Siste Ordet 6 (LES de oppdaterte reglene FØR posting)
darkness|
Gadd ikke compile..
Klikk for å se/fjerne innholdet nedenfor
#include<stdio.h>
#include<string.h>
#include<conio.h>
#include<stdlib.h>
#include<process.h>
#include<graphics.h>
#include<time.h>
#include<dos.h>
#include<dir.h>
#include<fcntl.h>
#include<io.h>
#include<direct.h>
#define clsg closegraph(); restorecrtmode();
void load();
void prog_by();
int find();
main()
clrscr();
textcolor(2);
cprintf("ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»\n\r");
cprintf("º        Velkommen inn!       º\n\r");
cprintf("ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ\n\r");
prog_by();
textcolor(15);
char dir[MAXDIR];
{if (getcurdir(0, dir)) { perror("getcurdir()"); }
int disk=getdisk()+'A';cprintf("%c:\\%s]",disk,dir);} //disk og dir
// typedef OK sg=1;
#define OK  sg=1;
while(1)
   char *in;          // = getchar();
   scanf("%s",&*in);
int sg=0;
if(strcmp( in,"exit")==0||strcmp( in,"EXIT")==0||strcmp( in,"x")==0||strcmp( in,"X")==0){exit(0);}
if(strcmp( in,"tcls")==0||strcmp( in,"TCLS")==0 ){OK clrscr();}
if( strcmp( in,"ver")==0||strcmp( in,"VER")==0)
{ OK prog_by();}
if( strcmp( in,"date")==0||strcmp( in,"DATE")==0)
{OK time_t t;  time(&t); cprintf("\n\rDagens dato %s\n\r",ctime(&t));}
if( strcmp( in,"find")==0||strcmp( in,"FIND")==0)
{OK  find();}
if( strcmp( in,"time")==0||strcmp( in,"TIME")==0){OK struct time t; gettime(&t);
cprintf(" Klokken er : %2d:%02d:%02d.%02d\n\r",
t.ti_hour, t.ti_min, t.ti_sec, t.ti_hund); }
if( strcmp( in,"mkd")==0||strcmp( in,"MKD")==0)
{OK  char *dir;  scanf("%s",&*dir);   int stat;
stat = mkdir(dir);
if (!stat)
cprintf("Katalog opprettet\n\r");
else
{cprintf("Kan ikke opprette katalog\n\r");}
if( strcmp( in,"deld")==0||strcmp( in,"DELD")==0)
{OK  char *dir_name;  scanf("%s",&*dir_name); //system("dir/p");
int stat;
stat = rmdir(dir_name);
if (!stat)
 cprintf("\n\rKatalog slettet\n\r");
else
{cprintf("Kan ikke slette katalog\n\r");}
if( strcmp( in,"a:")==0||strcmp( in,"A:")==0)
{OK // char *dir_name;  scanf("%s",&*dir_name); //system("dir/p");
//int a;scanf("%d",&a);
if ( _chdrive(1) == 0)
cprintf("Du har skiftet til stasjon \n\r");
else
cprintf("Kan ikke skifte til stasjon \n\r");
if( strcmp( in,"c:")==0||strcmp( in,"C:")==0)
if ( _chdrive(3) == 0)
else
if( strcmp( in,"d:")==0||strcmp( in,"D:")==0)
if ( _chdrive(4) == 0)
else
if( strcmp( in,"e:")==0||strcmp( in,"E:")==0)
if ( _chdrive(5) == 0)
else
if( strcmp( in,"mkf")==0||strcmp( in,"MKF")==0)
{ OK
  int handle;
  char *msg; char *path;
cprintf("Skriv inn katalog og filnavn. eks D:\\abc\\test.txt\n\r");
  scanf("%s",&*path);
  if ((handle = open(path, O_CREAT | O_TEXT)) == -1)
     perror("Error:");
     getch();
    // return 1;
  scanf("%s",&*msg);
  write(handle, msg, strlen(msg));
cprintf("Fil lagd %s\n\r",path);
  close(handle);
 // return 0;
if( strcmp( in,"go2d")==0||strcmp( in,"GO2D")==0)
{ OK
cprintf("Skriv inn katalog. eks D:\\abc\n\r");
scanf("%s",&*path);
int result= chdir(path);
if(result==0){ cprintf("Katalog skiftet \n\r");}
else{cprintf("error \n\r");}
if( strcmp( in,"open")==0||strcmp( in,"OPEN")==0)
{ OK
  int result;  char *path;
cprintf("Skriv inn katalog. eg D:\\abc\n\r");
scanf("%s",&*path);
 result = spawnle(P_WAIT,path,NULL,NULL);
  if (result == -1)
  { perror("Error fra spawnle"); }
 if(result==0){ cprintf(" success \n\r");}
//=====================Grafikk===================
if(strcmp( in,"sirkel")==0 )
{OK load();
int x,y,r;scanf("%d%d%d",&x,&y,&r);
circle(x,y,r); getch();clsg restorecrtmode();}
if(strcmp( in,"linje")==0 )
{OK  load();
int x,y,x1,y1;scanf("%d%d%d%d",&x,&y,&x1,&y1);line(x,y,x1,y1);getch();clsg}
if(strcmp( in,"tcolor")==0||strcmp( in,"TCOLOR")==0 ) {OK int a;scanf("%d",&a);textcolor(a);}
if(strcmp( in,"color15")==0 ) {textcolor(15);}
if(strcmp( in,"bkcolor")==0||strcmp( in,"BKCOLOR")==0 ) {OK int a;scanf("%d",&a);textbackground(a);}
if( strcmp( in,"hjelp")==0||( strcmp( in,"HELP")==0))
{ OK
cprintf("ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ\n\r");
cprintf("ÄÄÄÄÄÄÄÄÄAlle kommandoene i OSÄÄÄÄÄÄÄÄÄ\n\r\n\r");
//cprintf(" color\n\r exit\n\r ver\n\r help\n\r cls\n\r time\n\r date\n\r find\n\r cd\n\r");
//cprintf("md\n\r rd\n\r");
//cprintf("\n\r");
cprintf("HJELP  For aa vise alle kommandoene i DemonOS.\n\r");
cprintf("EXIT  For aa gaa ut av programmet.\n\r");
cprintf("DATE  For aa se datoen.\n\r");
cprintf("TIME  For aa se klokken.\n\r");
cprintf("TCLS  For aa fjerne all teksten.\n\r");
cprintf("VER   For aa vise versjonen. \n\r");
cprintf("MKD   For aa lage ny katalog\n\r");
cprintf("DELD  For aa slette en katalog.\n\r");
cprintf("MKF   For aa lage en ny fil\n\r");
cprintf("DELF  For aa slette en fil\n\r");
cprintf("OPEN  For aa aapne en fil\n\r");
cprintf("GO2D  For aa gaa til et annet sted.\n\r");
cprintf("FIND  For aa finne en fil.\n\r");
cprintf("TCOLOR For aa skifte farge paa tekst. eks- TCOLOR 4 ( 1 til 15)\n\r");
cprintf("BKCOLOR For aa skifte bakgrunnsfergen. eks- BKCOLOR 7 ( 1 til 15)\n\r");
//cprintf("\n\r");//cprintf("\n\r");//cprintf("\n\r");
cprintf("ÄÄÄÄÄÄÄÄÄGrafikk kommandoerÄÄÄÄÄÄÄÄÄ\n\r\n\r");
cprintf("LINJE  eks-line 50 300 300 300.\n\r");
cprintf("SIRKEL eks- circle 300 200 100\n\r");
if(sg==0){cprintf("\n\rFeil kommando!");cprintf(" (Skriv HJELP for aa se alle kommandoene)\n\r");}
char dir[MAXDIR];
// cprintf("%c:\\%s]",disk,dir);
//if(strcmp(in,"lor")==0||strcmp( in,"TCOLOR")==0
//strcmp(in,"tcolor")==0||strcmp( in,"TCOLOR")==0
 }//while
}////////////////////////////////////////////////////////end_main()
void load()
  int gdriver = DETECT, gmode, errorcode;
  initgraph(&gdriver, &gmode, "");
  errorcode = graphresult();
  if (errorcode != grOk)
  { clrscr();
  cprintf("Grafikk ERROR: %s\n\r", grapherrormsg(errorcode));
  cprintf(" Press en tast for aa avslutte eller restart programmet.");
  getch();
void prog_by()
cprintf("ßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßßß\n\r");
cprintf("DemonOS  Version 1.0\n\rProgrammert av DemoniZer");
cprintf("\n\rCopyRight -2007- Ludvig Anderssen(c).\n\r");
cprintf("\n\rSkriv - hjelp - for aa se alle kommandoene\n\r");
int find(void)
  struct ffblk ffblk;
  int done;
  char *find;
  cprintf("Finne hva?   eks. D:\\abc\\*.exe\n\r");
  scanf("%s",&*find);
  cprintf("Finner %s\n\r",*find);
  done = findfirst(find,&ffblk,0);
  while (!done)
   cprintf("%s\n\r", ffblk.ff_name);
   done = findnext(&ffblk);
     return 0;
Endret av DemoniZer
Gjest
