COD3, NFS:Carbon PS3 dårligere enn til X360
Straffa
Gamespot
It was fast and mostly smooth on the 360, but the game's extremely choppy on the PlayStation 3. This problem isn't limited to hectic battle sequences either--it'll chug in rooms that are completely empty
Twenty-four people can play online, but whereas four players per Xbox 360 could go online, just one person can play on a single PS3
Link
PS3 versjonen sliter med framedrops selv i 30 FPS
X360 kjører 60 FPS og svært sjelden går den under
Ingen split screen, det er tragisk
NFS:Carbon
IGN
One disappointing aspect is that the PlayStation 3 version of the game doesn't have a couple of the "show off" features that the Xbox 360 game does. The 360 version lets you pause the game at any time and enter a photo mode. It's basic, sure, but you can spin and zoom the camera and take a snapshot of your vehicle in motion. You're also able to upload a photo of your modded vehicle for others to drool over, but the PS3 game lacks this feature as well, sadly.
Visually, the PlayStation 3 version of Need for Speed Carbon falls short of its Xbox 360 counterpart. The two games run at roughly the same framerate, but the PS3's filtering effects, specifically the blurring, can be ugly. Road textures look nice and detailed at low speeds, but when you're flying down the road and the game blurs everything, they simply look poor. A few other odd things don't match up either, like the Drafter's wake, which is a transparent cylinder on the 360 and some rather ugly blue streamers on the PS3.
Link
Endret av avanore
"Ikke bra"? I følge artikkelen du lenka til var det "8.2 - great".
Men litt skuffande at dei ikkje har klart å optimalisere det betre for PS3, ja.
Kay
7292900[/snapback]
Er ikke bra når du ikke kan ha split screen engang.
FPS drops når spillet kjøres bare i 30 frames er tragisk
Endret av avanore
Siterer meg sjøl fra ein annen tråd:
Noen som bør sette seg ned å lese CELL for dummies manuelen til neste gang eit spill skal portes ihvertfall....
7292335[/snapback]
7292892[/snapback]
Siterer meg og de fleste andre som har tatt på en PC
Flaskehalsen er som regel GPU
Endret av avanore
7292917[/snapback]
Jaudå, eg er med på det. Men utifrå emnetittelen ser det ut som om Gamespot seier at COD til PS3 ikkje er bra. Og det blir litt feil når konklusjonen deira er at det er "great".
Kay
7292917[/snapback]
Kay
7293018[/snapback]
Ser du bort fra FPS drops under 30 frames og ingen splitscreen, så er gameplayet det samme. Derfor den karakteren
Endret topic
Endret av avanore
7293038[/snapback]
Jau, har ingen problem med det. Men noko slikt som "Gamespot: COD til PS3 dårlegare enn til XBox360" hadde vore meir rett.
Kay
7293038[/snapback]
Kay
7293076[/snapback]
Greit :)
Å, her får vi virkelig se at Bluray får kjørt seg med all sin kapasitet! Absolutt verdt den ekstra kostnaden! Resistance og CoD3 er bevis på dette. :dribble:
Nei, det her var ikke bra nei. Men så er det sikkert vanskelig og porte det også, i og med såpass forskjellige arkitekturer. Også er jo PS3 i sin tidlige levetid... men CoD2 til 360 høres da bedre ut enn dette her, og det var også en release tittel
Skulle likt å sett ein viss person innom denne tråden her i kveld altså;)
Regner med at porter kommer seg på PS3 med tiden etter at utviklerene har blitt kjennt med hardwaren i PS3 :) Men det virker jo som at 360 egner seg best for multiplatoforsm spill foreløpig.
Atter en tråd som kritiserer 360 fra vår alles gode nøytrale venn avanore. :dontgetit:
Det er vel ikke så utenkelig at de baserte dette på 360 arkitektur og bare prortet det over. Noe som gjør at den maskinen som får en port ikke klarer å holde målet til "orginalen"
Å viss noen prøver seg på å si at dette bare er hardware, vel, da burde de kanksje fått en liten ferie.
PS3 prestere bedre? Er vel heller de som portet det som fortjener ett spark bak for å gjøre dårlig jobb spør du meg. Jeg er ikke konsoll hardware guru, men det irriterer meg når folk legger skylden på Sony (greit, de kunne sikkert laget bedre dev kits osv osv osv) når det ofte er utviklerne som kutter noen hjørner. Ikke at det nødvendigvis alltid er deres feil heller om de har en deadline hengendes over hodet.
Denne tråden kjem heilt sikkert til å bli Flaming Console Boy Deluxe Edition 1337 her på forumet.
Då problemet heilt sikkert ligger i at det har vore problemer å porte spelet til PS3 så seg eg ingen grunn til å krangle vidare. Hadde eit spel vore primært utvikla for PS3 og porta til Xbox 360 så ville me ha sett same effekten.
Bør tråden stenges? Nei det er enda fullt mogleg for ein god diskusjon, men usaklege innlegg vil slettes og warn vil bli utdelt. Kjem det ut av kontroll så blir det rett og slett bare stengt.
