Feilmelding - mot mysql - versjon?
Jeg har funnet ett script for opplasting av csv filer og ilegging av disse til en mysql database.
men jeg får feilmeldingen :The used command is not allowed with this MySQL version
error_reporting(E_ALL);
include_once "config.inc";
$php_self = $_SERVER['PHP_SELF'];
$file_open = 0;
$page = "<center>
<div align='center' style='border: 1px solid #000000; background-color: #000000;padding: 5px; color: #071bfd; width: 550px; font-family: verdana, arial, sans-serif;' >
<table align='center' style='border: 1px solid #eff7c2; background-color: #e2feea;padding: 10px; color: #071bfd;' cellspacing=5><tbody>
<tr><td style='background-color: #000000;padding: 5px'><u><b><h3><font color='#ffffff'><center>AGTC - CSV Upload Script v1.0a ©2006</center></font></h3></u></b></td></tr>
<tr><td><span style=\"font-family: arial, sans-serif;\"><i><b>Instructions on use:</b></i> <br />
Before using this script please read the <a href='README.html'>README.html</a> file to check you have installed it correctly.<br />
Please make sure you are trying to upload a TXT or CSV file only with the extension .txt or .csv at the end of the file name. <br />
Do not exceed the maximum upload size of 2mb.<br />
You can create your files using MS-Excel or similar CSV creator.<br /><br /></td></tr>
<form enctype='multipart/form-data' action='$php_self' method='post' onSubmit='Alert()'>
<input type='hidden' name='MAX_FILE_SIZE' value='2000000' />
<input type='hidden' name='option' value='yes' />
<font color='#ffffff' size='-1'>Locate  CSV File: <br /></font><input name='csvfile' type='file' size='70' /> <br />
<center><input type='submit' value='Upload CSV File' />
</td></tr></tbody></table></div></center>";
if(!isset($_POST['option'])){
 	echo $page;
 elseif($_POST['option'] == "yes"){
 $uploaddir = './uploads/';
 $uploadfile = $uploaddir . $_FILES['csvfile']['name'];
 if (move_uploaded_file($_FILES['csvfile']['tmp_name'], $uploadfile)) {
 print "<font face='arial'>Successfully uploaded. ";
 $notice = 1;
 chmod($uploadfile, 0777);
 } else {
 print "<font face='arial'>ERROR: Upload Failed. ";
 $notice = 0;
 $notice = 1;
 if ($notice == 1) {
 echo "\n sending Data...";
 flush();
 echo "</font>";
 if (file_exists($uploadfile)) {
 $fp = fopen($uploadfile, 'r') or die (" Cannot open the file");
 $fileopen = 1;
 $length = calculate_length($uploadfile);
 $replace = "REPLACE";
 $field_terminater = ",";
 $enclose_option = 1;
 $enclosed = '"';
 $escaped = '\\\\';
 $line_terminator = 1;
 $local_option = 1;
 $sql_query     =  'LOAD DATA';
 	if ($local_option == "1") {
   $sql_query     .= ' LOCAL';
 	$sql_query     .= ' INFILE \'' . $uploadfile . '\'';
 	if (!empty($replace)) {
   $sql_query .= ' ' . $replace;
 	$sql_query     .= ' INTO TABLE ' . "`csv_test`";
 	if (isset($field_terminater)) {
   $sql_query .= ' FIELDS TERMINATED BY \'' . $field_terminater . '\'';
 	if (isset($enclose_option) && strlen($enclose_option) > 0) {
   $sql_query .= ' OPTIONALLY';
 	if (strlen($enclosed) > 0) {
   $sql_query .= ' ENCLOSED BY \'' . $enclosed . '\'';
 	if (strlen($escaped) > 0) {
   $sql_query .= ' ESCAPED BY \'' . $escaped . '\'';
 	if (strlen($line_terminator) > 0){
   $sql_query .= ' LINES TERMINATED BY \'' . '\n' . '\'';
 $result = mysql_query ($sql_query);
 echo mysql_error();
 if(mysql_affected_rows() > 1) {
   echo " <div align=left><b><font color='#071bfd' face='arial'>The CSV data has been added to your database.<br><br> <a href='javascript:history.back()'><<< Return to CSV Upload Script</a></font></div> ";
 else {
 	error_log(mysql_error());
 	echo " <div align=left><b><font color='#e42127' face='arial' > ERROR, could not add the CSV data to your database.</font></div>";
 if ($file_open ==1) {
 fclose($fp) or die("ERROR: Could not close the file");
function calculate_length($fp) {
  $length = 1000;
  $array = file($fp);
  for($i=0;$i<count($array);$i++)
      if ($length < strlen($array[$i]))
          $length = strlen($array[$i]);
  unset($array);
  return $length;
<script language="Javascript">
function Alert() {
var question = alert("Confirm this is a CSV file no more than 2mb in size!");
return question;
</script>
Gjest Slettet+142
vet ikkje så mye om det, men søk på feilmeldingen på google, og vips :)
se et stykke på siden
If LOAD DATA LOCAL INFILE is disabled, either in the server or the client, a client that attempts to issue such a statement receives the following error message:
ERROR 1148: The used command is not allowed with this MySQL version
håper det hjelper litt isåfall :p
