MortenS Skrevet 6. november 2006 Del Skrevet 6. november 2006 (endret) En kompis har fått trøbbel med begge DVD-brennerne etter han installerte Windows Genuine Activation check ved feil. Er det mulig at WGA kan disable eller rote med innstillinger hvis den mener windows versjonen er fake? Høres spesielt ut, men DVD brennerne fungerte fint før WGA ble installert. Her er error i DVD Decrypter: Her er error log i Nero: 6.11.2006 Burn DVD Image 21:18:48 #1 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 262144KB of Memory 21:18:48 #2 Text 0 File Reader.cpp, Line 124 Reader running 21:18:48 #3 IMAGEGEN -10 File ImageGen.cpp, Line 366 Image was written as DAO. DAOI: MediaCatalogNumber = '' TocType = 0x40 Finalized = 1 First/Last Track = 1 / 1 1: ISRC = '' Blocksize = 2048 TrackMode = 'TRM_DATA_MODE1' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4359979008 CUES: 0: Ctrl=0x41 Trk= 0 (0x00) Index=00 Start=00:00.00 ( 0) RecDep=0x00 1: Ctrl=0x41 Trk= 1 (0x01) Index=00 Start=00:00.00 ( 0) RecDep=0x00 2: Ctrl=0x41 Trk= 1 (0x01) Index=01 Start=00:00.00 ( 0) RecDep=0x00 3: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=473:05.21 ( 2128896) RecDep=0x00 MTYP: Mediumtype = DVD (old format) (0x1C) Image file name: <F:\backup.nrg> 21:18:48 #4 Text 0 File Burncd.cpp, Line 3342 Turn on Disc-At-Once, using DVD media 21:18:48 #5 Text 0 File DlgWaitCD.cpp, Line 279 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 2128895 (473:05.20, 4157MB) 21:18:48 #6 Text 0 File DlgWaitCD.cpp, Line 291 Write in overburning mode: NO (enabled: CD) 21:18:48 #7 Text 0 File DlgWaitCD.cpp, Line 2578 Recorder: _NEC DVD_RW ND-3500AG, Media type: DVD-R Disc Manufacturer: DAXON0 - 16S Disc Application Code: 64, Disc Physical Code: 193 21:18:48 #8 Text 0 File DlgWaitCD.cpp, Line 458 >>> Protocol of DlgWaitCD activities: <<< ========================================= 21:18:48 #9 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (1 - DVD-ROM) 2 indices, index0 (150) not provided original disc pos #0 + 2128896 (2128896) = #2128896/473:5.21 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2128896 blocks [Z: _NEC DVD_RW ND-3500AG] -------------------------------------------------------------- 21:18:48 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [Z: _NEC DVD_RW ND-3500AG] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x40; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4359979008, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2128896 | lead-out | 1 | 0x41 | 0x00 21:18:48 #11 Text 0 File SCSIPassThrough.cpp, Line 36 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 21:18:48 #12 Phase 36 File dlgbrnst.cpp, Line 1725 Burn process started at 2.4x (3 324 KB/s) 21:18:48 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 21:18:48 #14 Text 0 File DVDR.cpp, Line 2580 Recording mode: Sequential Recording Mode 21:18:48 #15 Text 0 File MMC.cpp, Line 21611 Set BUFE: Buffer underrun protection -> ON 21:18:48 #16 Text 0 File DVDR.cpp, Line 2735 Start write address at LBA 0 DVD high compatibility mode: Yes 21:18:48 #17 Text 0 File Cdrdrv.cpp, Line 8411 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26127F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 2FE10 h Start sector number of the next Border-In: 2FFA0 h Media Specific [16..63]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!.... 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 21:18:48 #18 CDR -1 File ThreadedTransferInterface.cpp, Line 1799 Unspecified Recorder Error Z: _NEC DVD_RW ND-3500AG 21:18:48 #19 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1799 Could not perform start of Disc-at-once 21:18:48 #20 Phase 38 File dlgbrnst.cpp, Line 1725 Burn process failed at 2.4x (3 324 KB/s) Endret 6. november 2006 av MortenS Lenke til kommentar
-Shark- Skrevet 6. november 2006 Del Skrevet 6. november 2006 unistaller WGA da Legg til fjern programmer, hvis alle oppdateringer og bla nedover:) Lenke til kommentar
MortenS Skrevet 6. november 2006 Forfatter Del Skrevet 6. november 2006 unistaller WGA da 7232499[/snapback] "This update cannot be removed" Lenke til kommentar
-Shark- Skrevet 6. november 2006 Del Skrevet 6. november 2006 unistaller WGA da 7232499[/snapback] "This update cannot be removed" 7232560[/snapback] Nedtur Jeg kunne ihvertfall gjøre det. Formater da Lenke til kommentar
MortenS Skrevet 6. november 2006 Forfatter Del Skrevet 6. november 2006 Hva om det er DVD platene som er fucked? Bruker en ny spindle med Philips 16x DVD-R, men har ingen andre plater. Hvordan sjekker man om brenneren ikke takler platene, et prg? Lenke til kommentar
MortenS Skrevet 7. november 2006 Forfatter Del Skrevet 7. november 2006 Tror det må være at brenneren min NEC ND-3500AG som ikke støtter Philips 16x DVD-R platene, med id: DAXON016S. NEC ND-3500AG har nyeste firmware v2.88. Kjenner noen til workaround for ditta? :-( Lenke til kommentar
-Shark- Skrevet 7. november 2006 Del Skrevet 7. november 2006 Tror det må være at brenneren min NEC ND-3500AG som ikke støtter Philips 16x DVD-R platene, med id: DAXON016S. NEC ND-3500AG har nyeste firmware v2.88. Kjenner noen til workaround for ditta? :-( 7239514[/snapback] prøv med andre plater da vel. Min brenner tar stor sett det meste, en NEC 3550 tror jeg. Kosta 400 en gang. Lenke til kommentar
it2005 Skrevet 7. november 2006 Del Skrevet 7. november 2006 (endret) Fjerne WGA: kjør system restore til tidspunkt før installasjon av WGA Endret 7. november 2006 av it2005 Lenke til kommentar
Reeve Skrevet 7. november 2006 Del Skrevet 7. november 2006 Jeg har en fil osm fjerner WGA, men er ikke sikker på om det er lovlig å gi den ut her, siden den på en måte lar de med piratkopiert windows bruke indows vanlig. Men PM om du skal ha den, så kan vi sikkert ordne det på et vis Lenke til kommentar
