pcie x16 blir x1 når eg overklokker cpu!
Er ganske ny når det gjelder overklokking!
Men eg vett så pass att PCIE x16 skjermkortet mitt ikkje skal gå ned til x1!
Hva kan det verr eg gjør feil?
CPU: Intel Core 2 Duo E6400
RAM: OCZ DDR2 1024MB Platinum XTC Dual Ch. PC2-6400 2x512MB 800MHz
Skjermkort: MSI GeForce 7900GTO
Hovedkort: Asus P5B DLX/WIFI-AP
Kjører dette oppsettet for og nå 3.2ghz!
Klikk for å se/fjerne innholdet nedenfor
BIOS-versjon: 0804
AI Tuning:Manual
CPU Frequency:401
DRAM Frequency:802
PCI Express Frequeny:101
PCI Clock Synchronization Mode:33.33MHz
Spread Spectrum:Disabled
Memory Voltage:2.1v
CPU VCore Voltage:1.4v
FSB Termination Voltage:Max
NB Core:Max
SB Core (SATA,PCI E):Auto
ICH Chipset Voltage:Auto
Modify Ratio Support:Enabled
Ratio CMOS Setting:8
C1E Support:Disabled
Max CPUID Value Limit:Disabled
Vanderpool Technology:Enabled Får ikke Disabled
CPU TM Function:Disabled
Execute Disable Bit:Enabled
PECI:Disabled
Memory Remap Feature:Disabled
Configure DRAM Timing by SPD:Disabled
DRAM CAS# Latency:5
DRAM RAS# to CAS# Delay:5
DRAM RAS# Precharge:5
DRAM RAS# Activate tp Precharge:15
DRAM Write Recovery Time:4
DRAM TRFC:35
DRAM TRRD:10
Rank Write to Read Delay:10
Read to Precharge Delay:10
Write to Precharge Delay:10
Static Read Control:Disabled
Initiate Graphic Adapter:PEG/PCI
