Konkret CPU anbefaling, Hvilken CPU? Intel.
dale
Hei, jeg har et Kontron 986LCD-M/mITX embedded. Som du finner her.
Info om kortet følger her:
Klikk for å se/fjerne innholdet nedenfor
Most featured and highest performing Mini-ITX in the market with support for all PGA & BGA Core Duo and Core solo CPU.
Intel® Core™ Duo and Core™ Solo Processors (mPGA478 socket, mBGA479 prepared)
Support Yonah and Merom CPU core
Front Side Bus 533/667 MHz
Intel® 945GM + Intel® ICH7R Chipset
Intel® GMA950 graphic controller on board
Flat Panel Display Support
Dual independent Display Support (incl. 2x LCD)
1x 16x PCI-Express /SDVO external graphic card socket
2GB DDR2 memory support
3x 10/100/1000 Mbps Ethernet
8x USB 2.0, 4x RS232C, 2x IEEE1394
1x ATA100 and 4x SATA150/300 IDE Controller
1x Compact Flash socket
1x mini PCI-Express socket for easy expansion of i.e. wireless LAN
On board RAID 0/1/5/10 support with SATA harddisk
7.1ch HDA / AC-97compliant audio output
Size: 170 x 170 mm (6.7" x 6.7")
Description
986LCD-M/mITX support latest Intel® Core™ Duo and Core™ Solo processors up to 2.16GHz. Due to the latest Intel's dual core technology, the board achives both superior data processing capability and low power consumption.
Kan noen anbefale en CPU til meg, den bør være embedded. Og forholdet Ytelse/watt må gå i favør watt. Skal kjøles med en heatpipe.
Jeg har forstått det slik at embedded CPU er industri versjoner som skal holde lengre en std utgaver.
Jeg føler meg noe utdatert i CPU jungelen og er serdeles takknemmlig for all hjelp.
Kristoffer : )
