Musematte: Raptor-Gaming P3 eller P4?
Jeg skal ha ei ny musematte til Logitech G5 / MX1000 og lurer på hvilken av disse mattene fungerer best. Begge musa bruker laser.
RAPTOR-GAMING P3
Klikk for å se/fjerne innholdet nedenfor
The RAPTOR-GAMING P3 has been developed especially with and for gamers. This mousepad enables efficient and precise work with the mouse without jerks or dropouts. In addition, the RAPTOR-GAMING P3 enhances targeted precision by its special surface structure. The bearing surface is significantly larger as compared to common high-sense mousepads and keeps the gaming mouse in touch even during hectic moves. The RAPTOR-GAMING P3 is made of robust and scratch-resistant plastic material, offering an extremely easy-to-clean surface. The bottom side has been sprayed with a special rubber coating to avoid slipping even on very smooth surfaces. The RAPTOR-GAMING P3 comes with a comfortable bag for safe transport of the mousepad to the next LAN and also includes an extra set of RAPTOR-SLIDERS to improve the slippage of your mouse. The RAPTOR-GAMING P3 is used by prominent eSports-Clans, like f.e. n!faculty or Meet your Makers (mYm).
Technical details:
Structured sliding surface
Very low friction
Excellent sliding properties
Robust and scratch-resistant coating
Anti-slip bottom
Easy and accurate per-pixel cursor control
Spacious bearing surface (310 x 220 mm)
Absolutely waterproof, easy to clean
Extensive durability
Especially ergonomic design
Compatible to all common mouse types
Extremely flat – Thickness: 1.5 mm only
Dette er en hard matte
RAPTOR-GAMING P4
The RAPTOR-GAMING P4 consists of a flexible foam plastic mat. Its surface is large as compared to the other RAPTOR-GAMING mousepads. This mousepad has been developed especially for gamers with extremely low sense. The surface is covered by especially coated black high-quality textile material. The RAPTOR-GAMING P4 is suited for the general use of optical and ball mice. The thickness of only 2mm avoids early fatigue of the wrist and therefore, is ideal for extensive deathmatches. The RAPTOR-GAMING P4 is among the most flat pro-gamer mousepads on the market. The complete bottom side is coated with a profiled anti-slip rubber, keeping the mousepad from slipping on any surface.
Technical details:
Especially coated black high-quality textile material
Friction adapted to low-sense gamers
Excellent gliding properties
Anti-slip bottom side
Spacious bearing surface (400 mm x 300 mm)
Extremely ergonomic design
Low thickness of only 2 mm
Dette er en tøymatte
Takk for innspill!
