Socket, merkelig feilmld
Warning: Unknown: failed to open stream: Permission denied in Unknown on line 0
Warning: Unknown: Failed opening '/var/www/trrunde/socket.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in Unknown on line 0
i php filen har jeg skrevet:
<?php
$fp=fsockopen("http://localhost/trrunde/coppermine/login.php?referer=index.php",80, $errno,$errstr,30) or die("faen i helvete");
sendToHost('localhost','post','/trrunde/coppermine/index.php?referer=index.php','param=First+Param&second=Second+param');
/* sendToHost
* Params:
*   $host      - Just the hostname.  No http:// or
                 /path/to/file.html portions
*   $method    - get or post, case-insensitive
*   $path      - The /path/to/file.html part
*   $data      - The query string, without initial question mark
*   $useragent - If true, 'MSIE' will be sent as
                 the User-Agent (optional)
* Examples:
*   sendToHost('www.google.com','get','/search','q=php_imlib');
*   sendToHost('www.example.com','post','/some_script.cgi',
*              'param=First+Param&second=Second+param');
function sendToHost($host,$method,$path,$data,$useragent=0)
   // Supply a default method of GET if the one passed was empty
   if (empty($method)) {
       $method = 'GET';
   $method = strtoupper($method);
   $fp = fsockopen($host, 80);
   if ($method == 'GET') {
       $path .= '?' . $data;
   fputs($fp, "$method $path HTTP/1.1\r\n");
   fputs($fp, "Host: $host\r\n");
   fputs($fp,"Content-type: application/x-www-form- urlencoded\r\n");
   fputs($fp, "Content-length: " . strlen($data) . "\r\n");
   if ($useragent) {
       fputs($fp, "User-Agent: MSIE\r\n");
   fputs($fp, "Connection: close\r\n\r\n");
   if ($method == 'POST') {
       fputs($fp, $data);
   while (!feof($fp)) {
       $buf .= fgets($fp,128);
   fclose($fp);
   return $buf;
Fant en ferdig kode også, men kommer akkuratt samme feilmld!! Vet noen hva som er galt?
<?php
$method="post";
$host="localhost";
$path="/trrunde/coppermine/login.php?referer=index.php";
$data="username=trrunde&password=passordet";
$fp=fsockopen($host,80);
fputs($fp, $data);
$http_response = fgets( $fp, 80 );
echo $http_response;
Når jeg kjører denne så virker det som den henger seg helt, vet noen hvorfor?
Du har en merkelig rekkefølge på de linjene i programmet ditt.
Det som skjer er at serveren forventer et dobbelt sett med linjeskift (\r\n\r\n), før den kan sende noe tilbake. Etter at du har sendt post data, så setter du i gang å vente på en respons du aldri får, fordi du har glemt å sende de linjeskiftene jeg snakket om. Hvis man ser litt lenger ned så sender du noe connection close greier med dobbelt linjeskift bak, men programmet kommer seg aldri dit som du kanskje har skjønt.
Riktig rekkefølge på linjene blir:
PHP
<?php
$method="POST";
$host="localhost";
fputs($fp"$method $path HTTP/1.1\r\n");
fputs($fp"Host: $host\r\n");
fputs($fp"Content-type: application/x-www-form- urlencoded\r\n");
fputs($fp"Content-length: " strlen($data) . "\r\n");
fputs($fp"Connection: close\r\n\r\n");
fputs($fp$data);
$http_response fgets$fp80 );
//Hvis responsen blir av en viss lengde, er det en idé å skifte ut med noe lignende det under.
//Da er du garantert å få med alt.
$http_response = '';
while(!feof($fp)) {
$http_response .= fgets( $fp, 128 );
fclose($fp);
Håper du får det til å virke nå.
