Cat5 krav
Hei.
Sitter her på jobben og vi diskuterer hvor mange kilo man kan dra kabelen...
Vi tenker når vi drar kabler igjennom rør og slikt så drar vi ganske kraftig (jeg er jo ganske kraftig, så det sier seg selv :wink: )
Hvor mange kilo tåler den før den blir degradert til cat3?
Mvh
Detail checklist
Never pull CAT5 wire with more than 25 pounds of force.
Never step on or otherwise crush, kink, or crimp the wire (don't make staples or wire ties tight).
Never put a staple through the wire (you knew that, I'll bet).
Avoid periodic sags; if the cable must sag, vary the intervals.
Never bend CAT5 wire tightly around a corner; make sure it bends gradually, so that a whole circle would be at least 2" across. Watch especially when the wire comes out a drilled hole and turns; don't let knots or kinks happen even temporarily.
Don't put so many wires in any conduits that it ends up more than 40% full.
Never untwist the 2 wires in a single pair for more than 1/3-1/2" to make a connection (the twists are critical to cancel out interference between the wires).
Never run the wire parallel to power wiring nearer than 6" away.
No run (hub to device) may be over 100 meters long (if you had a 100-meter long house, you'd be hiring this done anyway!).
