Når ble Brent Blend dannet?
Som Stjernespørsmål til elevøvningen ble klassen min spurt om:
"I hvilken geologisk tidsalder ble mesterparten av oljen type Brent Blend dannet, og i hvilken temperaturintervall ble denne dannelsen gjennomført"
Søkt rundt om kring men har ikke funnet noe ennå. Hvis noen visste dette hadde det vært kjempeflott!
Mye bra info på :
http://en.wikipedia.org/wiki/Brent_Blend
http://en.wikipedia.org/wiki/North_Sea_oil
  "Wikipedia" skrev:
Middle Jurassic
Northern North Sea tilted fault blocks; Brent Series deltaic sands of Bathonian age. In 1971 the Shell/ Esso joint venture drilled a poorly resolved structure in block 211 and found a classical prograding delta sand sequence (the Brent Sands overlain by a good source rock (the Kimmeridge Clay Formation, broke up into tilted fault blocks due to crustal extension, and the whole sealed by the lateral equivalent of the Chalk, the muddy Shetland Group. Several billion barrels of oil later, the Brent Field is being depressurised in the mid 2000s with shutdown looming on the horizon. Economically, this is the major play in the North Sea.
Altså dannet under Jura tiden
Endret av Thorsen
