HL/CS protokollen
Hei
Jeg har et spørsmål her:
Hvordan man får informasjon ut av en HL server ved å sende kommandoer til den via UDP eller evt. TCP
Hvordan jeg kan hente info om antall frags, bane, antall spillere, osv.
Tusen takk for all hjelp
Endret av Neverio
   // Name: Half-Life RCon Class
   // Description:This Class is rcon protoc
   //     oll implemantation.
   It allows u to send commands to a hl based gameserver without any knowledge of the rcon protcoll or udp sockets. code is commented.
   And dont forget to rate this code :-)
   // By: Holger Kaslowitz
   //This code is copyrighted and has    // limited warranties.Please see http://
   //     www.Planet-Source-Code.com/vb/scripts/Sh
   //     owCode.asp?txtCodeId=2384&lngWId=10    //for details.    //**************************************
   Public Class HLrCon
   #Region "Various Variables"
   Dim UdpSender As Net.Sockets.UdpClient
   Dim UdpReceiver As Net.Sockets.UdpClient
   Dim RconId As UInt32
   Dim Passwort As String
   Dim UniqueIdentifier As String = "cdf0c103e995bbd63cb3050a96531ec7"
   Dim Anfang As Byte() = {255, 255, 255, 255}
   Dim StringConverter As New Text.ASCIIEncoding
   Dim uintConverter As New System.ComponentModel.UInt32Converter
   #End Region
   Sub New(ByVal Host As String, ByVal Port As Int32, ByVal Password As String)
   Dim HelloMessage As Byte()
   Dim ReceiveBuffer As Byte()
   Dim Temp As New ArrayList
   'Adding the 4 255
   Temp.AddRange(Anfang)
   'Creating a new Socket
   UdpSender = New Net.Sockets.UdpClient(Host, Port)
   'Adding Challenge Message
   Temp.AddRange(StringConverter.GetBytes("challenge rcon" & Chr(10)))
   'Converting to ByteArray for sending
   HelloMessage = Temp.ToArray(GetType(Byte))
   'Sending...;-)
   UdpSender.Send(HelloMessage, HelloMessage.Length)
   'Receiving
   ReceiveBuffer = UdpSender.Receive(New Net.IPEndPoint(Net.IPAddress.Any, 0))
   'Parsing Answer
   Dim Tempstring As String = StringConverter.GetString(ReceiveBuffer)
   Tempstring = Tempstring.TrimEnd(Chr(10))
   RconId = uintConverter.ConvertFromString(Tempstring.Split(" ")(2))
   Passwort = Password
   End Sub
   Public Function SendCommand(ByVal Command As String) As String
   Dim TempList As New ArrayList
   Dim TempArray() As Byte
   'Creating the Message
   TempList.AddRange(Anfang)
   TempList.AddRange(StringConverter.GetBytes("rcon " & uintConverter.ConvertToString(RconId) & " " & Passwort & " " & Command))
   TempArray = TempList.ToArray(GetType(Byte))
   'Sending
   UdpSender.Send(TempArray, TempArray.Length)
   'Waiting for response
   Return StringConverter.GetString(UdpSender.Receive(New Net.IPEndPoint(Net.IPAddress.Any, 0))).Substring(5)
   End Function
   End Class
VB.NET kode, du burde klare å "oversette" det til C++ kode.
Endret av chills
  • 1 år senere...
Hvorfor bumper du flere år gamle tråder?
Så ikke på datoen på trådene, tenkte kanskje at forumet var litt mer aktivt enn det igrunn er. Er jo altids kjekt å ha løsninger liggende ute på nett. Men da får jeg vel igrunn finne meg et litt mer seriøst forum da, siden alle her virker afk. (Med enkelte unntak)
Det er jo så koselig her :yes:
Ingen grunn til å baile fra diskusjon.no eller kalle forumet for useriøst.
Det er en koslig stamgjeng her, som klarer å dra svært mange tråder off-topic med koseprat når problemet er løst. En del andre er inaktive, men istedenfor å ditche diskusjon.no er det vel bare å vanke andre steder i tilegg?
