Mala Skrevet 24. november 2006 Del Skrevet 24. november 2006 Og med dette ser vi at mine hint i 2.posten om Monster skepsisen mest sansynlig er korrekt,og det samme som er sagt her har blitt sagt før fleire ganger. Overpriset, og mest sansynlig lite igjen for pengene her i gården. OK? Lenke til kommentar
Penneknekt Skrevet 24. november 2006 Del Skrevet 24. november 2006 Les denne. Morsomt, men tankevekkende: When I was a graduate student I did the simplest possible experiment. I placed a pair of amplifiers on a table: one fancy and expensive, and the other plain and cheap. Both had wires that ran to a switch box. The switch was clearly labeled as to which amp corresponded to which position. Subjects were allowed as much time as they wanted; they operated the switch themselves, and all they had to do was to report in which position of the switch the system sounded better. All but a few reported that they could tell the difference, and almost all preferred the more expensive unit. One person said that as far as he was concerned, the switch "wasn't doing anything at all." That person was right: I was using only one amplifier and the switch was not connected to anything. The results were statistically significant, and showed that people can fool themselves with alarming ease. Kilde Lenke til kommentar
satek777 Skrevet 24. november 2006 Forfatter Del Skrevet 24. november 2006 "Hjernevaskede hifi-fantaster"? Javel. Hm, greit. Jeg er den første til å innrømme at digitale kabler ikke er min force, derfor etterspørselen etter erfaringer. Når det gjelder din påstand om blindtest, hadde dette vært meget interessant, uten at jeg på forhånd har noen formening om resultatet. Hvor bra MS-kabelen er i forhold til Monster Cable vet jeg heller ingenting om. Merkelig egentlig at slike tester ikke blir gjennomført hyppigere, med skjermbilder som klart illusterer forskjellen, hvis noen. Har lest mange anmeldelser etter at jeg skrev det innledende innlegget, og må jo si at Monster Cable får svært gode tilbakemeldinger over hele linja. Og du, "Darth MToffy": til syvende og sist VET du jo egentlig ikke hva kvalitetsforskjellen består i, eller hva? Det jeg etterspør er om noen har en erfaring med disse kablene, og hva de mener forskjellen består i, om det er verdt investeringen, ikke sant? Uansett holder jeg ved min påstand at dårlige kabler har fått mange krem-anlegg til å underprestere... P.S.: hvis noen kan referere til blind tester som viser at det er ingen forskjell i lydkvalitet mellom en billig optisk og en high-end kabel, innrømmer jeg lett dette. Er ikke en prestisjesak dette, har bare lyst til å finne ut om det er verdt investeringen. Lenke til kommentar
Tav0 Skrevet 31. mai 2007 Del Skrevet 31. mai 2007 (endret) Her en god side om forskeller mellom kabler: s-video, composit, component og vga(med bilder)http://www.gamespot.com/features/6139690/index.html Endret 31. mai 2007 av Tav0 Lenke til kommentar
sogasg Skrevet 31. mai 2007 Del Skrevet 31. mai 2007 (endret) Har ikke prøvd monster enda. Men jeg er storfornøyd med kompnentkabelen til xbox 360, den er mye bedre enn VGA-kabelen. Jeg har Samsung LE32R72 (720p) og har både Joytech koponentkabel, MS VGA-kabel og MS komponentkabel. MS sin komonentkabel er klart best. og en liten tommelfinger-regel hold deg alltid langt unna alt som har med Joytech å gjøre Endret 31. mai 2007 av sogasg Lenke til kommentar
Gastaa Skrevet 31. mai 2007 Del Skrevet 31. mai 2007 Jeg har et lite off topic spørsmål. Jeg kjører min 360 til en Samsung 32" lcd med standard komponentkabler, og lurer på om det er vits i det hele tatt å kjøpe vga kabler? Hva er egentlig forskjellen? Lenke til kommentar
Mala Skrevet 1. juni 2007 Del Skrevet 1. juni 2007 Foreslår at du fortsetter med komponent kablene, gir flotte HD bilder med gode farger og kontraster. Mange sliter med noe blassere bilder ved bruk av VGA kabler, men dette er kraftig forbedret etter siste oppdatering Lenke til kommentar
Spitzi Skrevet 1. juni 2007 Del Skrevet 1. juni 2007 (endret) Jeg har et lite off topic spørsmål. Jeg kjører min 360 til en Samsung 32" lcd med standard komponentkabler, og lurer på om det er vits i det hele tatt å kjøpe vga kabler? Hva er egentlig forskjellen? 8754129[/snapback] Jeg hadde vurdert VGA-kabelen fra Microsoft (ikke Joytech!), dersom du har HD-DVD-spilleren. Det blir nemlig litt bedre enn med komponent, men ellers er det lite forskjell. Før våroppdateringen var VGA ganske blass og kjedelig, men det er bedre nå. Er du stinn av gryn, kan du kjøpe Monsterkabler fra Modnet.no - men om det er verd det er en annen sak. Jeg bruker Monsters komponentkabel til projektoren, og MS komponent til min Samsung 32". Har hatt Joytech VGA kabel, men denne er veldig blass, og plaget av litt ghosting - men HD DVD ble litt mer detaljert pga oppløsningen - men har valgt å bruke komponent fordi farger og kontrast tross alt er viktigere enn ren oppløsning. VGA-inngangen er uansett opptatt nå pga PCen. Endret 1. juni 2007 av Spitzi Lenke til kommentar
