Får du ikke startet Help and Support i win2003?
Har en løsning som funket for meg som lyder slik:
Go to Start/Run and type in: regsvr32 HHCTRL.OCX\par
\par
If that doesn't help, more info:\par
\par
This issue can occur if one or more of the PCHealth components in your computer are damaged. To resolve this issue: \par
\par
1. It is important to note if you have recently made alterations to your computer before this problem occurred, or if the Help and Support \par
Center ever worked correctly. If you have recently made alterations to your computer before this problem occurred, try to undo the changes\par
you made or uninstall the hardware or software that could have caused the issue. After you do so, test to determine if the issue is resolved, \par
and if it is, skip the remaining steps. If the issue is not resolved, continue to the next step. \par
\par
2. Remove the .cab files from the Packagestore folder, and then rebuild the original Help and Support Center: \par
\par
a. Click Start, click Run, type "cmd" (without the quotation marks), and then click OK to open a command prompt. \par
Type "net stop helpsvc" (without the quotation marks), and then press ENTER. \par
b. Type "cd /d windir\\pchealth\\helpctr" (without the quotation marks), where windir is the Windows folder, and then press ENTER.\par
c. Type "rd packagestore /s /q" (without the quotation marks), and then press ENTER. \par
d. Type "cd binaries" (without the quotation marks), and then press ENTER. \par
e. Type "start /w helpsvc /svchost netsvcs /regserver /install" (without the quotation marks), and then press ENTER. \par
f. If any of the following processes are running, stop them: helpsvc.exe helphost.exe helpctr.exe \par
\par
NB! Under punkt b. måtte jeg endre til c:\ og windows mappen
Jeg stoppet ingen prosesser her, men det funket alikevel! Trengte ikke fortsette men slenger med resten av teksten jeg kom over i mitt søk på løsning:
i. At the command prompt, type "net start helpsvc" (without the quotation marks), and then press ENTER. NOTE: The preceding procedure should not negatively affect an OEM-customized Help and Support Center. \par
\par
However, it does remove any other .cab files from the Packstorage folder, such as the Windows XP support tools (which adds their table of contents into the Help and Support Center). \par
\par
4. If the preceding steps do not resolve the issue, use the Windows XP CD-ROM to start your computer, and then run a repair (in-place upgrade) installation. \par
\par
Steven Liu \par
\par
This edit resets the proper keys to invoke Help and Support, depending on your issues. Click here.\par
\par
This script repairs Windows Help and Support if you have run any Reg Cleaners:\par
Repairs Windows\'ae XP Help and Support after running Easy Cleaner or similar registry cleaners.\par
\par
Note: If you have used Easy Cleaner, there is a workaround that prevents Help and Support from becoming corrupt: In the options, add Help to the Skip List. \par
http://personal.inet.fi/business/toniarts\par
\par
Start Menu/Help and Support doesn't work: Go to Start/Run and type in: helpctr -regserver and Start/Run/CMD: regsvr32 /u hhctrl.ocx.\par
\par
To reinstall Help and Support: Go to C:\\Windows\\inf\\pchealth.inf. Right click and choose install. Have your CD handy.\par
\par
Note: The folder is hidden by default. Go to Start/Run and type in: control folders. View: Show hidden files and folders and uncheck Hide extensions for known file types.\par
\par
"Could not start the Help and Support Service on Local Computer. Error 126: The specified module could not be found" Restore Help and Support Service. Restore Help and Support Service Keys.\par
\par
Also, make sure that the Help and Support Service is running. Go to Start/Run and type in: services.msc. From there scroll down to Help and Support and make sure the service is set to Automatic and is Started. \par
\par
If the option is greyed out or Help and Support Service is not listed trying running these two edits. \par
\par
You may also opt to running the System File Checker. To do so, go to Start/Run/CMD and type in: SFC /Scannow. This option forces Windows to scan all protected system files immediately. \par
\par
Restore winhlp32.exe for XP or XPSP1 (Line 57)\par
http://www.kellys-korner-xp.com/xp_tweaks.htm\par
\par
After installing SP1 for some users the correct version of win32hlp.exe is not properly placed in the System32 folder. If this is the case replace the older version with the version found in windows\\ServicePackFiles\\i386.\par
\par
Another option to the above:\par
\par
1. Insert the Windows XP installation CD into your CD-ROM.\par
2. Browse to your CD-ROM and change the folder to \\I386\par
3. Copy the following files into a temporary folder on your hard disk:\par
\par
Winhlp32.cn_\par
Winhlp32.ex_\par
Winhlp32.hl_\par
\par
4. Click Start->Run, type CMD and then press Enter.\par
5. Change to the temporary folder where you stored the Winhlp32 files.\par
6. Type the following commands:\par
\par
EXPAND WINHLP32.CN_ WINHLP32.CNT\par
EXPAND WINHLP32.EX_ WINHLP32.EXE\par
EXPAND WINHLP32.HL_ WINHLP32.HLP\par
\par
7. Copy Winhlp32.exe to your \\%SYSTEMROOT%\\ folder. \par
8. Copy the Winhlp32.cnt, and Winhlp32.hlp to the \\%SYSTEMROOT%\\Help\\folder.\par
9. Typically this folder is C:\\Windows.\par
10. Delete the contents of your temporary folder.\par
\par
Checkpoint: Help and Support Won't Expand\par
\par
Go to Start/Run/Regedit and navigate to this key:\par
\par
HKEY_LOCAL_MACHINE\\System\\CurrentControlSet\\Control\\Session Manager\\Environment. In the right pane, verify that the windir value is REG_EXPAND_SZ and not a REG_SZ type. If not, change it.\par
\par
Tip: If you want to view only the locally stored Windows XP Help documentation in the Classic View: Go to Start/Run and type in: hh windows.chm\par
\par
Check the default values for these registry keys to make sure that they match. Registry keys and values to fix XP's Help and Support after running Toni Arts EasyCleaner. \par
\par
HKEY_LOCAL_MACHINE\\Software\\CLASSES\\TypeLib\\\{FC7D9E00-3F9E-11D3-93C0-00C04F72DAF7\}\\1.0\\0\\win32\par
Default value: C:\\WINDOWS\\PCHealth\\HelpCtr\\Binaries\\HelpCtr.exe\\1\par
\par
HKEY_LOCAL_MACHINE\\Software\\CLASSES\\TypeLib\\\{FC7D9E00-3F9E-11D3-93C0-00C04F72DAF7\}\\1.0\\HELPDIR\par
Default value: C:\\WINDOWS\\PCHealth\\HelpCtr\\Binaries\\HelpCtr.exe\\\par
\par
HKEY_LOCAL_MACHINE\\Software\\CLASSES\\TypeLib\\\{FC7D9000-3F9E-11D3-93C0-00C04F72DAF7\}\\1.0\\0\\win32\par
Default Value: C:\\WINDOWS\\PCHealth\\HelpCtr\\Binaries\\HelpCtr.exe\\2\par
\par
HKEY_LOCAL_MACHINE\\Software\\CLASSES\\TypeLib\\\{FC7D9000-3F9E-11D3-93C0-00C04F72DAF7\}\\1.0\\HELPDIR\par
\par
Help and Support - Did you know not working...\par
\par
Delete the following file. C:\\WINDOWS\\PCHEALTH\\HELPCTR\\Config\\News\\newsver.xml\par
\par
Help and Support - Start Menu Doesn't Work\par
\par
Go to Start/Run and type in: helpctr -regserver\par
\par
Help and Support - Text is missing\par
\par
Some themes can knock out the text in help and switching to another custom theme may not correct it. Switching back to an original XP theme - so far - will set things right again.\par
\par
Windows XP Security Patch: Flaw in Windows XP Help and Support Center Could Enable File Deletion \par
http://www.microsoft.com/Downloads/Release...=43681\par
\par
The above patch resolves the "Flaw in Windows XP Help and Support Center Could Enable File Deletion" vulnerability in Windows XP. Download now to prevent an attacker from deleting files on another user\rquote s computer, via either a Web site or an e-mail. \par
\par
\par
More information on troubleshooting Help and Support, customizing and other extra issues can be found here:\par
\par
Troubleshooting Help and Support\par
http://www.kellys-korner-xp.com/xp_h.htm#h&s\par
\par
Help, CHM, HH Checker/Fixer (Line 141)\par
\par
Helpctr.exe not responding - Go to Start/Run and type in: Helpctr.exe. \par
For some users this has restored the functionality in the Start Menu.\par
\par
\par
If the above didn't help:\par
\par
Check your settings here: Go to Start/Run/Regedit and navigate to this key:\par
\par
HKEY_LOCAL_MACHINE\\System\\CurrentControlSet\\Control\\Session\par
Manager\\Environment\par
\par
In the right pane if windir is listed under type as REG_SZ, it needs \par
to be changed to REG_EXPAND_SZ, Value Data: C\\Windows.\par
\par
If this is the case:\par
\par
Go to: HKEY_LOCAL_MACHINE\\System\\CurrentControlSet\\Control\\Session Manager\\Environment\par
\par
Right click on Environment, then choose Export, name it and save it. Then go to the right pane, right click in an empty area and choose New/Expandable String Value. Name it windir. Then double click it and under Value data, type in: C:\\WINDOWS\par
\par
From there, right click and delete the windir which type was listed as REG_SZ then hit refresh (F5\par
Løsningen er egentlig beregnet for XP men funket altså fint for meg på Win2003.
Endret av Master Chiun
