msi p965 platinum feil
Quir0
Tror du må installere enten Dual CoreCenter eller Dual CoreCell, men sjekk hva MSI sier (du har ikke oppgitt noe maskinvare i signaturen):
>If you are using an ATI graphic card, you must install ver. 8.26 driver and its additional applications to make Dual CoreCenter works normally. It is better to use recommended installation while installing an ATI VGA driver.<
Flere tips i MSI-forumet
