Play.com
CickNave
Den prisen du ser på play.com er den du totalt betaler. Dersom tollmyndighetene eller andre kjipe instanser gir deg gebyr får du dette refundert ved å sende inn kvittering til Play.com.
Jeg har kjøpt der i ett år eller så, både spill, musikk og dvder, og jeg er kjempefornøyd. Det er jævli behagelig å vite at den prisen som står på produktet er den endelige prisen, og at det ikke er slike "opp-av-hatten" kostnader som frakt, gebyrer og annen dritt.
Leve Play.com
Moms har jeg aldri hatt noe problemer med. Dette tollgebyret er vanskelig å slippe unna, men kompisen min sendte en mail inn til Play.com og spurte. Her er korrespondansen;
Subject: movies for more than about 250,- NOK needs taxes :sad:
> Hi
> I realy like your web-shop, its easy to find movies and a good
> lay-out. The first movies I bought was delivered direct to my
> mail-box. but when I ordered the Simpsons season 2 box set. I got a
> note in my mail-box whith a message that I had to pay taxes on it.
> If I have to pay tax on the typical boxed-set it will be cheaper to
> buy it in the stores here.
> Regards
Date: Mon, 19 Aug 2002 14:21:42 +0100
To:
Subject: Re: movies for more than about 250,- NOK needs taxes :sad:
Hi there,
Certain REGION 1 products which are shipped from North America are liable
for customs duties on their arrival in the EU. Customs occasionally levy a
charge on these products which varies from country to country. Usually this charge is between 10-20% of the products value.
ONLY products where the customs disclaimer appears are liable for these
additional charges. We guarantee these charges will not be applied to any
REGION 1 product where the disclaimer does not appear and will not be applied to ANY REGION 2 titles GAMES or CD's.
Please Post/Fax/Email us any proof of unnecessary charges and we will refund you card.
We hope this helps.
Kind Regards
Play
Det betyr at du kan sende inn kvitteringen på tollgebyret og få den refundert. De sender oxo sakene i enkle "brev" slik at det skal endel til å gå over grensen.
Jeg ble klar over play.com da de vant en eller annen test i en eller annen nettavis. Du kan lese mer her http://www.dvdarkivet.no/nettbutikker.php
Kjøper ukentlig saker derfra så jeg er veldig fornøyd.
Håper dette hjalp deg litt...
