quarkey Skrevet 27. november 2006 Del Skrevet 27. november 2006 God morgen. Jeg har et problem med at OpenGL greier ikke kjøre helt når jeg starter Quake3. Får en error og oppløsningen blir automatisk satt til 640x480. Det funket helt fint før, noen som har peiling på hva jeg kan gjøre? Har prøvd å legge inn drivere og quake inn på nytt. Er ganske blank når det gjelder OpenGL. hehe. Jeg kjører Slackware 11.0 med 2.6.17 kernel. Har lastet ned driverene fra Nvidia sine sider. (NVIDIA-Linux-x86-1.0-9629-pkg1) ---- R_Init ----- ...loading opengl32: QGL_Init: Can't load opengl32 from /etc/ld.so.conf or current dir: /usr/local/games/quake3/opengl32: cannot open shared object file: No such file or directory failed ...loading libGL.so.1: Initializing OpenGL display ...setting mode 6: 1024 768 Using XFree86-VidModeExtension Version 2.2 XFree86-VidModeExtension Activated at 1024x768 Couldn't get a visual ...WARNING: could not set the given mode (6) Initializing OpenGL display ...setting mode 3: 640 480 Using XFree86-VidModeExtension Version 2.2 XFree86-VidModeExtension Activated at 640x480 Couldn't get a visual ...WARNING: could not set the given mode (3) ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- ----- CL_Shutdown ----- ----------------------- Sys_Error: GLimp_Init() - could not load OpenGL subsystem lspci Klikk for å se/fjerne innholdet nedenfor 00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3) 00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev a3) 00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2) 00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2) 00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3) 00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev a2) 00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev a3) 00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev a3) 00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev a2) 00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev a3) 00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3) 00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3) 00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3) 00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3) 00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration 00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map 00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller 00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control 01:00.0 VGA compatible controller: nVidia Corporation NV40 [GeForce 6800 Ultra/GeForce 6800 GT] (rev a2) 05:07.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 07) 05:07.1 Input device controller: Creative Labs SB Live! Game Port (rev 07) 05:0a.0 RAID bus controller: Silicon Image, Inc. SiI 3114 [SATALink/SATARaid] Serial ATA Controller (rev 02) 05:0b.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22/A IEEE-1394a-2000 Controller (PHY/Link) 05:0c.0 Ethernet controller: Marvell Technology Group Ltd. 88E8001 Gigabit Ethernet Controller (rev 13) Tusen takk! Lenke til kommentar
slettet_konto Skrevet 27. november 2006 Del Skrevet 27. november 2006 prøv : glxinfo | grep rendering å paste output Lenke til kommentar
quarkey Skrevet 27. november 2006 Forfatter Del Skrevet 27. november 2006 [11:07:58|kverkeren@Blowfish~]: glxinfo | grep rendering direct rendering: Yes Lenke til kommentar
quarkey Skrevet 28. november 2006 Forfatter Del Skrevet 28. november 2006 rare greier! det funket for 1 uke siden Lenke til kommentar
