The Ghost Skrevet 25. april 2007 Del Skrevet 25. april 2007 Vil nok tru den er bedre, men så har du jo heatpipe system så da må du ha ny kjøler på SB og mosfet også Lenke til kommentar
Caliber Skrevet 25. april 2007 Del Skrevet 25. april 2007 Vil nok tru den er bedre, men så har du jo heatpipe system så da må du ha ny kjøler på SB og mosfet også 8474218[/snapback] Bare å dra frem dremelen det... Men du har et poeng, absolutt! Lenke til kommentar
kimern9 Skrevet 26. april 2007 Del Skrevet 26. april 2007 Vil nok tru den er bedre, men så har du jo heatpipe system så da må du ha ny kjøler på SB og mosfet også 8474218[/snapback] sb og mosfet? haha hva er det for no... selger de kjølere for det hos netshop? Lenke til kommentar
Intern Skrevet 26. april 2007 Del Skrevet 26. april 2007 SB = Southbridge Mosfet = De små sorte kvadratene som sitter rundt sokkelen med kjøleribber oppå Lenke til kommentar
kimern9 Skrevet 26. april 2007 Del Skrevet 26. april 2007 5. Heat and Overclocking. if you take nothing I say here serious, atleast take this one point and listen for a second. these boards run really.... reaaaaaaaally hot. my Asus board here has heatpipes all over it, but after about 5 minutes of it on, its clear the heatpipes on this board are doing little to nothing for this board. this board should not be run with any form of passive cooling if you intend to overclock. active cooling is a must, and not just for the NB. the SB and PWM area all too get very very hot when running overclocked for long periods of time. to give you an example, how I found this out was.... I was poking around the board with my flashlight looking for some ICS, so I could see if there was a clockgen available for this board. the board was on and running... I tapped the NB heatsink, with my flashlight hand... and I burned my hand. not like alittle warm... I mean burned. at the time, the board was heavily overclocked, and running some high voltages... but no different then any other overclocker would do. to say it was hot, isnt the right word. I've seen boards that run hot in the past... especially after days like the first prescotts. this board makes the prescott look like a ice cube. these boards need far better cooling then I am seeing on them at stock. it might take a hour or so of heavy overclocking or gaming to see what I mean, but touch the heatsink and you will see what I mean. put fans on there, anywhere you can if you overclock. these things need it. Fant det her i The Ghost sin signatur link, (takk ghost)... hvor er det jeg finner kjølere for southbridge og mosfet da, så på kjølerne de solgte på netshop, og der var det bare chipset kjøler og cpu kjøler som går på hovedkortet tror jeg... kan du linke meg til noen brae? Lenke til kommentar
Intern Skrevet 26. april 2007 Del Skrevet 26. april 2007 Jeg har ikke sett noen custom mosfet kjølere enda, men på SB kan du bruke en NB kjøler, så lenge den passer. Undersøk dette med forhandler før du kjøper. Undersøk altså, skruehull på HK og sammenligne med de som skal ned i hullene ved SB på kjøleren. Lenke til kommentar
kimern9 Skrevet 26. april 2007 Del Skrevet 26. april 2007 (endret) Jeg har ikke sett noen custom mosfet kjølere enda, men på SB kan du bruke en NB kjøler, så lenge den passer. Undersøk dette med forhandler før du kjøper. Undersøk altså, skruehull på HK og sammenligne med de som skal ned i hullene ved SB på kjøleren. 8477842[/snapback] Jeg vil ikke ha passiv kjøling ikkesant, trenger vifte for dette hk't. Er en hau med passive kjølere i prisguiden og de med vifter har fått klager på mye bråk... f.eks denne https://prisguiden.no/product.php?productId=27277 Endret 26. april 2007 av kimern9 Lenke til kommentar
Intern Skrevet 26. april 2007 Del Skrevet 26. april 2007 Jeg tør å påstå uten å ha dette kortet selv, at den kjøleren som sitter på er nok. Skulle den ikke være det, kan du putte på en slik. (De er også lette nok til å lime på med termisk lim. Nettopp gjort dette selv på pappas HK.) Lenke til kommentar
kimern9 Skrevet 26. april 2007 Del Skrevet 26. april 2007 (endret) Jeg tør å påstå uten å ha dette kortet selv, at den kjøleren som sitter på er nok. Skulle den ikke være det, kan du putte på en slik. (De er også lette nok til å lime på med termisk lim. Nettopp gjort dette selv på pappas HK.) 8477937[/snapback] leste du quoten min da? fant forresten ett review på andre versjonen av den sprint kjølern som tydeligvis skal være stillere: http://www.rbmods.com/Articles/Thermaltake...e_spirit2/3.php jeg er villig til å betale mer enn 50 kroner, så da går jeg heller for noctua hvis jeg går for passiv.. Endret 26. april 2007 av kimern9 Lenke til kommentar
The Ghost Skrevet 26. april 2007 Del Skrevet 26. april 2007 Vet kun om en Mosfet kjøler som ikke er vann blokk Men den er ikke å finne til salgs none stesder i hele verden, jeg har ikke funnet den Gå inn her og se under mosfet og HR-09 og den som passer er HR-09U ikke HR-09S da den blir for bred (har målt) Lenke til kommentar
kimern9 Skrevet 26. april 2007 Del Skrevet 26. april 2007 Vet kun om en Mosfet kjøler som ikke er vann blokk Men den er ikke å finne til salgs none stesder i hele verden, jeg har ikke funnet den Gå inn her og se under mosfet og HR-09 og den som passer er HR-09U ikke HR-09S da den blir for bred (har målt) 8478058[/snapback] men kan jeg beholde mosfet kjølern på asus striker extreme eller sitter heatpipen på alle delene? Lenke til kommentar
Intern Skrevet 26. april 2007 Del Skrevet 26. april 2007 Heatpipen sitter på alle delene. Jeg tok av heatpipen på mitt P5N32-SLI SE Deluxe i går, og da måtte jeg ta av SB kjøleren også :/ Lenke til kommentar
kimern9 Skrevet 26. april 2007 Del Skrevet 26. april 2007 Heatpipen sitter på alle delene. Jeg tok av heatpipen på mitt P5N32-SLI SE Deluxe i går, og da måtte jeg ta av SB kjøleren også :/ 8478468[/snapback] hva har du på MOSFET'n da? Lenke til kommentar
Intern Skrevet 26. april 2007 Del Skrevet 26. april 2007 Jeg skulle bare rense HK'et for støv osv, siden jeg har fått nytt. Så jeg satte den på igjen. Lenke til kommentar
The Ghost Skrevet 26. april 2007 Del Skrevet 26. april 2007 Du kan jo prøve med Swiftech sine minne kjølere med en vifte over eller noe sånt ..... Lenke til kommentar
snippsat Skrevet 27. april 2007 Del Skrevet 27. april 2007 (endret) Ja det blir en del arbeid med og bytte dette. Så da må vi få se over 500fbs+ Det er ikke problem og kjøre et moderat oc oppsett, uten og bytte kjøler si 9*400 3600mzh Dette opsett kjører du greit 24/7 Min løsning er vifte som blåser på chipsett kjølern. Dette er nok greit opp mot 450fbs. Når vi snakker om 450-500+ Så krever dette en del både av ocklokker og resten. Du bør ha ram som lett gjør 1200mzh Fordi dividers på dette kortet liker runde tall. Du må god tålmodighet. Et par linker du bør lese Den andre posten av kunaak. Snakker om dividers og minne. Her slipper du unna med MYE testing. Kunaak sa i en post at han har brukt 150 timer i bios alene for og forstå kortet(og han er en av de mest efarene oc) Han vil aldrig anbefale kortet viss du er en urfaren oc. Og jeg som bare har ca 50timer i bios (mest med quad fbs problemet) http://www.xtremesystems.org/forums/showthread.php?t=132364 Her er en post av eva2000(dette er et greit 24/7 oppsett uten og bytte noe) http://www.xtremesystems.org/forums/showth...ighlight=qx6700 Lykk til med opsettet. Endret 27. april 2007 av SNIPPSAT Lenke til kommentar
Jan Tore K Skrevet 27. april 2007 Del Skrevet 27. april 2007 (endret) Har oppdaget en viktig ting med 1002-BIOSen, det er mulig at det er slik med tidligere BIOSer og, jeg har ikke sjekket. Memtest kan kjøre fint i 12 timer i strekk mens OS er ustabil på samme timings/volt. Dette gjør at du ikke kan utelukke minneproblemer ved ustabil pc. Jeg må forske litt mer på dette fenomenet, men har ikke tid den nærmeste tida. Skriver dette så folk ikke stoler 100% på memtest med lignende konfig som jeg har. Endret 27. april 2007 av Jan Tore M Lenke til kommentar
snippsat Skrevet 27. april 2007 Del Skrevet 27. april 2007 (endret) Ja det har du helt rett i. For høy volt til minnet vil fint passere 12 timer i memtest. Minnet vil alikevel gi problemer(bluscreen frys lås) Prøv og kjør så lavt som mulig. Husk kun 0.2v kan gjøre stor forskjell. Dette er veldig viktig for 680i Jeg kjører 100% stablit på 4gb. Måtte gå ned til 2.075v i bios dette gir 2.1v Kun litt over 2.1v blir det ustabilt Men vil gå uten problemer 2.25v i memtest kjører nå 5.5.5.5.15 1066 2.1v Endret 27. april 2007 av SNIPPSAT Lenke til kommentar
The Ghost Skrevet 27. april 2007 Del Skrevet 27. april 2007 Bare en liten ting. Vi med PLUSS versonene skal vi bruke same drivere og BIOS som non PLUSS versonen ? Lenke til kommentar
snippsat Skrevet 27. april 2007 Del Skrevet 27. april 2007 Bios er ikke samme plus er på 0602 Ikke plus er på 1002. Driver tror er det samme. Det er vel bare og gå på asus sin side og sammenlingne. Lenke til kommentar
