Hvordan resize video
Prøvde med AutoGK også, men får feilmld fra VirtualDub:
"Video compression error: The source image format is not acceptable. (error code -2)"
Logg:
Klikk for å se/fjerne innholdet nedenfor
[15.11.2006 22:23:14] AutoGK 2.27
[15.11.2006 22:23:14] OS: WinXP (5.1.2600).2
[15.11.2006 22:23:14] Job started.
[15.11.2006 22:23:14] Input file: E:\Mine dokumenter\RKH\rkh-reklamefnutt.mpg
[15.11.2006 22:23:14] Output file: E:\Mine dokumenter\RKH\rkh-reklamefnutt.avi
[15.11.2006 22:23:14] Output codec: DivX
[15.11.2006 22:23:14] Audio 1: Audio Stream 0 MPEG
[15.11.2006 22:23:14] Subtitles: none
[15.11.2006 22:23:15] Format: .AVI
[15.11.2006 22:23:15] Target size: 50Mb
[15.11.2006 22:23:15] Started encoding.
[15.11.2006 22:23:15] Demuxing and indexing.
[15.11.2006 22:23:18] Processing file: E:\Mine dokumenter\RKH\rkh-reklamefnutt.mpg
[15.11.2006 22:23:18] Source resolution: 480x576
[15.11.2006 22:23:18] Found PAL source.
[15.11.2006 22:23:18] Source aspect ratio: 4:3
[15.11.2006 22:23:18] Analyzing source.
[15.11.2006 22:24:15] Source is considered to be interlaced.
[15.11.2006 22:24:15] Output will contain 4100 frames
[15.11.2006 22:24:15] Encoding audio.
[15.11.2006 22:24:55] Audio1 size: 2,293,622 bytes (2.19 Mb)
[15.11.2006 22:24:55] Overhead: 267,392 bytes (0.26 Mb)
[15.11.2006 22:24:55] Video size: 49,867,786 bytes (47.56 Mb)
[15.11.2006 22:24:55] Target bitrate is: 2433kbps
[15.11.2006 22:24:55] Running compressibility test.
[15.11.2006 22:26:02] Duration was: 1 minute, 6 seconds
[15.11.2006 22:26:02] Speed was: 30,18 fps.
EXCEPTION: Open avi failed.
[15.11.2006 22:26:02] Job finished. Total time: 2 minutes 47 seconds
