Hvordan ta backup av x360 spill
jimmil
Les litt i "Chipping / Modding av Xbox 360", der finner du mye nyttig :)
Legacy information for creating backups.
Extracting Security Sector
Ensue SATA cable is plugged from drive to PC.
(This is very important as may be possible in future for console to detect modified firmware due to Inquiry routine enabled for Windows)
Power on Xbox 360.
Insert Enable0800 DVD into drive. Wait 5 or so seconds then remove the Enable0800 DVD. Drive now in 0800 mode.
Turn on PC and wait for Windows to boot
Insert original game disk into drive and wait for windows to detect disk change
Run DVDinfoPro
Enter the following four custom cdb commands:
AD 00 FF 02 FD FF FE 00 08 00 01 C0
AD 00 FF 02 FD FF FE 00 08 00 03 C0
AD 00 FF 02 FD FF FE 00 08 00 05 C0
AD 00 FF 02 FD FF FE 00 08 00 07 C0
Then save hexadecimal display as bin file as SS.bin
Extracting PFI (Physical Format Information) Sector
Run DVDinfoPro
From Advanced Commands pull down menu choose Send Custom Command
From Preset Commands pull down menu choose "00h Physical Format Information" from under the Read DVD Struct Commands heading
Click Send
Then save hexadecimal display as bin file as PFI.bin
Extracting DMI (Disk Manufacturing Information) Sector
Run DVDinfoPro
From Advanced Commands pull down menu choose "04h Disc Manufacturing Info"
Click OK on Read DVD Structure Option window
Then save hexadecimal display as bin file as DMI.bin
Creating a game backup
Drive is still in 0800 mode.
Extract Isobuilder.rar
Run DVDinfoPro
Enter the following custom cdb command to unlock drive: (game data visable)
FF 08 01 01 05 01 03 00 04 07 (new in MS28)
Run Isobuster
Right click on DVD and select Extract From-To
Click Length and enter number of LBAs as follows:
Xbox 1 Original Number of LBA to read 3431264 decimal
or
Xbox 360 Original Number of LBA to read 3567872 decimal
Select User Data (2048 bytes/block)
Click Start Extraction
Enter filename as game.iso and click Save
Upon read error dialogue box choose fill with blank zeros for sector and select use this selection for all errors
Copy game.iso, ss.bin, PFI.bin and DMI.bin to the relevent isobuilder directory (Depending on Xbox 360 or Xbox 1 game)
Run build360.bat (Xbox 360 game) or build.bat (xbox 1 game).
These batch files now expect PFI and DMI bin files
Burn with CloneCd and choose the image.dvd file
Regner med du allerede vet at du må flashe den med Enable0800 først jeg ;)
