superwoman Skrevet 17. november 2002 Del Skrevet 17. november 2002 hey!! vi har et lite problem, kordan i faan finner man ut koden på døra i brookhaven hospital i 3 etasje! vi har prøvd koden som sto på papp biten i skrivemaskinen,men den stemte ikke! æ har sotte med det problemet i 3 laaaange tima no! nån som kan hjelpe mæ please? _________________ du må ikke tro at du kjenner mæ fordi du har sett mæ på film?! =) [ Denne Melding var redigert av: bic-judge på 2002-11-18 08:42 ] Lenke til kommentar
Gorthaur Skrevet 18. november 2002 Del Skrevet 18. november 2002 Har ikke prøvd spillet selv, men visst du bare søker litt, så er det ikke så vanskelig. Prøv denne: http://www.dvdhouseofhorror.com/silent_hil...walkthrough.htm Visst du ikke finner det: "BROOKHAVEN HOSPITAL =================== Hospitals... brings back [uN]lovely memories, especially in SH1 and RE3. To the left is a Hospital Map- you'll need it like all the maps thus far. If you want to save, there's a red slab in the Reception Office. Head to the Document Room, via the Reception Room. There's a Purple Bull Key by the typewriter. Read the journal nearby, too. Using the map, find the staircase so we can go to Floor 2. Head inside the Women's Locker Room. Examine the bear for a Bent Needle. The Shotgun is in the nearby locker. Head inside the Men's Locker Room. Inside the Exam Room Key. Go back downstairs and unlock the Examination Room. Head to the Doctor's Lounge for very important Shotgun Shells. Travel to 2F again. Head into Exam Room 3. Grab the First Aid Kit. Check the typewriter for a VERY, VERY important code. JOT IT DOWN ON PAPER, because it is random! Head into the room called M2 and grab the Lapis Eye Key. The Shotgun Shells nearby are a needed item for the boss at the end of this section. Head into M3 for Handgun Bullets and a Health Drink. M6 has Shotgun Shells and a Health Drink. Head to Floor 3. Go to the door leading to the hallway with the "S" Rooms. You need a code. That code is 7335 on Easy and Normal Riddle Modes and 1328 on Hard. To find this out, read a memo in the First Floor Exam Room. Head to Room S3. Maria will leave James' side. There's a key nearby. Grab the Roof Key. Head over to the roof, via the staircase. Use the Roof Key to unlock it. On top is a diary. Read it if you want. [NOTE: I hear the if you read the diary, you get a certain ending. I have not confirmed this, but it seems very likely. Stand around it if you don't want to hear it. Stand for a few moments and then try heading out.] As you head back in, something will be blocking the door. Pyramid Head, from the Blue Creek Apartments, has returned. After a scene, you'll be back on the third floor, in the Special Treatment Room. Down there, head through the door left of the sign. Inside, read the blood-spattered wall. Try to figure out the code. JOT IT DOWN ON THE SAME PAPER AS THE CODE FROM EARLIER! Head to Floor 2 and check on Maria. Then head to the last door in that hall- S14. Inside, is a box that needs 2 codes and 2 keys to open. Use the Lapis Eye Key and Purple Bull Keys to remove the chains. Now enter the code you got from the typewriter on the right padlock. Enter the code you got from the bloody wall on the left and open the case for... HAIR!!! Ew... Anyway, this took me a damn half-hour to figure out, so I had to refer to my BradyGames Guide for this one! Thanks to BradyGames for the tip! Go to the Shower Room and look at the green slimed faucet. Go to the item screen and combine the hair from the bear with the bent needle. To combine, select the hair and then use the "combine." Now select the bent needle and select "use." You should get an elevator key. Use it on the elevator on Floor 3F. Ride it to Floor 1. Head into Room C3 and talk to Laura. After a few scenes, you are in your second boss battle. Arm the Shotgun! " Lenke til kommentar
