Corsair PC150 256mb CAS 2/2/2 SDRAM
atlantaoc.com har nå testet Corsair PC150 256mb CAS 2/2/2 SDRAM.Den kjørte stabilt på 150MHz cas2 med alt på max.
The Corsair PC150 RAM showed a significant improvement over the generic PC133, and really blew it away when running at optimum settings. I still think there are a few more MHz left in there, but that's for another day. I can't say I am disappointed in the purchase by any means; it does exactly what it is supposed to do, not one tiny bit more, but it does its job. While this RAM may not hit the 166 like the Kingmax RAM, it is by no means a bad buy if you are looking to increase the FSB within the 150MHz range.
Les testen her:
http://www.atlantaoc.com/reviews.php?op=sh...owcontent&id=21
_________________
mvh
Kjell Erik Budalen
http://www.overklokking.no
[ Denne Melding var redigert av: kjekka på 2001-09-23 09:40 ]
