDOWS\system32\msfeedsbs.dll
2006-11-07 21:03 458752 --------- C:\WINDOWS\system32\msfeeds.dll
2006-11-07 21:03 413696 --a------ C:\WINDOWS\system32\vbscript.dll
2006-11-07 21:03 231424 --a------ C:\WINDOWS\system32\webcheck.dll
2006-11-07 21:03 180736 --------- C:\WINDOWS\system32\ieui.dll
2006-11-07 21:03 156160 --a------ C:\WINDOWS\system32\msls31.dll
2006-11-07 03:27 382976 --a------ C:\WINDOWS\system32\iedkcs32.dll
2006-11-07 03:27 229376 --a------ C:\WINDOWS\system32\ieaksie.dll
2006-11-07 03:26 71680 --a------ C:\WINDOWS\system32\admparse.dll
2006-11-07 03:26 55296 --a------ C:\WINDOWS\system32\iesetup.dll
2006-11-07 03:26 54784 --a------ C:\WINDOWS\system32\ie4uinit.exe
2006-11-07 03:26 43008 --a------ C:\WINDOWS\system32\iernonce.dll
2006-11-07 03:26 152064 --a------ C:\WINDOWS\system32\ieakeng.dll
2006-11-07 03:26 13312 --a------ C:\WINDOWS\system32\ieudinit.exe
2006-11-07 03:26 123904 --a------ C:\WINDOWS\system32\advpack.dll
2006-11-07 03:25 161792 --a------ C:\WINDOWS\system32\ieakui.dll
2006-11-04 13:14 1245696 --a------ C:\WINDOWS\system32\msxml4.dll
2006-11-02 11:52 38912 --------- C:\WINDOWS\system32\wpdshextres.dll
2006-10-20 02:39 713728 --a------ C:\WINDOWS\system32\sxs.dll
2006-10-18 21:58 8704 --a------ C:\WINDOWS\system32\wdfmgr.exe
2006-10-18 21:58 8704 --a------ C:\WINDOWS\system32\uwdf.exe
2006-10-18 21:47 991744 --a------ C:\WINDOWS\system32\drmv2clt.dll
2006-10-18 21:47 937984 --a------ C:\WINDOWS\system32\WMNetMgr.dll
2006-10-18 21:47 767488 --------- C:\WINDOWS\system32\WMVSENCD.dll
2006-10-18 21:47 757248 --a------ C:\WINDOWS\system32\WMADMOD.dll
2006-10-18 21:47 656896 --------- C:\WINDOWS\system32\WMVXENCD.dll
2006-10-18 21:47 63488 --a------ C:\WINDOWS\system32\wpdmtpus.dll
2006-10-18 21:47 629760 --a------ C:\WINDOWS\system32\wpd_ci.dll
2006-10-18 21:47 613376 --------- C:\WINDOWS\system32\wmpmde.dll
2006-10-18 21:47 603648 --a------ C:\WINDOWS\system32\WMSPDMOD.dll
2006-10-18 21:47 542720 --a------ C:\WINDOWS\system32\blackbox.dll
2006-10-18 21:47 535040 --------- C:\WINDOWS\system32\wmdrmsdk.dll
2006-10-18 21:47 429056 --a------ C:\WINDOWS\system32\wmdrmdev.dll
2006-10-18 21:47 414208 --a------ C:\WINDOWS\system32\msscp.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\wmvdmoe2.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\wmvdmod.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\WMVADVE.DLL
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\WMVADVD.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\wmsdmoe2.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\wmsdmod.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\wdfapi.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\MPG4DMOD.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\MP4SDMOD.dll
2006-10-18 21:47 4096 --a------ C:\WINDOWS\system32\MP43DMOD.dll
2006-10-18 21:47 37376 --a------ C:\WINDOWS\system32\wmdmps.dll
2006-10-18 21:47 35840 --a------ C:\WINDOWS\system32\wpdconns.dll
2006-10-18 21:47 356352 --a------ C:\WINDOWS\system32\wpdsp.dll
2006-10-18 21:47 348672 --a------ C:\WINDOWS\system32\wmdrmnet.dll
2006-10-18 21:47 33792 --a------ C:\WINDOWS\system32\wmdmlog.dll
2006-10-18 21:47 321536 --a------ C:\WINDOWS\system32\mswmdm.dll
2006-10-18 21:47 317440 --------- C:\WINDOWS\system32\MP4SDECD.dll
2006-10-18 21:47 314880 --a------ C:\WINDOWS\system32\wmpdxm.dll
2006-10-18 21:47 295936 --------- C:\WINDOWS\system32\wmpeffects.dll
2006-10-18 21:47 284160 --------- C:\WINDOWS\system32\PortableDeviceApi.dll
2006-10-18 21:47 276992 --a------ C:\WINDOWS\system32\audiodev.dll
2006-10-18 21:47 27136 --a------ C:\WINDOWS\system32\mspmsnsv.dll
2006-10-18 21:47 2603008 --------- C:\WINDOWS\system32\WpdShext.dll
2006-10-18 21:47 259072 --------- C:\WINDOWS\system32\MPG4DECD.dll
2006-10-18 21:47 259072 --------- C:\WINDOWS\system32\MP43DECD.dll
2006-10-18 21:47 2450944 --a------ C:\WINDOWS\system32\wmvcore.dll
2006-10-18 21:47 242688 --a------ C:\WINDOWS\system32\wmpasf.dll
2006-10-18 21:47 229376 --a------ C:\WINDOWS\system32\cewmdm.dll
2006-10-18 21:47 222208 --a------ C:\WINDOWS\system32\WMASF.dll
2006-10-18 21:47 212992 --------- C:\WINDOWS\system32\MFPLAT.dll
2006-10-18 21:47 211456 --a------ C:\WINDOWS\system32\qasf.dll
2006-10-18 21:47 204288 --a------ C:\WINDOWS\system32\wmpsrcwp.dll
2006-10-18 21:47 199168 --------- C:\WINDOWS\system32\PortableDeviceWMDRM.dll
2006-10-18 21:47 179712 --a------ C:\WINDOWS\system32\msnetobj.dll
2006-10-18 21:47 175616 --a------ C:\WINDOWS\system32\mspmsp.dll
2006-10-18 21:47 166912 --------- C:\WINDOWS\system32\PortableDeviceTypes.dll
2006-10-18 21:47 1661440 --a------ C:\WINDOWS\system32\wmpencen.dll
2006-10-18 21:47 1574912 --------- C:\WINDOWS\system32\WMVENCOD.dll
2006-10-18 21:47 157184 --a------ C:\WINDOWS\system32\wmidx.dll
2006-10-18 21:47 154624 --a------ C:\WINDOWS\system32\wpdmtp.dll
2006-10-18 21:47 1543680 --------- C:\WINDOWS\system32\WMVDECOD.dll
2006-10-18 21:47 1382912 --------- C:\WINDOWS\system32\WMVSDECD.dll
2006-10-18 21:47 133632 --------- C:\WINDOWS\system32\WPDShServiceObj.dll
2006-10-18 21:47 1329152 --a------ C:\WINDOWS\system32\WMSPDMOE.dll
2006-10-18 21:47 132096 --------- C:\WINDOWS\system32\PortableDeviceWiaCompat.dll
2006-10-18 21:47 130048 --------- C:\WINDOWS\system32\wmpps.dll
2006-10-18 21:47 11264 --a------ C:\WINDOWS\system32\LAPRXY.dll
2006-10-18 21:47 1117696 --a------ C:\WINDOWS\system32\WMADMOE.dll
2006-10-18 21:47 101888 --------- C:\WINDOWS\system32\PortableDeviceClassExtension.dll
2006-10-18 20:03 100864 --a------ C:\WINDOWS\system32\logagent.exe
2006-10-18 20:00 249856 --------- C:\WINDOWS\system32\drmupgds.exe
2006-10-18 20:00 17408 --------- C:\WINDOWS\system32\wpdshextautoplay.exe
2006-10-17 12:06 78336 --a------ C:\WINDOWS\system32\ieencode.dll
2006-10-17 12:05 40960 --a------ C:\WINDOWS\system32\licmgr10.dll
2006-10-17 12:05 206336 --------- C:\WINDOWS\system32\WinFXDocObj.exe
2006-10-17 12:05 105984 --a------ C:\WINDOWS\system32\url.dll
2006-10-17 12:04 101376 --a------ C:\WINDOWS\system32\occache.dll
2006-10-17 12:03 17408 --a------ C:\WINDOWS\system32\corpol.dll
2006-10-17 11:58 61952 --------- C:\WINDOWS\system32\icardie.dll
2006-10-17 11:58 12288 --------- C:\WINDOWS\system32\msfeedssync.exe
2006-10-17 11:57 36352 --a------ C:\WINDOWS\system32\imgutil.dll
2006-10-17 11:57 266752 --------- C:\WINDOWS\system32\iertutil.dll
2006-10-17 11:56 45568 --a------ C:\WINDOWS\system32\mshta.exe
2006-10-17 11:28 48128 --a------ C:\WINDOWS\system32\mshtmler.dll
2006-10-17 11:27 380928 --------- C:\WINDOWS\system32\ieapfltr.dll
2006-10-13 13:41 141824 --a------ C:\WINDOWS\system32\nwprovau.dll
2006-10-02 15:28 312128 --------- C:\WINDOWS\system32\msdelta.dll
(((((((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries are not shown
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\run]
"CTFMON.EXE"="C:\\WINDOWS\\system32\\ctfmon.exe"
"LogitechSoftwareUpdate"="C:\\Programfiler\\Logitech\\Video\\ManifestEngine.exe boot"
"BMT"="C:\\Programfiler\\BMT MouseTracker\\MouseTrack.exe"
"Pulse"="C:\\Programfiler\\Pulse\\Pulse.exe -splash"
"FreeRAM XP"="\"C:\\Programfiler\\YourWare Solutions\\FreeRAM XP Pro\\FreeRAM XP Pro.exe\" -win"
"E06AXLRD_16125156"="\"C:\\Programfiler\\Microsoft Encarta\\Encarta Premium DVD 2006\\EDICT.EXE\" -m"
"SUPERAntiSpyware"="C:\\Programfiler\\SUPERAntiSpyware\\SUPERAntiSpyware.exe"
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run]
"UpdReg"="C:\\WINDOWS\\Updreg.exe"
"CTStartup"="C:\\Programfiler\\Creative\\SBAudigy\\Program\\CTEaxSpl.EXE /run"
"SunJavaUpdateSched"="C:\\Programfiler\\Java\\jre1.5.0_02\\bin\\jusched.exe"
"PRONoMgr.exe"="C:\\Programfiler\\Intel\\NCS\\PROSet\\PRONoMgr.exe"
"CTHelper"="CTHELPER.EXE"
"HPDJ Taskbar Utility"="C:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\hpztsb07.exe"
"WorksFUD"="C:\\Programfiler\\Microsoft Works\\wkfud.exe"
"Microsoft Works Portfolio"="C:\\Programfiler\\Microsoft Works\\WksSb.exe /AllUsers"
"Microsoft Works Update Detection"="C:\\Programfiler\\Microsoft Works\\WkDetect.exe"
"LVCOMSX"="C:\\WINDOWS\\system32\\LVCOMSX.EXE"
"LogitechVideoRepair"="C:\\Programfiler\\Logitech\\Video\\ISStart.exe"
"LogitechVideoTray"="C:\\Programfiler\\Logitech\\Video\\LogiTray.exe"
"SoftDisc"="\"C:\\Programfiler\\SoftDisc\\softdisc.exe\" -hide"
"Logitech Utility"="Logi_MwX.Exe"
"MaxtorOneTouch"="C:\\PROGRA~1\\Maxtor\\OneTouch\\Utils\\OneTouch.exe"
"MXO Auto Loader"="C:\\WINDOWS\\MXOALDR.EXE"
"RemoteControl"="C:\\Programfiler\\CyberLink\\PowerDVD\\PDVDServ.exe"
"NeroFilterCheck"="C:\\WINDOWS\\system32\\NeroCheck.exe"
"Jet Detection"="C:\\Programfiler\\Creative\\SBAudigy\\PROGRAM\\ADGJDet.exe"
"AVG7_CC"="C:\\PROGRA~1\\Grisoft\\AVG7\\avgcc.exe /STARTUP"
"WinampAgent"="C:\\Programfiler\\Winamp\\winampa.exe"
"ATICCC"="\"C:\\Programfiler\\ATI Technologies\\ATI.ACE\\CLIStart.exe\""
"REGSHAVE"="C:\\Programfiler\\REGSHAVE\\REGSHAVE.EXE /AUTORUN"
"!AVG Anti-Spyware"="\"C:\\Programfiler\\Grisoft\\AVG Anti-Spyware 7.5\\avgas.exe\" /minimized"
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents\IMAIL]
"Installed"="1"
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents\MAPI]
"Installed"="1"
"NoChange"="1"
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents\MSFS]
"Installed"="1"
[HKEY_CURRENT_USER\software\microsoft\internet explorer\desktop\components]
"DeskHtmlVersion"=dword:00000110
"DeskHtmlMinorVersion"=dword:00000005
"Settings"=dword:00000001
"GeneralFlags"=dword:00000001
[HKEY_CURRENT_USER\software\microsoft\internet explorer\desktop\components\0]
"Source"="About:Home"
"SubscribedURL"="About:Home"
"FriendlyName"="Min gjeldende hjemmeside"
"Flags"=dword:00000002
"Position"=hex:2c,00,00,00,cc,00,00,00,00,00,00,00,34,03,00,00,e2,02,00,00,00,\
00,00,00,01,00,00,00,01,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00
"CurrentState"=hex:04,00,00,40
"OriginalStateInfo"=hex:18,00,00,00,ff,ff,00,00,ff,ff,00,00,ff,ff,ff,ff,ff,ff,\
ff,ff,04,00,00,00
"RestoredStateInfo"=hex:18,00,00,00,f2,01,00,00,b9,00,00,00,7c,00,00,00,72,00,\
00,00,01,00,00,00
[HKEY_USERS\.default\software\microsoft\windows\currentversion\run]
"CTFMON.EXE"="C:\\WINDOWS\\system32\\CTFMON.EXE"
"AVG7_Run"="C:\\PROGRA~1\\Grisoft\\AVG7\\avgw.exe /RUNONCE"
[HKEY_USERS\s-1-5-18\software\microsoft\windows\currentversion\run]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\sharedtaskscheduler]
"{438755C2-A8BA-11D1-B96B-00A0C90312E1}"="Browseui preloader"
"{8C7461EF-2B13-11d2-BE35-3078302C2030}"="Component Categories cache daemon"
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shellexecutehooks]
"{AEB6717E-7E19-11d0-97EE-00C04FD91972}"=""
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"=""
"{57B86673-276A-48B2-BAE7-C6DBB3020EB8}"="AVG Anti-Spyware 7.5"
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
"NoDriveTypeAutoRun"=dword:0000009d
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer\Run]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"dontdisplaylastusername"=dword:00000000
"legalnoticecaption"=""
"legalnoticetext"=""
"shutdownwithoutlogon"=hex:01,00,00,00
"undockwithoutlogon"=dword:00000001
[HKEY_USERS\.default\software\microsoft\windows\currentversion\policies\explorer]
"NoDriveTypeAutoRun"=dword:00000091
[HKEY_USERS\s-1-5-18\software\microsoft\windows\currentversion\policies\explorer]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\shellserviceobjectdelayload]
"PostBootReminder"="{7849596a-48ea-486e-8937-a2a3009f31a9}"
"CDBurn"="{fbeb8a05-beee-4442-804e-409d6c4515e9}"
"WebCheck"="{E6FB5E20-DE35-11CF-9C87-00AA005127ED}"
"SysTray"="{35CEC8A3-2BE6-11D2-8773-92E220524153}"
"WPDShServiceObj"="{AAA288BA-9A4C-45B0-95D7-94D524869DB5}"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start-meny^Programmer^Oppstart^SECRETMAKER.lnk]
"path"="C:\\Documents and Settings\\All Users\\Start-meny\\Programmer\\Oppstart\\SECRETMAKER.lnk"
"backup"="C:\\WINDOWS\\pss\\SECRETMAKER.lnkCommon Startup"
"location"="Common Startup"
"command"="C:\\PROGRA~1\\SECRET~1\\SECRET~1.EXE /Logon"
"item"="SECRETMAKER"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Server^Start-meny^Programmer^Oppstart^HDDlife.lnk]
"path"="C:\\Documents and Settings\\Server\\Start-meny\\Programmer\\Oppstart\\HDDlife.lnk"
"backup"="C:\\WINDOWS\\pss\\HDDlife.lnkStartup"
"location"="Startup"
"command"="C:\\Programfiler\\HDDlife\\HDDlife.exe "
"item"="HDDlife"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Server^Start-meny^Programmer^Oppstart^PowerReg Scheduler.exe]
"path"="C:\\Documents and Settings\\Server\\Start-meny\\Programmer\\Oppstart\\PowerReg Scheduler.exe"
"backup"="C:\\WINDOWS\\pss\\PowerReg Scheduler.exeStartup"
"command"="C:\\Documents and Settings\\Server\\Start-meny\\Programmer\\Oppstart\\PowerReg Scheduler.exe"
"item"="PowerReg Scheduler"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Server^Start-meny^Programmer^Oppstart^Registration Silent Hunter III.LNK]
"path"="C:\\Documents and Settings\\Server\\Start-meny\\Programmer\\Oppstart\\Registration Silent Hunter III.LNK"
"backup"="C:\\WINDOWS\\pss\\Registration Silent Hunter III.LNKStartup"
"command"="C:\\Programfiler\\Ubisoft\\SilentHunterIII\\Support\\Register\\RegistrationReminder.exe -d 802361 -l english -r 7 -g Silent Hunter III -c us -i 2172"
"item"="Registration Silent Hunter III"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^Server^Start-meny^Programmer^Oppstart^Xfire.lnk]
"backup"="C:\\WINDOWS\\pss\\Xfire.lnkStartup"
"command"="C:\\PROGRA~1\\Xfire\\Xfire.exe "
"item"="Xfire"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\CashFiesta]
"key"="SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run"
"item"="Cashfiesta"
"hkey"="HKCU"
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\DAEMON Tools-1033]
"item"="daemon"
"hkey"="HKLM"
"command"="\"C:\\Programfiler\\D-Tools\\daemon.exe\" -lang 1033"
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MoneyAgent]
"item"="mnyexpr"
"hkey"="HKCU"
"command"="\"C:\\Programfiler\\Microsoft Money\\System\\mnyexpr.exe\""
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ms-update]
"item"=""
"hkey"="HKLM"
"command"=""
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\msnmsgr]
"item"="msnmsgr"
"hkey"="HKCU"
"command"="\"C:\\Programfiler\\MSN Messenger\\msnmsgr.exe\" /background"
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Steam]
"item"=""
"hkey"="HKCU"
"command"=""
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Uptime-Project]
"item"="client"
"hkey"="HKCU"
"command"="C:\\Documents and Settings\\Server\\Skrivebord\\client\\client.exe"
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Zone Labs Client]
"item"="zlclient"
"hkey"="HKLM"
"command"="C:\\Programfiler\\Zone Labs\\ZoneAlarm\\zlclient.exe"
"inimapping"="0"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
"ZESOFT"=dword:00000002
HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\securityproviders]
"SecurityProviders"="msapsspc.dll, schannel.dll, digest.dll, msnsspc.dll"
Completion time: 07-01-01 14:47:35.51
C:\ComboFix.txt ... 07-01-01 14:47
