Hvordan fjerne en Trojansk Hest?
Avinstaller MSN fra legg til/fjern programmer
Last ned DrWeb
Kjør drweb-cureit.exe (si ja til å kjøre en express scan)
Når dette er ferdig klikker du på Option -> Change settings.
Under fanearket Scan, fjerner du haken ved Heuristic analysis.
Under fanearket Actions, skal alle punkt under Malware settes til Rename.
Velg partisjon du vil scanne og klikk deretter på den grønne pilen for
å starte scanningen. Velg "yes to all" når det finner noe for første gang.
(Denne kjøringa skal egentlig kjøres i safemode)
Logfile of HijackThis v1.99.1
Scan saved at 20:22:33, on 29.11.2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\SOUNDMAN.EXE
D:\PROGRA~1\Avast4\ashDisp.exe
C:\Programfiler\Java\jre1.5.0_06\bin\jusched.exe
C:\Programfiler\DAEMON Tools\daemon.exe
C:\Programfiler\QuickTime\qttask.exe
I:\iTunesHelper.exe
C:\Programfiler\SUPERAntiSpyware\SUPERAntiSpyware.exe
d:\Programfiler\Avast4\aswUpdSv.exe
d:\Programfiler\Avast4\ashServ.exe
C:\Programfiler\iPod\bin\iPodService.exe
d:\Programfiler\Avast4\ashMaiSv.exe
d:\Programfiler\Avast4\ashWebSv.exe
C:\Documents and Settings\Lars Gaute\Skrivebord\drweb-cureit.exe
C:\Programfiler\Mozilla Firefox\firefox.exe
C:\DOCUME~1\LARSGA~1\LOKALE~1\Temp\RarSFX1\_start.exe
C:\DOCUME~1\LARSGA~1\LOKALE~1\Temp\RarSFX1\cureit.exe
C:\Programfiler\WinRAR\WinRAR.exe
C:\DOCUME~1\LARSGA~1\LOKALE~1\Temp\Rar$EX00.515\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koblinger
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - D:\Programfiler\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [avast!] d:\PROGRA~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Programfiler\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [DAEMON Tools] "C:\Programfiler\DAEMON Tools\daemon.exe" -lang 1033
O4 - HKLM\..\Run: [QuickTime Task] "C:\Programfiler\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "I:\iTunesHelper.exe"
O4 - HKCU\..\Run: [MsnMsgr] "C:\Programfiler\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Programfiler\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Programfiler\Fellesfiler\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = D:\Programfiler\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Programfiler\SUPERAntiSpyware\SASWINLO.dll
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - d:\Programfiler\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - Unknown owner - d:\Programfiler\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - d:\Programfiler\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - d:\Programfiler\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: iPod Service - Apple Computer, Inc. - C:\Programfiler\iPod\bin\iPodService.exe
Det ser ut som at du har fått det samme som bror min og bestefar min fikk på sin pc. Jeg er kvitt det, ingen feilmeldinger som har kommet ihvertfall, men for alt jeg vet kan det hende det ligger igjen noe drit.
888bar var jeg så dum så jeg slettet manuelt fra utforsker, før jeg fjerna den fre legg til/fjern programvare. Den ligger fortsatt som en ekstra bar i IE, men nå uten navn. Slett den fra legg til/fjern først, derette kontroller manuelt.
Fikk du en link over msn som du klikket på?? I såfall er det sannsynligvis det samme. Linken er "forkledd" som et *.jpg bilde, men er egentlig en *.pif fil, snarvei til et dos-program (i følge FireFox). Viruset jeg hansket med åpnet et samtalevindu med hver av kontaktene dine i msn som for øyeblikket var pålogga, som sendte de den samme meldinga, "is that you?" etterfulgt av en lenke. Som man kanskje skjønner ble det da fort spredt! SÅ, ikke klik på mistenkelige linker i msn
I bloggen min har jeg skrevet litt mer detaljert hvordan jeg løste det.
Kort fortalt:
Jeg søkte i utforsker etter files som ble OPPRETTET (de kan godt være endret på i ettertid) på det nøyaktige tidspunktet linken på msn ble klikket på. Deretter fjerna jeg manuelt de filene jeg har satt en rød prikk ved på bildet i bloggen min, se linken.
winstall.exe mener jeg at jeg sletta ved å først avslutte prosessen i oppgavebehandlinga. På den andre pc'n jeg jobba med måtte jeg slette den i sikkermodus. Du må også slette to programfiler ved navn cd.exe og msrr.exe. Det er også ei fjerde programfil du må slette, hva den heter husker jeg ikke nå men det var også en slags bokstavforkorting. Ikonet på den var et vanlig setup-ikon. Du skal finne disse i søket du har gjort, med filer kun oppretta den gitte datoen.
I tillegg: Av innstaller msn, og gå deretter igjennom mappene og slett resten! Jeg slettet også windows-messenger, om det er nødvendig vet jeg imidlertid ikke.
Dette er som sagt det viruset jeg hanska med, det også en trojnsk hest. Om det er det samme som du sliter med vet jeg ikke, men det virka mistenkelig likt.
Scan saved at 20:34:20, on 29.11.2006
Running processes:
I:\iTunesHelper.exe
C:\Documents and Settings\Lars Gaute\Programdata\Microsoft\Internet Explorer\Quick Launch\test.exe.exe
Gamma Loader.exe
(file missing)
(file missing)
SUPERAntiSpyware Scan Log
Generated 11/29/2006 at 08:32 PM
Application Version : 3.3.1020
Core Rules Database Version : 3137
Trace Rules Database Version: 1154
Scan type       : Quick Scan
Total Scan Time : 00:12:50
Memory items scanned      : 368
Memory threats detected   : 0
Registry items scanned    : 525
Registry threats detected : 2
File items scanned        : 12732
File threats detected     : 174
Adware.Tracking Cookie
C:\Documents and Settings\Lars Gaute\Cookies\lars [email protected][2].txt
C:\Documents and Settings\Lars Gaute\Cookies\lars gaute@advertising[1].txt
C:\Documents and Settings\Lars Gaute\Cookies\lars gaute@casalemedia[1].txt
C:\Documents and Settings\Lars Gaute\Cookies\lars gaute@tradedoubler[2].txt
C:\Documents and Settings\Lars Gaute\Cookies\lars gaute@cgi-bin[2].txt
C:\Documents and Settings\Lars Gaute\Cookies\lars [email protected][1].txt
Adware.Toolbar888
HKCR\TypeLib\{569304BA-83ED-4CFF-AC26-BE3E482F7208}
HKCR\Interface\{C6F2214E-0B54-45A9-B90D-7DD4BA45ED0B}
Trojan.Hacktool
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC100\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC101\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC102\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC103\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC104\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC110\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC111\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC112\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC113\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC114\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC115\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC121\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC122\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC125\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC126\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC129\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC130\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC131\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC132\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC133\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC134\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC135\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC136\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC137\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC138\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC139\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC140\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC141\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC142\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC147\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC156\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC159\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC170\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC175\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC184\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC185\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC186\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC187\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC188\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC189\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC190\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC193\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC204\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC205\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC206\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC213\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC220\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC221\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC222\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC224\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC230\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC238\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC257\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC264\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC265\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC266\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC267\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC268\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC270\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC277\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC278\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC279\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC280\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC290\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC306\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC313\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC315\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC316\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC79\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC81\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC82\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC83\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC85\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC88\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC89\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC90\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC91\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC93\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC94\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC95\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC96\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC97\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC98\SYSTEM.DLL
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC99\SYSTEM.DLL
Trojan.Update-Mcboo
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC100\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC101\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC102\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC103\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC104\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC110\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC111\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC112\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC113\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC114\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC115\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC121\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC122\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC125\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC126\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC130\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC131\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC132\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC133\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC134\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC135\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC136\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC137\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC138\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC139\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC140\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC141\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC142\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC147\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC156\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC159\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC170\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC175\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC184\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC185\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC186\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC187\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC188\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC189\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC190\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC193\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC204\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC205\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC206\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC213\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC220\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC221\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC222\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC224\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC230\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC238\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC257\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC264\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC265\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC266\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC267\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC268\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC270\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC277\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC278\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC279\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC280\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC290\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC306\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC313\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC315\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC316\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC79\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC81\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC82\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC83\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC85\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC88\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC89\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC90\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC91\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC93\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC94\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC95\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC96\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC97\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC98\UPDATE.EXE
C:\RECYCLER\S-1-5-21-1482476501-117609710-682003330-1003\DC99\UPDATE.EXE
Generated 11/29/2006 at 09:11 PM
Total Scan Time : 00:13:26
Memory items scanned      : 388
Registry items scanned    : 527
Registry threats detected : 0
File items scanned        : 11808
File threats detected     : 0
