graks Skrevet 20. desember 2006 Del Skrevet 20. desember 2006 jeg har tatt med min xbox360 hjem til jul,men når jeg trykker på power knappen får jeg rødt lys i steden for grønnt lys.hva kan være feil? Lenke til kommentar
Stig_W Skrevet 20. desember 2006 Del Skrevet 20. desember 2006 Fra Microsofts support side: Xbox 360: The power supply light is red SYMPTOMS The Xbox 360 power supply light is red. CAUSE A fault has been detected in the external power supply. Back to the top THINGS TO TRY. Check to make sure that the power cord is plugged directly into a known good wall outlet, and not plugged into an extension cord, surge protector, or power strip. 2. Try the power supply in a different wall outlet, ideally in another part of the house. To do this, follow these steps: a. Turn off the console. b. Disconnect the cord that connects the power supply to the console. c. Unplug the power cord from the wall socket. d. Disconnect the power cord from the power supply. 3. Allow the power supply to cool for several hours. The red light may indicate that the power supply has overheated. The power supply should turn back on after it cools. Make sure that the power supply has sufficient ventilation during cooling. Do not try to turn on the console while the power supply is cooling. 4. If the light on the power supply remains red after you follow these troubleshooting steps, the power supply needs service. Back to the top MORE INFORMATION The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply can turn itself off in conditions of too much current, too-high voltage, or too-high temperature. Under these conditions, the light on the power supply will turn from green to orange or to red, or the light will turn off. When the power supply light is green, the power supply is functioning correctly. • Follow these safeguards to help the power supply work: • Do not block any ventilation openings in the power supply. • Do not put the power supply on a bed, on a sofa, or on any other soft surface that may block ventilation openings. • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated. • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register. • Plug the power supply directly into a known good wall outlet. Do not use extension cords or power strips. Lenke til kommentar
graks Skrevet 20. desember 2006 Forfatter Del Skrevet 20. desember 2006 fant ut hva det var.måtte bare switch om på kabelen fra hdtv til vanlig tv som det tv jeg spiller på hjemme i jula. Lenke til kommentar
