par småproblemer med ubuntu
ZeS
Har du veldig treg linje eller bruker du den sentrale ubuntuserveren?
Det går kanskje litt raskere dersom du bruker den norske serveren (NTNU). Da legger man til 'no.' rett etter http:// i sources.list
Slik ser min /etc/apt/sources.list ut:
Klikk for å se/fjerne innholdet nedenfor
## Add comments (##) in front of any line to remove it from being checked.
## Use the following sources.list at your own risk.
deb http://no.archive.ubuntu.com/ubuntu/ edgy main restricted universe multiverse
deb-src http://no.archive.ubuntu.com/ubuntu/ edgy main restricted universe multiverse
## MAJOR BUG FIX UPDATES produced after the final release
deb http://no.archive.ubuntu.com/ubuntu/ edgy-updates main restricted universe multiverse
deb-src http://no.archive.ubuntu.com/ubuntu/ edgy-updates main restricted universe multiverse
## UBUNTU SECURITY UPDATES
deb http://security.ubuntu.com/ubuntu/ edgy-security main restricted universe multiverse
deb-src http://security.ubuntu.com/ubuntu/ edgy-security main restricted universe multiverse
## BACKPORTS REPOSITORY (Unsupported. May contain illegal packages. Use at own risk.)
deb http://no.archive.ubuntu.com/ubuntu/ edgy-backports main restricted universe multiverse
deb-src http://no.archive.ubuntu.com/ubuntu/ edgy-backports main restricted universe multiverse
## PLF REPOSITORY (Unsupported. May contain illegal packages. Use at own risk.)
# deb http://packages.freecontrib.org/plf/ dapper free non-free
# deb-src http://packages.freecontrib.org/plf/ dapper free non-free
## CANONICAL COMMERCIAL REPOSITORY (Hosted on Canonical servers, not Ubuntu
## servers. RealPlayer10, Opera and more to come.)
# deb http://archive.canonical.com/ubuntu/ dapper-commercial main
## Beryl
deb http://wine.budgetdedicated.com/apt edgy main
deb-src http://wine.budgetdedicated.com/apt edgy main
deb http://download.tuxfamily.org/3v1deb edgy beryl-svn
# deb http://ubuntu.beryl-project.org/ edgy main
(Jeg laster ned i 2Mbyte/sek fra NTNU).
Edit: IKKE avbryt den allerede pågående oppdateringen. Da vil du få en del problemer. - Ingen problemer er uopprettelige, men problemer er ikke morro.
Endret av HavarN
*snip*
7517091[/snapback]
laster fra sentrale ubuntuserveren ja, men er ikke no problem, for laster fullt ut det linja mi klarer uansett. 120kbit :w00t::w00t: telenor 1500kbit@7-800ish ftl
edit: en ting til: når jeg prøver å kjøre ./configure til div programmer får jeg error om at den ikke finner noen kompatibel C compiler(copypaster error når aptitude distro-upgrade er klar). løsning?
EDIT2: kjørt ferdig distro-upgrade nå, får fortsatt samme feilmeldinger i synaptic
Endret av ZeS
får fortsatt
This installation run will require temporarily removing the essential package e2fsprogs due to a Conflicts/Pre-Depends loop. This is often bad, but if you really want to do it, activate the APT::Force-LoopBreak option.Internal Error, Could not early remove e2fsprogs
når jeg prøver å installere/update/remove noe med synaptic... hva må jeg disable og hva er kommandoen for det?
EDIT: har du 16mbit linje HavarN? gief plix :p
Endret av ZeS
Jeg har faktisk 100MBits + 20Mbits (to linjer) :evil:
Har du prøvd å kjøre dselect da?
Start med menyvalg nr 1, du trenger trolig ikke å kjøre 0. Deretter følger du menyen nedover og kjører alle menyvalgene.
sudo dselect
7520201[/snapback]
EDIT: gidder ikke mere :p laster ned edgy iso nå.. 2timer så er den klar :)
Endret av ZeS
dselect funket altså ikke?
Dersom du ikke har mye du må ta backup av så er nok det enkleste utvilsomt å installere edgy fra en edgy-cd, ja ;)
7520537[/snapback]
dselect spamma seg selv i hjel med error's :p
ingenting viktig på laptopen uansett :) så får vi se om jeg får noe sving på edgy cd'n da ;)
Hvis du skal kompilere og installere programmer fra kildekode og ikke bruke ferdige pakker fra Synaptic/pakkehåndteren kan du installere det meste av GNU-verktøyene du trenger for dette (C++-kompilatoren g++, C-kompilatoren gcc, C-bibliotek libc6-dev, linkeren ld, verktøyet make m.fl.) ved å installere samle-pakken build-essential, og kanskje vil programmet du skal kompilere kreve at du også har de såkalte header-filene (.h-filene) til Linux-kjernen, så da kan du også prøve å installere pakken linux-kernel-headers.
Enten
sudo aptitude install build-essential linux-kernel-headers
eller intaller dem via Synaptic.
Uansett må du nok få fikset pakke-dependency-problemene du har før du får lov til å installere dem.
Har du rebootet maskinen din etter ta du foretok dist-upgrade? (Jeg sier ikke at du bør gjøre det, ting kan kanskje brekke mer enn de allerede er, men jeg bare lurer.)
EDIT: Jeg ser jeg var litt på etterskudd med svaret mitt. Dersom du går for å installere Edgy Eft på scratch, så vil jeg anbefale deg å lage en egen partisjon som du bruker til /home -- om du ikke synes det blir for komplisert, da. Det vil si at du skiller ut alle hjemmekataloger på egen partisjon, slik at du for fremtiden, dersom du skulle ha behov for det, lett kan formatere/installere/herje med GNU+Linux-systemet ditt (f.eks ha flere distroer, men alle bruker samme /home) uten fare for å miste dine dokumenter, bookmarks, mail etc. For eksempel har jeg selv en ext3-partisjon med rota (/) på 15 GB (trenger ikke så mye, bruker bare 4.4 GB), en swap-partisjon og resten av disken til /home (ext3). Dette kan i så fall fikses under installasjonen.
Endret av kommers
