Hvem fant opp "ALT"?
(Min første tanke er at dette har blitt diskutert en del ganger fra før i PRS. ;) )
Videre vil nok de religiøse hevde at guden/skaperen er så mystisk at det per definisjon er umulig å fullt ut forstå eller beskrive vedkommende. Jeg på min side, går et hakk ned og sier akkurat det samme om naturen/universet i seg selv.
De religiøse har fått "rettighetene" til å spre ideene sine gjennom utallige hellige kriger, korstog, misjonering, heksebrenning, inkvisasjoner, presteskap osv. gjennom historien. Med andre ord; gjennom vold og undertrykkelse. :(
Endret av Royo
To create the universe in seven days, MacGyver used a string, a paper clip and a pen. As there were no humans present at the time, the means for which he did it are still unknown.
Og teoriene bak
# The universe is constructed of four basic elements: Duct tape, paper clips, toilet paper and string. These are exclusive and non-commutative, the upshot of which is that they represent the few materials that MacGyver is unable to simply construct.
# There is a Swiss army knife in the centre of our galaxy.
# In String Theory, rather than being composed of zero-dimensional points, the universe is composed of one-dimensional strings which wind through space and time. However, in MacGyver's Tape Theory, the universe is constructed of two-dimensional tapes, silver on one side and sticky on the other, which wind through space and time. The heart of every hadron, boson and quark is a tiny ball of duct tape. Likewise, in Duct Tape Theory, the action of gravity and nuclear forces can be explained by multidimensional tapes binding together the particles of the universe. Because everything in the universe is composed of duct tape, Tape Theory explains how MacGyver is able to use Duct Tape to create so many different items.
Kilde : Uncyclopedia
Det fins ikke noe fasit svar på dette.
Blir bare tanker om det.
Men min mening er at alt handler om å tro når det kommer til religiøse spørsmål utviklingen etc.
Man kan sitte å motargumentere hverandre i lange tider.
7451374[/snapback]
Vel. Fasit-svaret finnes. Det er bare oss mennesker som er så begrenset å våre evner at vi (aller mest sannsynlig) aldri vil få tak på det.
Alt handler strengt tatt om tro, bortsett fra det faktum at du ekstisterer et eller annet sted, i et eller annet.
Sant så sant, bare en som vet fasitsvaret i det tilfelle da :thumbup:
La oss nå si at det finnes en gud, og gud har skapt verden osv. Noen må jo ha skapt gud, og noen må jo ha skapt den som skapte gud? Hvem har liksom fått "rettighetene" til å bestemme alt som skal eksistere?
Det er vidt kjent at verden er resultatet av en liten "min tiss er større en din tiss"-stil konkurranse mellom den hellige to-het, Chuck Norris og MacGyver. Teologer har kommet til at en av reglene var at de skulle bruke deler av den andres kreasjon for å overgå den andre med en ny kreasjon.
Skapelsen fant sted etter at MacGyver hadde skapt the A-team med kun gaffa-teip, pakkestrips og krutt (Norris hadde akkurat skapt våpen)
Ydmykelsen ved å ikke skape the A-team ble enda større fordi Mr.T umiddelbart utbrøt: "I pity the fool who don't create the A-team!"
I raseri grep CHuck Norris setningen fra Mr.T ut av løse luften og roundhouse sparket den med sitt hardeste roundhouse spark (noe fysikere mener er umulig i vår verden; kraften bak dette sparket ville rive rom/tids kontiniumet i filler)
Sparket kompinerte kulheten og badass-heten av både Chuck Norris og Mr.T til en kritisk masse som resulterte i the Big Bang. MacGuyver erklærte at han hadde tapt, the A-team fikk låne sofan til MacGuyver i påvente av Vietnamkrigen og Chuck Norris bestemte seg for å skape evolusjonsteorien for å kunne erte Darwin senere (se boka: "There is no theory of evolution. Just a list of animals Chuck Norris allows to live.")
