hvor kan jeg få tak i tv coder til 360 medie remot
Mikr89
Har du prøvd dette?
To scan for a TV code:
  1. Turn on your TV and point the remote toward it.
  2. Press and hold the TV and OK buttons simultaneously for two seconds. All buttons on the remote will then light up for two seconds, after which only the numeric TV buttons (1–12) will remain lit.
  3. Press the CH+ or CH– button to send a series of off commands to your TV. Repeat until the TV turns off.
Note
      Give your TV enough time to respond to the off command after each button press. Some TVs take more time to react to off commands than others.
  4. Press the TV button to save the code and exit. All buttons on the remote will blink three times to confirm the code.
  5. Press the TV button again to restore full TV/Xbox 360 operability.
Note
If, after setting the TV code, you find that the remote is not functional or has incomplete or inaccurate TV functionality, try a different code for your TV manufacturer or scan for another code.
