Kjore 2 OS paa en gang?
eikum
Boot.ini filen mistet sin effekt når du installerte Vista :)
Nå er det Boot menyen til Vista som teller.
Prøv dette:
1. Right-Click on My Computer and select properties
- (In Vista you can select View System Information from the Computer window.)
2. From the System Properties window select the Advanced tab
3. Push the Settings button under Startup and Recovery
4. Select the default OS from the Default operating system dropdown box.
5. Click OK twice.
