kjøpe ny disk og sette opp raid 0 uten å formatere
exin89
derimot jeg trur du IKKE må formatere...skal gå ann å bare sette inn en ny harddisk så lenge du ikke skal ha OS på den
7589474[/snapback]
jeg vet hva du mener..... du kan clone harddisken, men anbefaler ikke. det skjedde faktisk at det skjerte seg for meg. derfor er det bedre å bruke 60 minutter og legge alt på nytt.....
her er tips hvordan du kan gjøre dette uten re-install:
(1) Boot to Ghost, run a "clone" from your system drive to a backup drive, then shutdown.
(2) Disconnect the system drive and boot the backup clone to verify that the clone is good, then shutdown.
(3) Connect the new RAID0 set and stripe it in RAID BIOS, then boot to the backup clone. The OS will find the RAID0 hardware and prompt you to install the drivers.
(4) Reboot and verify the RAID0 set in device manager, partition and set active, then shutdown.
(5) Boot to Ghost, run a clone from the backup drive to the RAID0 set, then shutdown.
(6) Disconnect the backup drive and boot to the RAID0 set.
her er liten forklaring hva skjer i RAID 0 (fra en US forum):
if you want to install raid-0 on the system you have to go back and wipe the hd, reinstall windows XP and updates.
raid-0 splits data between 2 hds.. if you only have the data on 1 hd the raid controller cant just cut down the middle and give one half to the other hd it has to be done on the fly. while the data is being processed half is sent one way and the other half is sent another way.
