Bluescreen, (Try changing video adapters)
Hei,
Sliter med "Bluescreen" problemer, problemet intreffer både idle og load. Noen ganger sitter jeg i flere timer før det skjer andre ganger få minutter.
Error beskjed:
A problem has been detected and widnows has been shut down to prevent damage to your computer.
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to be sure you have adequate disk space. If a driver is identified in the Stop message, disable the driver or check with manufacdturer for driver updates. Try changing video adapters.
Check with you hardware vendor for any BIOS updates. Disable BIOS memory options such as catching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select safe mode.
Technical information:
*** STOP: 0x0000007E (0x0000005, 0x804E6C97, 0xF78EECAC, 0xF78EE9A8)
Beginning dump of physical memory.
Physical memory dump complete.
Contact your system administrator or technical suppeort group for further assistance.
Takk for din oppmerksomhet!
