bmw-m5 Skrevet 7. desember 2006 Del Skrevet 7. desember 2006 Jeg er helt nybegynner med Ubuntu og har faktisk greid å innstalere AVG for Linux (stolt av meg selv ) men lurer litt på hvordan jeg avinnstalerer dette programmet? Noen smarte hjerner her som kan gi meg en grei forklaring/fremgangsmåte? Lenke til kommentar
A!1 Skrevet 7. desember 2006 Del Skrevet 7. desember 2006 Hvordan installerte du det? Kan du skrive dpkg -l | grep avg i en terminal og poste output her? Lenke til kommentar
bmw-m5 Skrevet 7. desember 2006 Forfatter Del Skrevet 7. desember 2006 Hvordan installerte du det? Kan du skrive dpkg -l | grep avg i en terminal og poste output her? 7445390[/snapback] Firstly this is a workaround due to the fact AVG only comes as a .rpm package, ubuntu uses .deb packages 1. Download AVG .rpm package from http://free.grisoft.com/softw/70free/setup...-a0757.i386.rpm and save it to your Desktop. (Right click on link and choose Download Link) 2. Now we need some extra libs to get it to work, open the terminal: Code: sudo apt-get install alien libstdc++2.10-glibc2.2 python2.4-glade2 python2.4-gtk2 libgtk2.0-dev 3. Even though AVG is free (as in beer) it still need you to get a registration number. It can be done like this Code: cd Desktop rpm -qip --scripts avg71flm-r28-a0757.i386.rpm Find where it says 70FREE-TX-IB-P1-C01-S139FC-327-9FPB the numbers are different from each time you install avg. 4. Installing AVG: Code: sudo alien --scripts avg71flm-r28-a0757.i386.rpm sudo dpkg -i avg71flm_r28-1_i386.deb 5. Now to the registration of AVG: Code: sudo /opt/grisoft/avggui/bin/avggui_update_licinfo.sh sudo avgscan -register 6. AVG needs to make a folder and save some files at your home folder: Code: avggui & Close AVG again. 7. Now we need an avg launcher in the application tab, there's two ways a) if you want to launch avg as root (the update button works then in AVG) or b) as normal user. a)Code: sudo gedit /usr/share/applications/avg.desktop add: Quote: [Desktop Entry] Name=AVG Antivirus Comment=Antivirus Exec=gksudo avggui & Icon=/opt/grisoft/avggui/prog/pixmaps/avgico_big.png Terminal=false Type=Application Categories=Application;System; save and exit. b)Code: sudo gedit /usr/share/applications/avg.desktop add: Quote: [Desktop Entry] Name=AVG Antivirus Comment=Antivirus Exec=avggui & Icon=/opt/grisoft/avggui/prog/pixmaps/avgico_big.png Terminal=false Type=Application Categories=Application;System; save and exit. If you're using the b) you need also an update launcher: Code: sudo gedit /usr/share/applications/avgupdate.desktop add: Quote: [Desktop Entry] Name=AVG Updater Comment=Antivirus Exec=sudo /opt/grisoft/avg7/bin/avgupdate -o Icon=/opt/grisoft/avggui/prog/pixmaps/avgupdateico.png Terminal=true Type=Application Categories=Application;System; save and exit. Lenke til kommentar
bmw-m5 Skrevet 7. desember 2006 Forfatter Del Skrevet 7. desember 2006 Hvordan installerte du det? Kan du skrive dpkg -l | grep avg i en terminal og poste output her? 7445390[/snapback] Output: ii avg71flm r28-1 AVG 7.1 Anti-Virus Workstation for Linux ikt2006@ikt2006-desktop:~$ AVG er IKKE avinnstalert Lenke til kommentar
A!1 Skrevet 7. desember 2006 Del Skrevet 7. desember 2006 Output:ii avg71flm r28-1 AVG 7.1 Anti-Virus Workstation for Linux 7445820[/snapback] sudo dpkg --remove avg71flm Så skal de være gjort. Lenke til kommentar
bmw-m5 Skrevet 7. desember 2006 Forfatter Del Skrevet 7. desember 2006 Output:ii avg71flm r28-1 AVG 7.1 Anti-Virus Workstation for Linux 7445820[/snapback] sudo dpkg --remove avg71flm Så skal de være gjort. 7445830[/snapback] Tusen takk! Da var den borte! Lenke til kommentar
