IGN COD3 review. PS3
Straffa
Based on criteria like this, it's hard to imagine COD not impressing. After all, it sounds exciting, so where are all the pitfalls? Unfortunately, they can be found everywhere... especially if you've played the Xbox 360 version released earlier in the year. A quick comparison reveals those differences right off the bat. Be it with multiplayer options and online capabilities (360 has a point system and voice support, PS3 doesn't), or the visuals (Xbox moves at a smoother framerate with few hitches, while the PS3 version stutters often and boasts a more "washed out" color palette)
The constant glitches and freeze-ups, however, are downright deplorable. In the 10 hours we spent with the single-player campaign, we had to restart a checkpoint five to six times because certain flags wouldn't activate (i.e., doors that were supposed to open didn't, walls that were supposed to break wouldn't, and characters that were supposed to die couldn't).
Moreover, soldiers that die on roofs or on top of tanks float in the air or clip through buildings with alarming frequency; grenades can go off in a crowd of people and do nothing but make noise and devastate no one; sound effects and other audio occasionally drop in and out, and can even stop working altogether for no reason. But worst of all, Call of Duty 3 can and will lock your PlayStation 3 up -- sometimes when quitting multiplayer, sometimes when quitting back to the XMB, and sometimes for no reason at all.
Washed out colors, multiple collision issues, and a highly inconsistent framerate hurt what was a very good looking Xbox 360 game.
PS3 imponerer for tiden...
Virker som en god del av disse multiplatform spillene som kommer til PS3 nå er veldig forhastede prosjekter for å få de klare til lanseringen. Synd for PS3 eierene...
7334243[/snapback]
Sist jeg sjekket har COD3 vært like lenge under utvikling for PS3 som X360
Endret av avanore
Håper dette kan få dere PS3 (pådødoglivframforaltannet) fanboys til å skjønne at PS3 ikke nødvendigvis blir så mye bedre enn x360.
Missforstå meg rett, jeg er ikke noe PS3 hater. Men må innrømme at jeg fryder meg litt ekstra når jeg leser så mye negativt om PS3.
Håper bare den kommer seg opp å kjører! for det er ei maskin jeg har lyst på
Overrasker meg litt av lanseringstitlene ikke bedre optimalisert enn lanseringstitlene til X360 i og med at spesifikasjonene til PS3 har vært kjent på et mye tidligere tidspunkt i forhold til launch enn det 360 spes. var.
Greit at Cell er vanskeligere å programere til, men hva er poenget med å lage en cpu som er så vanskelig å programere at det går ut over ytelse og kvalitet?
Endret av espent
7334580[/snapback]
4D
Dette trodde jeg var allmennkunnskap.
Tror ikke du er den eneste her som fryder deg over det... Personlig så syns jeg det er kjedelig å lese så mye negativt om ps3, har lenge gledet meg til denne. Men har fortsatt noen måneder til å se hvordan det går før jeg kjøper. Håper og tror at mye av problemet ligger i dårligere erfaring med å utvikle for arkitekturen til ps3 sammenlignet med xbox360, og at det har vært hastverk med å få ut spillene tidlig i lanseringen, selv om de kanskje ikke er helt klare.
Fortsatt optimist :)
Kvar er Avean?
Rart at med ein gong det er noko negativt (som er bevist av ei større webside), så er han ingen plass og sjå.
Uansett, trist for PS3 early adopters.
7335051[/snapback]
Er ikke så mye å kommentere her akkurat
Synd for PS3 eiere som har lyst på COD3, at de må betale så mye for å få en dårligere versjon
7335509[/snapback]
Jeg tviler på at CoD er en grunn for å skaffe seg PS3, det blir jo kjøpt pga de ekslusive titlene, og ikke multiplatform-spill..
Men ellers virker mange av multiplatformspillene rushet og lite optimalisert.. Lurer på hvordan testinga har fåregått :\
Gjest medlem-105082
Kvar er Avean?
7335051[/snapback]
Er "Avean" en skikkelig PlayStation elsker?
Endret av medlem-105082
Det vil vere å si det på ein mild og formell måte.
Men joda, 360 er visst det rette valget å gå om man vil ha best mulig optimaliserte multiplatform spill, ihvertfall no til å begynne med. Er glad eg sitter med COD3 i dag på 360 for å si det slik :)
